#1 |
Wannabe Elite Explorer
Montreal
Codes 53,173,212
I just got a 53 code Throttle position sensor over maximum voltage.
173 Oxygen sensor is or was not switching,Fuel control 212 Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems Is it possible that my TPS give me all those codes and replacing it will solve false reading of other units or is it something else? I am not sure of everything because my 53 code it make 1-1-1 and then make the rapid 5 code and then 1-1-1 and then the rapid 3 code. It reapeat it ...wait ...one flash to tell we go in CM code and begin CM code ...but why on koeo codes it give 1-1-1 as engine passed but just after that it give a 53 code ???? |
#2 | |
Spanish Fork, UT
92 XLT and '87 Bronco II
Quote:
__________________ Mr. Shorty 92 XLT 4x4 87 Bronco II XLT 4x4 '98 Chev K1500 Suburban SLT 4x4 |
#3 |
Montreal
i made the test and even filmed it i tryed to post it in the vid section but wont work and even in you tube it wont work but only 2 minutes and 61 megs
| Thread Tools | |
