| Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Atlanta, GA
2004 Explorer Eddie Bauer
Best replacement spark plugs?
I'm at 60K miles on my 2004 EB AWD 4.6 SOHC and I'm going to be going through doing all of the standard maintenance I do at 60K on all of my vehicles. Belt change, Spark plug, spark plug wireset, fluid and filter change. I'm wondering which 'if any' is the most recommended spark plug for this engine? At worst I'll just put original equipment back in but wondering if there is a favored plug that runs well for this engine. I've looked around on the forum but didn't see a post for this though it likely exists somewhere in the wealth of information posted. Any help is sincerely appreciated!
#2 |
Elite In Memoriam
1999 XLT
Seriously doubt that your plugs need to be changed at 60k miles.
I recommend Motorcraft plugs. __________________ Al Franklin My truck My Quest for 30 RIP Al Franklin! 1947-2010. Gone but not forgotten! :( |
#3 |
Humboldt, CA
'97 XLT 4X4
Motorcraft is the Ford OEM part, and is always recomended. I believe Advanced Auto Parts carries Motorcraft?
#4 |
Xterra Forum Member
Clear Spring, MD
2011 Xterra Pro-4X
yeah stick with the Motorcraft, or Autolite (they make motorcraft plugs) don't get sucked into all the gimmik plugs out there that cost more, for the most part they are all junk.
__________________ Rusty... 2001 Mounty 4x4 4.0 SOHC 4.10's 180K miles Current Mods: replacement Engine, TT, Shackle, AAL, Tranny Cooler, Exhaust, Transgo, Air shocks, ATF Temp & PSI ga., Ext Tranny Filter, UD Pulley, E-Fan, BW EPC, Custom Bumper, Body Lift |
#5 |
Oshkosh, WI
2004 Eddie Bauer
I tried the Autolite Iridium plugs in mine and they work fine. Better than the OEM double platinums? Doubtful. They weren't that much more, so I thought I'd give them a whirl.
Ditto on the "gimmick" plugs. Most are worse quality than the OEM Motorcraft/Autolite plugs that were factory installed. Save your money. __________________ Mike 2004 Explorer Eddie Bauer 4.0 SOHC FFV Showroom clean, showroom stock. |
#6 | |
Xterra Forum Member
Clear Spring, MD
2011 Xterra Pro-4X
Quote:
![]() They cost me a fortune, but I figure hey they will last a long time, yeah right in 13K I had to replace them all because the planum fell off 2 plugs and one lost it's conductor what a bunch of junk so back to the standard ford platnums __________________ Rusty... 2001 Mounty 4x4 4.0 SOHC 4.10's 180K miles Current Mods: replacement Engine, TT, Shackle, AAL, Tranny Cooler, Exhaust, Transgo, Air shocks, ATF Temp & PSI ga., Ext Tranny Filter, UD Pulley, E-Fan, BW EPC, Custom Bumper, Body Lift |
#7 |
Oshkosh, WI
2004 Eddie Bauer
Mine were pretty well junk at ~70k. The gaps were over 0.090" on the worst ones. There was no platinum left on them!
#8 |
Elite In Memoriam
1999 XLT
Sounds more like an exception than the rule.
I have seen many 100k plugs that looked almost new and still gapped properly. __________________ Al Franklin My truck My Quest for 30 RIP Al Franklin! 1947-2010. Gone but not forgotten! :( |
#9 |
Slinky+Escalator=Fun
Statesboro, GA
1993 Ford Explorer XLT
i used bosch plugs when i started replacing my own each year... i figure it's pretty cheap, why not? it's tip money from one night...
