Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
knocking noise under truck, need help!
Reply
Thread Tools
Old 01-07-2008, 02:58 PM   #1
jad2411
El Paso, TX
blue 02 xlt & white 02xls
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Ok so it's been a while since the noise started, here's what I have done to my truck since:
4 new Monroe sensatrack shocks
reman rack and pinion
2 new cv axles
brake job (4 wheels)
new left upper control arm
2 new hub assemblies
2 new torsion bar adjusters
reman transfer case
removed front shaft (need to get a new or reman one)
Over 3k spent on repairs and noise just won't go away, am I missing something? dealer told me to change the torsion bar adjusters, which I had already done with no results at all,what is there left to do??? with all of that money I could just have bought another truck
jad2411 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-07-2008, 03:21 PM   #2
chriswells78
Powell(Columbus), OH
96 XLT 5.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
When do you hear the knocking noise? Over bumps? Under acceleration, under braking?
__________________
2013 Explorer Limited 4x4 Not modding this one
1999 Mustang GT, 2013 F350 XLT V10
chriswells78 is offline   Reply With Quote
Old 01-07-2008, 03:30 PM   #3
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
most of the time :mad:
That's why I haven't been able to find the problem, but you can hear it during regular driving, don't need to do anything for it to happen, it just does and sometimes it will last thru the entire lenght of the trip, sometimes it will just do it randomly.
First shop I took the truck to told me it couln't be the CV axles as my truck didn't have any (not doing bussines with them as the don't seem to know that 4x4's DO have those) next shop I went to told me that CV axles were not the cause of the noise, but that I needed to replace them as one was already about to break, that's when we found out the upper arm was done, so I took it to a 4x4 shop, to a suspension and to a transmision shop and nobody knows the reasson
I really don't have any more money to spend on things that I might not need
Old 01-07-2008, 03:40 PM   #4
chriswells78
96 XLT 5.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
Have you though it might be something silly like a piece of trim flapping in the breeze? Seems like you have really covered most of the major problem areas of 2nd gen explorers and then some.
__________________
Old 01-07-2008, 03:46 PM   #5
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Yes
First thing I thought was the spare tire, a co-worker had a similar noise and he found out that the spare tire was loose so I took it out, no luck, looked under the truck when they lifted the truck to install the shocks to see if something was loose and couldn't find anything that could be loose and swing during driving to make the noise so, I'm really frustrated
Old 01-07-2008, 04:46 PM   #6
brianjwilson
98 Ranger, 05 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Have you checked the common things like lower ball joints and sway bar bushings and endlinks?
The sway bar bushings seem to be really common. Sometimes you can tighten the crap out of the endlinks and it will get rid of the noise, other times they need replaced. Often, they won't feel loose when you try to move them by hand.
__________________
2006 F150 FX4 Super Crew - Xcal 2, Bilstien 5100's leveled 2"
2003 VW Jetta GLI VR6 six speed, 2" drop on 18's
Old Stuff;
2005 Explorer Sport Trac 4x4 locked and lifted on 33's
1998 Ford Ranger 4x4 on 33's
1997 Ford Explorer 4x4 on 31's
brianjwilson is offline   Reply With Quote
Old 01-08-2008, 06:27 AM   #7
Provokr
Jacksonville, NC
2005 XLT 4.6L 4X4
Vehicle Specs
Quoted: 1 Post(s)
What kind of sound is it? Does it sound like metal on metal... metal on plastic... random intervals?
__________________
2005 XLT 4.6 4X4 w/ 1.5" body lift
"Cars are like legos for grown-ups"
Provokr is offline   Reply With Quote
Old 01-08-2008, 08:10 AM   #8
JoeMahma
Pa.
1997 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Mine was clunking over bumps and driving me nuts. I changed the sway bar end links even though they looked good. They were shot when I got em off but I just couldn't see it while they were on the truck. Clunk is all gone. How's you universal joints on the rear drive shaft? Oh, rear drive shaft slip yoke might need to be lubricated as well.
