#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
blinking check engine light
Reply
Thread Tools
Old 01-29-2008, 04:28 PM   #1
beenwrong2002
Dallas,TX
96' Ford Explorer XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
well i've had my fair share of the blinking O/D light, but now I've got a blinking check engine light. A few weeks ago the check engine light came on and I got the codes read at autozone. They said it was something to do with an O2 sensor or the fuel mixture or somethin. But now yesterday the check engine light actually started blinking. I did some searching on here and found most people said it was a misfire of the cylindiers. What are the driving symptoms of a cylinder misfire? What causes the misfire? Could the 02 sensor and/or fuel mixture be related to the possible "misfiring"? I'd appreciate any input/advice/suggestions. Thanks yall for all help and future help. I dont know what I'd do without this site
__________________
96' Ford Explorer 4.0 OHV 4x4 TT, Warrior Shackles, PA853 3" Body Lift with 33x10.5x15 BFG A/T 3.73 Limited Slip MAC Cold Air Intake
Under Drive Pulley On the Way
beenwrong2002 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-30-2008, 02:40 PM   #2
beenwrong2002
Dallas,TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
annnybody?
__________________
Old 01-30-2008, 02:51 PM   #3
Charlie
Wisconsin
1995 F-150
Vehicle Specs
Quoted: 0 Post(s)
Isn't a blinking check engine light an "urgent" problem? I think misfire, too. Are all of your plugs/wires good?
__________________
Link to lift and max tire size info
1996 Sport
2000 XLT
1995 F-150
1987 F-150 XLT "The General"
Charlie is offline   Reply With Quote
Old 01-30-2008, 07:30 PM   #4
AiwaExplorer
AiwaExplorer's Avatar
'99 Sport
Vehicle Specs
Quoted: 0 Post(s)
Yes, Blinking is a problem you should urgently look into.
__________________
99 Sport 2WD- Liberator AT's 31x10.5x15's, TT, Powder Coated Rock Crusher Diff cover, Superchip, Ported TB, Altezza tails, 4 baja off-road lights, Billet Grill, Billet bumper Grill, Aiwa CD deck
Coming soon- 4dr leaf packs, AAL, Shackles, and 3" BL
AiwaExplorer is offline   Reply With Quote
Old 01-30-2008, 07:38 PM   #5
beenwrong2002
Dallas,TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i better get it into the shop then
__________________
Old 01-30-2008, 10:29 PM   #6
btexpress
Thornton, Colorado
2009 Ford Explorer Eddie
Vehicle Specs
Quoted: 0 Post(s)
A flashing CEL is telling you there is a problem that could damage the catalytic converter.
btexpress is offline   Reply With Quote
Old 02-03-2008, 11:47 AM   #7
beenwrong2002
Dallas,TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
ah thanks for the info I have another question, I had a mechanic tell me that a switch on the side of my tranny was causing my fuses to blow for my 4x4 and my reverse lights. I had my tranny rebuilt like 6 months ago at a shop and it has a 1 year warranty. Yall think this warranty for a rebuild would cover this switch thats on the side of the tranny?
__________________
Old 02-04-2008, 08:42 PM   #8
97ford50x
Enola PA
97 5.0 xlt
Vehicle Specs
Quoted: 0 Post(s)
as far as the tranny switch if i was the one that did the rebuild i would cover it but that is the way my shop is run as far as the cel if the code was an o2 code that will some times case it to blink and if it was a miss fire you would know it it woul shake and stumble when you drive it if you getany more info on the cel let us know the more info the better try to get the code numbers they will be like a ( p0123) or some number like that but it should start with a p
__________________
1997 ex with a 5.0 zapv-88 For sale warrior shakels tt 31 inch procomp mud terrain custom snorkel AAL And the plastikote,tinted tails look
4406 installed
97ford50x is offline   Reply With Quote
Old 02-06-2008, 06:57 PM   #9
beenwrong2002
Dallas,TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
ill try to get the code numbers again...is the misfire most noticeable when accelerating?
__________________
Old 02-11-2008, 08:33 PM   #10
97ford50x
Enola PA
97 5.0 xlt
Vehicle Specs
Quoted: 0 Post(s)
did you get any code numbers yet ? and it will be more noticeable when you give it gas
__________________
4406 installed
Old 02-11-2008, 10:21 PM   #11
Xan
B
Lincoln, NE
01, mountaneer
Vehicle Specs
Quoted: 0 Post(s)
you should have really got the code numbers... if you go to auto zone they are most likely to tell you an O2 sensor to sell you one. Most likely they got a rich/lean code, or random/multiple misfire. Yes it could be a O2 sensor that could drop both those codes but theres alot of other cheaper things you could check before just jumping and changing stuff or running off to a mechanic.
Xan is offline   Reply With Quote
Old 02-13-2008, 11:04 PM   #12
beenwrong2002
Dallas,TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I have to get the codes read again, i havent had time lately, but i do think its a misfire cuz i can feel it when i accelerate...
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
