| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Newark, Ohio
1996 Explorer Eddie Bauer
Bad fuel pressure regulator signs...
I have noticed that everynow and then my explorer has a episode of hard starting. It seems like a cylinder might be loading up and it takes a bit to get it cleared out. Once the motor is running it's a smooth 800 rpm's with no missing what's so ever. I have replaced all plugs and wires. I doubt that it would be a fuel pump due to it's only when starting. Has anybody replaced the FPR? If so what kind of symptoms could I expect with one going bad?
#2 | |
Albany, NY
96 EB V6 OHV 4WD
Quote:
#3 |
Newark, Ohio
Haven't monitored the pressures but I replaced the IACV this past summer. Hope it hasn't died already.
#4 |
Rust? You mean character!
Pittsburgh, PA
'97 XLT SOHC
They normally don't go that fast. Check all your vacuum lines, I'm not sure how your exact fuel system is run but i know on mine there are two vacuum lines that run to my fuel pressure regulator, if those are borken or leaking then that could be a problem.
If thats all fine, id then try and clean your IAC, I try and clean mine monthly. Also, don't throw out that it could be a your PFE sensor for your EGR system. If its bad, it will load the cylinders up full of EGR gas and cause a rough idle. __________________ Adam 4.0 SOHC Modified w/ Magnaflow Exhaust... ![]() '10 Edge Sport ![]() |
#5 |
Old and in the way
Humboldt, Kansas
2000 Mounty
Sometimes the FPR diaphrgm will leak fuel into the vacuum line--check the line for a fuel smell, raw fuel.
#6 |
1991 FORD EXPLORER XLT
i have this problem raw fuel sprays from my vacuum line ,do i need to replace the fpr
#7 |
Reading Pa
2001 Eddie Bauer
Yes
__________________ Resident Ford Tech for the last 17 years, 2001 Eddie Bauer 5.0L, Cherry Bomb Cat back, 2010 Ecoboost Flex |
#8 |
thanks a lot ,so much gas coming out i figured it was a fuel line,
the connector kept popin off the hose i was going to put a clamp on it lol, thank god 4 this site |
| Thread Tools | |
