#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
overly sensitive front brakes
Reply
Thread Tools
Old 02-09-2008, 10:52 PM   #1
steve53
wasilla, ak
93 xl 5sp
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi there. I have a 1993 xl and my front brakes have all of a sudden become overly sensitive. Not that they cry easily but when I barely touch them on snow or ice, the anti-lock motor kicks in, whereas before I used to be able to apply normal pressure on the pedal without the anti lock operating. I am wondering if the master cylinder could be bad or the anti-lock assembly? I searched the frame for a proportioning valve but could find none. Does the anti-lock assembly act as a proportioning valve? Brake pedal feels normal and I have not messed around with the brakes lately. Just curious if anyone else has had the same problem and come up with a solution. Thanks.
Steve
steve53 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-09-2008, 11:23 PM   #2
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 289 Post(s)
...pull the front wheels and check for dirt/debris around the sensors...
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 02-09-2008, 11:26 PM   #3
fordnut71
oshawa, ontario. home 2 goverment motors canada
99 ex sport
Vehicle Specs
Quoted: 0 Post(s)
it would be your master going.the abs is the proportioning valve.
when you change the master do a bench bleed 1st before you install it.
bleeding the abs is a major pita. just takes forever to get the air out.
fordnut71 is offline   Reply With Quote
Old 02-09-2008, 11:39 PM   #4
steve53
wasilla, ak
93 xl 5sp
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the advice. I will check out the wheel sensors. If that doesn't do it I will replace the master. Thanks.
Steve
Old 02-09-2008, 11:43 PM   #5
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Spraying brake cleaner over the ABS sensors, and everything else in that location should do the trick.
BrooklynBay is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
