#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
1996 lower ball joint must replace control arm?
Reply
Thread Tools
Old 01-28-2008, 11:52 AM   #1
bgingras
1996 ford explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'm being told that I must replace the entire lower control arm and not just the ball joints on a 1996 explorer sport? is this right? Seems a bit extreme. quoted $1100 for 4 ball joints replaced becuase it was for all 4 control arms?
bgingras is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-28-2008, 11:57 AM   #2
carlover
Fontana,CA
'96 XL
Vehicle Specs
Quoted: 8 Post(s)
You can replace the lower ball joint without replacing the while arm. the upper control arm must be replaced as it is one sealed unit. You can do this while job in your driveway uf you want to save on the labor. Parts shouldnt be more that 350$ for the Moog balljoints and tie rods and such.
__________________
Sean.
BTF built explorer race truck in progress.
http://www.explorerforum.com/forums/...d.php?t=216036
BTF-FABRICATION.COM
carlover is offline   Reply With Quote
Old 01-28-2008, 12:00 PM   #3
bgingras
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks,
even the online "repair guides" on autozone say replace the entire arm...go figure.
Old 01-28-2008, 12:11 PM   #4
carlover
Fontana,CA
'96 XL
Vehicle Specs
Quoted: 8 Post(s)
Ive done this job quite a few times on my explorer. You do need a ball joint press to remove and re-install the lower ball joints. There are a few very good writeups on this board about how to do this job.
http://www.explorerforum.com/forums/...d.php?t=165352
or
http://www.explorerforum.com/forums/...d.php?t=188225
__________________
Sean.
BTF-FABRICATION.COM
Old 07-03-2012, 08:18 AM   #5
doctorkev
Williston, FL
1996
Vehicle Specs
Quoted: 0 Post(s)
The Haynes repair guide says the same thing, but my local Ford dealer parts department carries the ball joints alone
doctorkev is offline   Reply With Quote
Old 07-03-2012, 03:32 PM   #6
markcoronado
Bracey Va.
95 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I have a 95 EB and replaced one of my lower ball joints a few years ago.
I bought the part at Auto Zone or Advance, can't remember which one but they will lend you the ball joint press.
markcoronado is offline   Reply With Quote
Old 07-03-2012, 03:45 PM   #7
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 652 Post(s)
Yeah this is an old thread but I am throwing this into the pot.
I found it easier to replace the whole ( lower) arm.
Look at it this way. New bushings and ball joint pressed in for twice the cost of the joint alone.
The tricky part is releasing the tension on the torsion bars, but believe me doing it this way will save labor hours and get the front end a lot tighter. Your control arm bushings are 16 years old.
Also, since the uppers are also removed, re install using camber adjuster shims. This will allow a better alignment,and, they should not charge any additional labor to install them over the upper ball joint(s) labor charge, as the adjuster kit is basically a different style of mounting bolt for the upper arms.
My .02
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 07-04-2012, 02:28 PM   #8
idoticsoigpa
Springfield, MO
1998 Eddie Bauer V8 AWD
Vehicle Specs
Quoted: 0 Post(s)
I have repair manuals that say that the entire lower control arm has to be replaced, and just looking at the lower ball joints, one would say the same thing. Thing is, it's not true. I have not done it, but I have had the lower ball joints replaced on two different 1998 explorers at a Ford dealer, and they have a method to replace the lower ball joints without replacing the whole control arm. It looks to me like a hole is punched out in the lower control arm and a replacement ball joint is put into the hole.
idoticsoigpa is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
