Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Smart Key Programming on replacement Ignition switch
Reply
Thread Tools
Old 02-01-2008, 07:57 PM   #1
whisperer
VAP Man
Bend OR - Hilo HI.
whisperer's Avatar
:) Which one?
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
The ignition switch tumbler assembly is broken in my 98 Explorer sport and I need to replace it. That means the new key that matches the new tumbler will need to be re-programmed. Problem is that the old key will not then go into the new tumbler to do the on-board programming, and I only have one Smart key for the car anyway, the factory manual says I need 2 original Smart keys to do the on-board programming.
How do I get this job done? Is there another way I can get a new lock assembly and matching Smart key synced to my truck?
__________________
90 Ranger 4WD +6", 88 Ranger 2WD V8, 95 Explorer 4WD, 98 Explorer Sport 2WD, 2K Explorer V8 AWD 4D, 67 F100 SW BB Lowered, 72 F250 stock, 86 Bronco FS 4WD, 90 F150 4WD. Oh, and a bunch of cars.....
whisperer is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-01-2008, 08:36 PM   #2
A Wise Guy
McHenry, IL.
'06 Limited Dark Cherry
Vehicle Specs
Quoted: 0 Post(s)
If you do a search, I have not had the time yet, but if I find it I will put it up. I think it was expo 5.0 that did program a key only using 1 key. Now for the tricky part. If you remove your lock cylinder from the steering column the plastic ring that is around the cylinder can now be removed. This is the ring which the chip communicates with. Remove the ring and put the cylinder back in the hole but do not put the pickup ring back on the column yet. You should at this point be able to move the ring away from the new key and cylinder so it does not pick up the new key. Hold the old key at the ring, do the key turns with the new key then when it is time to program the new key hold the ring next to it so the new key is read. Come to think of it you may just be able to turn the ignition switch on and off with a screwdriver when the lock cylinder is out of the column. Hopefuuly this helps.
OK it was black magic who did it. http://www.explorerforum.com/forums/...ad.php?t=68728
__________________
'06 Limited V8 Style
K&N 77 Series Metal Intake, Magnaflow Cat Back, X-Cal 2, Tint up front...
Searching and Posting starts here: http://www.albinoblacksheep.com/flash/posting
A Wise Guy is offline   Reply With Quote
Old 02-01-2008, 10:23 PM   #3
whisperer
VAP Man
Bend OR - Hilo HI.
whisperer's Avatar
:) Which one?
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Good Info
Thanks A Wise Guy. That thread got me moving in the right direction.
From here I think I can get a new lock assembly with the matching PATS key, have a copy of the new PATS key made at the local hardware store (without the chip), use the hardware store key to start the truck taping the original PATS key close on the column. Then I can drive it to the dealer and have them program the new PATS key (that fits the new ignition) and make me a few copies of the now-correct PATS key.
That is all if I can't get the new PATS key to progam with only the one original and turning the gutted ignition with a screwdriver. I will definately try that first.
Is there a way to defeat this whole thing at the module? Can I jump it out there? I think the PATS system is kinda' cool but if I loose the programming in the one key that matches the truck now while trying to get this done I'm going to be in real trouble as the dealer is many miles away. If I had to tow the truck in I can see them just charging me stupid prices.
__________________
Old 02-02-2008, 09:35 AM   #4
A Wise Guy
McHenry, IL.
Vehicle Specs
Quoted: 0 Post(s)
If you remove the Pats pick up ring you can feed it down under yuor dash and away from the ignition switch where you have more room. Then you can pop the cap on the back side of the key, the cap may break, and pull the Pats chip out. It looks like a medicine capsule just smaller. Tape it to the Pats ring and burry it under the dash. Pats always has a chip for the computer, you can now use 99 cent keys and you do not have theft deterent any more.
__________________
Old 02-27-2010, 07:53 AM   #5
brandy2010
arkansas city kansas
2001 ford explorer sport
Vehicle Specs
Quoted: 0 Post(s)
where do i go to have a new key made for my 2001 ford explorer sport trac, i am in the process fo movikng and it has diasppeared
brandy2010 is offline   Reply With Quote
Old 02-27-2010, 07:54 AM   #6
brandy2010
Vehicle Specs
Quoted: 0 Post(s)
i need a key for my 2001 fors explorer sport trac
Old 02-28-2010, 09:48 AM   #7
renegadepig
spokane, wa
90 aerostar/98 explorer
Vehicle Specs
Quoted: 0 Post(s)
Why not have a locksmith re-key a new lock cylindar to the old key?
renegadepig is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
