Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
1997 Full Time AWD V8 Exploerer question. Transfer case.
Reply
Thread Tools
Old 02-06-2008, 08:22 PM   #1
Whiskey
Phoenix
Vehicle Specs
(Original Poster)
Hello all! I need some information about the transfer case in the 1997 AWD V8 Explorer.
A friend had me drive her's today and when I get on the gas, especially at low speeds there is a loud "Poping" sound coming from what I think is the Transfer case.
I've found allot of information about the dis-engageable transfer case for this model, but I am having a ruff time finding any data on even what transfer case is used in the full time 4 wheel drive model.
What transfer case is in this vehicle? (part number?)
Do you have a link so I can see what the inside of this thing looks like?
The only off road this truck see's is gravel spilled into a parking lot,.. is there any reason why I can't simply remove the front drive shaft?
She wants to get a new explorer, but needs this one to last another few months before she can afford the new one. We are looking for a cheap easy solution to limp her by
BTW,.. this would be the second time this transfer case has been replaced in 170K miles,.. last time it cost her 2K.
Thanks for the help!
Whiskey
Whiskey is offline   Reply With Quote
Old 02-06-2008, 08:43 PM   #2
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
The transfer case in the vehicle is the 4404 made by Borg Warner.
I dont think we have any pictures of the 4404 open, but I wouldnt open the transfer case just yet. I mean the problem could be other things like a driveshaft U-joint, or maybe even the axle itself.
You can remove the front driveshaft but not permanently because the vehicle will "creep" if you park the vehicle on any incline w/o the front driveshaft. But you can remove it just for a quick spin around town to narrow it down as to what exactly is making all that noise.
If it is the transfer case, and you only need the vehicle for a few more months, I would gamble and maybe pick up a transfer case from a local junk yard or maybe even Ebay. There are also vendors and other members on the forum (that have switched to the manually shifted 4406 model) that are getting rid of their 4404s.
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 02-06-2008, 08:48 PM   #3
rizzjc
Scubajoe - Radio Mod
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
My front driveshaft, when it went, was gone. Popping was constant, no matter the load. When my transfer case went, it was only under load. I picked one up from ped5stang, a vendor on this forum. It's been running strong for 20k-30k miles now. I have the old case, and hope to get time to open it up and consider trying to fix it some day, hopefully before I need it again. I believe you have to rule out the front half shafts as well though. To figure out it was my tcase, I had someone ride the brake, and hit the gas to make the truck CRAWL up and hill, as I lay on the ground to listen. Just don't stick your head too far under there unless you REALLY trust your driver.
__________________
Joe, N1LVN
'97 XLT AWD V8 STOCK
Amsoil Synthetics throughout. Amsoil Ea air filter. Bilsteins. Scanguage.
Search ExplorerForum
rizzjc is offline   Reply With Quote
Old 02-06-2008, 08:50 PM   #4
Whiskey
Phoenix
Vehicle Specs
(Original Poster)
Thanks for the quick reply!
What do you mean "Creap" when parked on an incline?
I was under the impression that the transmition drove the rear wheels (or rear driveline) in this vehicle directly, and the front tires are driven off a chain setup off the mainshaft. Meaning if you gut the transfer case you still have your rear wheel drive.
Have I been given the wrong information?
Sorry for asking what should be simple questions,.. I normally work on foreign cars and am not fermiliar with how a Ford is setup, or frankly with 4 wheel dive setups in general
I'm going to go see if I can find pics of a Borg Warner 4404 apart from google
Thanks!
Whiskey
Old 02-06-2008, 08:55 PM   #5
Whiskey
Phoenix
Vehicle Specs
(Original Poster)
Quote:
Lol,.. I'm not sure I trust anyone that much
I did do the standard look through,.. drivelines seem tight, CV's don't pop when I'm turned all the way left or right, boots are in great shape, nothing seems loose,.. but there's allot I could miss with a perfunctory look through in a parking lot like this.
If you are easy on the gas it may not pop, or might pop once,.. if you cram on the gas,.... well,.. let's just say I let off in fear of what might break all the way.
Whiskey
Old 02-06-2008, 09:07 PM   #6
rizzjc
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
Whiskey
Yep, that's what my tcase did when it went. If you get a used one, it's a relatively easy 1 day job if you got everything ready. I think I took my time and took 2 days. 4 jack stands and and a floor jack. Center console has to be removed. I just sliced the carpet under the center console to get to the access panel.
__________________
Joe, N1LVN
Old 02-06-2008, 09:18 PM   #7
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
It will creep because of the Viscous Clutch. The transfer case you have is not like most transfer cases out there so the concepts of a typical transfer case dont apply.
No, as stated, this isn't like a typical selectable transfer case.
But dont worry about the innards, you havent even narrowed it down to exactly what is making all that noise.
__________________
Old 02-06-2008, 09:32 PM   #8
Whiskey
Phoenix
Vehicle Specs
(Original Poster)
Cripe,.. Your right,.. there's this little ring gear/clutch assembly between the tranny and rear tires,.. the part that's directally driven is the front tires,.. but that's through a chain. Well this explains exactly why the chain would be skipping then
So the primary drive tires are really the front ones,.. the back ones don't get as much power? Dangit.
Okay,.. well we still have the option of temporarally removing the front drive line to see if the poping goes away,.. if it does we know for sure the problem is somewhere in the front end or tranfer case.
If not then I want to think transmition (shudder)
I think I can rule out the front diff right away,.. does anyone disagree? Remember this thing is babied by it's normal driver,.. think "Driving Ms. Daisey" babied,.. I don't think she's ever had it past 1/2 throttle.
So that leaves front driveline,.. which I can make a point of inspecting when it's off the vehicle, and the front CV's.
But I want to rule them out two,.. because when this thing skips it jerks the car hard,... like a gear slipping teeth.
Thanks!
Whiskey
Old 02-06-2008, 09:40 PM   #9
Whiskey
Phoenix
Vehicle Specs
(Original Poster)
This is a link to the page I'm looking at, may come in handy for someone at one point:
http://www.rsgear.com/transfer.asp
Off to the right there are exploded diagrams,.. click on the one for the 4404
Whiskey
Old 02-06-2008, 09:56 PM   #10
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
Good find
__________________
Old 02-06-2008, 10:00 PM   #11
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
The split on the 4404 is 40/60 front/rear. I'll bet your driveshaft is bad, they are usually the first things that fail. I'd pull it and see what it does, but do set the parking brake, it will roll.
Another thing to check would be the front differential, remove the drive shaft and check for play in the pinion.
The T-case swap is relatively simple, I did my 4406 in a conversion in one afternoon, I wouldn't spend 2k on another case swap. SYM and do it yourself. Heck, if you will drive to me, I'll do it for 1k and provide the case.
MountaineerGreen is offline   Reply With Quote
Old 02-06-2008, 10:04 PM   #12
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Very good find-
remove the front drive shaft-and pull the cv joint area away from the shaft.
If the rubber is torn at all ( you need to remove the driveshaft to see it) there is your bang bang hell.
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
