Serious Vacuum leak | Ford Explorer Forums
Serious Vacuum leak
JSpence
Oak Harbor, WA
1991 Explorer XLT
I have several vacuum lines that are in bad shape. My haynes repair manual doesn't give me any vacuum line layout. Any information and links would be great.
I've not seen vac layout diagrams. Couldn't you replace them one at a time as you take them off and then you wouldn't need a layout? I'd say the only place it may be is in the factory service manuals.
I know I posted this list a while ago. Here's what's on my '92, and your '91 should be similar. You should have vacuum lines going to:
1) Automatic transmission (if equipped).
2) Cruise control (if equipped)
3) brake booster
4) fuel pressure regulator
5) air filter housing
6) vacuum reservoir and HVAC system (1-6 coming off of vacuum tree at rear of intake)
7) PCV valve (separate nipple)
8) EVAP system (likely off of throttle body)
Thanks for the replies it should help a bunch.