when i first changed them, it was sputtering/skipping horribly! sounded like it was misfiring and about to die... come to find out, with 250K on the truck, the plugs had only been changed twice... i switched them, and it felt like a whole nother engine had been put in. that's my two cents, but if many people suggest motorcraft, i'd go with them... __________________ "Thunder" Registry R.I.P. 2005-2012 2001 Ford Ranger (New!!) "You can hear me when I'm coming" - Yung Joc |
#10 | |
Oshkosh, WI
2004 Eddie Bauer
Quote:
I too have seen many vehicles that have well exceeded their normal service life of platinum plugs. Best example being my neighbor's '98 Caravan...212,000 miles on the original Champion double platinums! She brought it in for a problem with misfires under load, and of course that's the first place you start. My techs and myself all couldn't believe the thing even ran. There was absolutely no electrode left! The plugs looked like one of those HEI spark testers...Just a hole in the porcelain where the electrode should have been, and about 2/3 of the ground electrode was completely gone! __________________ Mike 2004 Explorer Eddie Bauer 4.0 SOHC FFV Showroom clean, showroom stock. |
#11 |
Elite In Memoriam
1999 XLT
Mike, could your use of E85 fuel shorten the life of the plugs?
#12 |
Lenoir, NC
2002 Limited
I bought my explorer with 82k on it. I am up to 116k now. I am not sure if the plugs have been changed, I have not done it since I have had it. It runs fine. I should probably change them though I guess.
__________________ ![]() 2002 Explorer Limited, V6, 3.73 limited slip 265/75/16s Blacked out trim |
#13 |
Oshkosh, WI
2004 Eddie Bauer
In theory, it should extend the service life of them. E85 burns about 200° cooler, and produces no carbon deposits. It's doubtful that the previous owner (lessee) used E85 in it, since they lived in an area that didn't have an E85 station nearby.
For giggles, I pulled one of my replacement plugs that now has about 25,000 miles on it, and it looked like the day I installed them. __________________ Mike 2004 Explorer Eddie Bauer 4.0 SOHC FFV Showroom clean, showroom stock. |
#14 |
Oshkosh, WI
2004 Eddie Bauer
I'd do them just so you know they've been done. It's an easy and inexpensive job.
#15 |
Lenoir, NC
2002 Limited
I may do it. I have not even looked at it yet. I know a lot of newer cars can be a pain to change plugs on though.
#16 |
Oshkosh, WI
2004 Eddie Bauer
These are quite easy. The 4.0 V6 should take about 30-45 minutes to do all 6. Get a swivel spark plug socket and various length extensions, and it'll go pretty easy.
#17 |
Akron, Ohio
2004 Explorer XLT
Even though it's not recommened till 100k I would still replace them at 60k. I have worked as a Ford mechanic before getting on the fire dept. full time and still work part time as an auto mechanic. I've seen plugs on the 4.6 and 5.4 seize in the holes if left in too long.
#18 | |
Indya
03 XLT
Quote:
#19 |
Oshkosh, WI
2004 Eddie Bauer
It's unlikely on the 4.0, somewhat possible on the 4.6. I've never had it happen on anything I've worked on (yet), but talking to a Ford dealer tech, he recommended squirting some good penetrating oil (such as PB Blaster) down each spark plug hole, putting the coils back on, and driving it for a week or so. Then on removal, turn each one out about 1/8 of a turn, then back in, then 1/4 turn, and back in, and so on till each one is out. Reef on them like a gorilla, and you will break one (usually #8) off in the head.
#20 |
Hermitage and Murfreesboro, TN
1997 Mustang GT
I use NGK's in my 2004 4.6L (same as yours, bought it as a crate motor and swapped it in my 97GT).
Any of these will work: V-Power TR55 3951 .054 gap G-Power TR55GP 3403 .054 gap Laser Platinum PTR5F-11 6579 .054 Iridium IX TR55IX 7164 .054 <--- I use this one, but its in a Mustang GT. ![]() http://www.ngksparkplugs.com/ I also TQ every plug and use a light coating of anti-seize compound on the threads. ![]() http://www.permatex.com/products/aut...ubricant_a.htm __________________ 1997 Mustang GT - aluminum block PI swap from an 04 Explorer - 4R70W to TR3550 swapped and a few bolt ons! Best 1/8 is 8.74@82 and best 1/4 is 13.56@102.94 on stock 245-45-17 Goodyear gatorbacks. Last edited by JohnC76; 01-19-2008 at 09:48 PM. |
| Thread Tools | |