__________________
~Jamie~
JoeMahma is offline   Reply With Quote
Old 01-08-2008, 10:23 AM   #9
Vinniety
Westchester county, NY
2000 sport
Vehicle Specs
Quoted: 0 Post(s)
What kind of noise are you talking about? Is it a rubbing sound, a clunk, a whinning sound what does it sound like? Did you ever think maybe the tires can be causing it. Rotate them. Just an idea. It seems you changed more things then probably needed to.
__________________
1993 TYPHOON 60K miles
2000 Explorer sport 100K miles
Vinniety is offline   Reply With Quote
Old 01-08-2008, 11:08 AM   #10
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
have you checked the transmission mount?
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 01-08-2008, 12:47 PM   #11
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Provokr What kind of sound is it? Does it sound like metal on metal... metal on plastic... random intervals?
Sounds to me like metal on metal and it's almost as if someone was knocking at the door
Vinniety What kind of noise are you talking about? Is it a rubbing sound, a clunk, a whinning sound what does it sound like? Did you ever think maybe the tires can be causing it. Rotate them. Just an idea. It seems you changed more things then probably needed to.
I got new AT tires after the noise started(not because of the noise, I needed new tires), didn't do anything
jtsmith have you checked the transmission mount?
Transmission died at ~200K (yeah I know it's been on the road a lot) had a reman one installed in a pro shop so I would think that it was checked, don't know, just hoping
Joe & Brian don't know how to check those, I'll search here to see what I find about it
Thanks all of you for your replies, I'll keep you posted
Old 01-08-2008, 08:52 PM   #12
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Little update
So most of the time nobody rides in the back seat, today a fried of mine told me that she felt the knocking thru the floorpan but she felt it harder when I turned left, she was seating in the left side, so she switched to the right side and didn't feel it, so based on this new info, any ideas?
Old 01-08-2008, 08:56 PM   #13
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
transfer case banging on truck because of the transmission mount being broke or loose
Don't assume they replaced it. Even if it was replaced it could be broken again, Stuff happens
__________________
Jon
2000 Mountaineer
Old 01-14-2008, 06:39 PM   #14
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
update
Ok so I had an appointment cancelled today so I had nothing to do for a while and decided to check on the truck, took my haynes manual and went outside to check on the sway bar end links, the one on the drivers side was soo loose! I could have unscrewed it with my hand so I tightened it but the bushing is al torn up, I'll be heading to autozone tomorrow and buying a new set, I'll pick up the bushings for the sway bar as well, hopefully this will solve the problem, I'll let you know, as always thanks so much for your help
Old 01-14-2008, 09:09 PM   #15
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
My 01 sport has been rattling for some quite sometime when i am always on idle or at a red light it rattles my explorer I dunno if I got loose ball joints or my flowmasters loose or what.
It sounds annoying after awhile cause when i am with my gf she keeps on telling me it sounds bad.
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 01-15-2008, 12:12 PM   #16
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Haha tune to a radio station she likes and crank the volume
Old 01-15-2008, 12:59 PM   #17
winsorcoke
Cottage Grove, MN
'97 Sport
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Follow your exhaust pipe all the way back. Make sure it's not touching anything. When you take the muffler (I see you have a new one) off, the rear pipe will spin because of the bend on the end. If you don't twist it back up before you clamp the new muffler on, it will rest against the shock! I left while my neighbor welded mine up and he didn't twist it! Wasn't fun grinding a full weld off, but it rattled just you say yours does. Also check all the heat shields along the pipe. They like to rust and rattle.
winsorcoke is offline   Reply With Quote
Old 01-18-2008, 05:22 PM   #18
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Update
Today I took off the front sway bar, noise is still there, I'll get new bushings as I already have it removed I might as well do it now along with the end links, so now we know this isn't the source, next thing to check will be the transmission mount, I have no idea how to check it as I went under the truck and didn't know what to look for, so I'll have it checked by a shop
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
