#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2002 Explorer front wheel bearing question
Reply
Thread Tools
Old 12-27-2007, 04:08 PM   #1
NEWFS02X
Manitoba,Canada
2002 E/B 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
CAN 2002 Explorer front wheel bearing question
Any reason why the front bearing can't be removed/replaced in the front hub of these vehicles instead of replacing the entire hub assembly?
I just got a price of $163 up here for Fenco (low line); $266 for CR; and $250 for Bower.
Has anyone ever pressed them out and replaced them?
thanks....John
NEWFS02X is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-04-2008, 11:58 PM   #2
NEWFS02X
Manitoba,Canada
2002 E/B 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Front wheel bearing replacement
Anyone???
Old 01-24-2008, 03:42 PM   #3
Merc02
2002 Mountaineer 2wd V8
Vehicle Specs
Quoted: 2 Post(s)
front bearing
Wow, I'm new here and can't believe no one has replied. I've had to replace both hub assemblies. Dirver's side in Dec '06 and pass side Dec '07. I see parts available to have them pressed out, but I don't know what it takes to get them out and back in properly. I bought the first at the dealer for $158.00, after I asked nicely for a discount. I got the second at rockauto.com, Here's a discount code good til feb 5 2008 for a 5% discount. The 5% actually covered my shipping cost plus some. I paid under $110 total.
* Enter your discount code (and no other characters or spaces) in the "How did you hear about us" line of the shopping cart.
* If you are using our traditional HTML catalog, please click the "Set" button to the right of the field.
* Your discount will automatically appear, subtracted from your order total.
TIMKEN Part # SP470201
Last edited by Merc02; 01-24-2008 at 08:08 PM. Reason: found current discount code
Merc02 is offline   Reply With Quote
Old 01-25-2008, 03:33 PM   #4
34Ford
North Carolina
2002 EB 4.6
Vehicle Specs
Quoted: 0 Post(s)
Well I thought you possibly could since there is bearings for sale to fit the hub.
But after looking my old hub over real close it appears the factory has installed the bearings then used high pressure to press the steel of the hub around the bearings to keep them in place.
Removal of the material would mean there is nothing there to keep the new bearing in place.
Not sure if there are pressed fit or not. But they sure made it so they would never be just merely pressed out.
__________________
Dennis
'03 Mustang Mach 1
'02 Explorer Eddie Bauer 4.6
'01 Lincoln LS
34Ford is offline   Reply With Quote
Old 01-25-2008, 03:42 PM   #5
btexpress
Thornton, Colorado
2009 Ford Explorer Eddie
Vehicle Specs
Quoted: 0 Post(s)
Don't know of any available except the assembly with the hub.
btexpress is offline   Reply With Quote
Old 01-25-2008, 05:42 PM   #6
roh92cp
Fort Kent Maine
2002 Explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
I did have the bearing pressed in for the rear on one side major pain, would have been better to buy the hub assembly which I did when the other side went. I just replaced the front this week and the bearing and hub assebly with speed sensor was $130 from http://www.tascafordparts.com very easy to instal.
roh92cp is offline   Reply With Quote
Old 01-27-2008, 08:47 PM   #7
Rar
Winnipeg, Manitoba
2002 Explorer EB
Vehicle Specs
Quoted: 0 Post(s)
CAN
I had to replace the Rear Passenger Side and pressed out the Bearing, using a 20 Ton Press, anything smaller won't do it. Can't imagine the Front being much different.
Rar
Rar is offline   Reply With Quote
Old 01-27-2008, 10:49 PM   #8
NEWFS02X
Manitoba,Canada
2002 E/B 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
CAN Bearing issue
Hello Roger...good talking to you over the phone.
I just had a look at your F150..that's one clean truck! No rust??
Price is certainly in the ballpark for the shape it's in .
Good luck in selling it....John
Old 01-28-2008, 09:18 AM   #9
just2L
South Dakota
02 XLT
Vehicle Specs
Quoted: 0 Post(s)
I had the left front and the right rear go on mine at the same time. I bought the hub assemblies from a junkyard off an 05 with 20,000 miles on it. The front one swaped out but had to press the back one out and replace it with the 05. The front one took 20 mins. The back one took 3 hours while messing with the press.
All in all it cost me $240 for the hubs and labor for a mechanic to press the the rear hub out and replace it.
just2L is offline   Reply With Quote
Old 01-28-2008, 11:49 AM   #10
NEWFS02X
Manitoba,Canada
2002 E/B 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
CAN hubs
I'm assuming that when you say the front one swapped out you're referring to the entire hub assembly..correct? Not just the bearing.
........John
Old 01-29-2008, 09:37 AM   #11
just2L
South Dakota
02 XLT
Vehicle Specs
Quoted: 0 Post(s)
Yes that is what I meant, it took about 15 minutes from start to finish on the front the rear one was the issue.
Old 01-29-2008, 11:59 AM   #12
NEWFS02X
Manitoba,Canada
2002 E/B 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
front bearing
thanks.............
Old 01-31-2008, 09:15 AM   #13
sfbayjay
Cleveland-ish, OH
2002 XLT SOHC 4L V6
Vehicle Specs
Quoted: 6 Post(s)
Question
Hi all,
After a routine dealer inspection/maint visit, they told me that my 2002 XLT needs a new front left hub/bearing assembly (Quoted me $350). I don't notice anything while driving (no noises, etc.). They didn't drive it, either -- just had it up on the lift.
A local independent shop tells me that if I don't notice anything while driving then I probably don't need a new bearing/hub. They say that "I will know" when the bearins go bad -- either steering will be funny or I will get some serious noise from the front end.
I'm nervous about just driving until I hear terrible noises. Won't I do more damage or have the wheel sieze or something?
What can I do to check this out and make sure I don't need new bearings? Maybe check for play in the wheel when it's off the ground? How much play is tolerable?
Thanks for any advice!
From what I've read, it looks like I could probably change this thing myself -- but I don't have any "specialized" tools. I think I would need to buy a large socket (and a breaker bar?) to remove the driveaxle nut, maybe a puller to get the old hub assembly off the driveaxle, and obviously a torque wrench.
Is it worth buying all the stuff to try it myself, or should I go with a local quote I've got for $272??? I found the part online (Timken SP470200) for $125. How hard would this be for a "rookie"?
Finally -- are there any additional seals or other parts I'd need to buy, or just the hub/bearing assembly?
Thanks a million!
sfbayjay is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
