Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
'99 XLT 4.0 SOHC won't crank
Reply
Thread Tools
Old 02-24-2008, 08:46 PM   #1
Godzilla
Wonder Lake, IL
'99 XLT
Vehicle Specs
(Original Poster)
Unhappy '99 XLT 4.0 SOHC won't crank
When attempting to start my '99 XLT with 152K miles, there is one click and nothing else happens. No dimming of lights and all other electrical functions are normal. Last time I had this problem, the terminal on the trigger wire from the ignition to the on-starter solenoid had snapped. I crimped a new terminal on the wire and this solved the problem. I recently replaced the starter and had the battery and starter tested twice as well as the alternator. I have checked the relays and fuses as well as the both battery cables (0 ohms resistance) as well as the solenoid trigger wire. I am inclined to think the ignition switch could be bad but am reluctant to tear into that as it involves removing the steering wheel. I have also heard that the neutral safety switch can fail as well. Any suggestions on where to go from here would be greatly appreciated!
Godzilla is offline   Reply With Quote
Old 02-28-2008, 12:20 PM   #2
Godzilla
Wonder Lake, IL
'99 XLT
Vehicle Specs
(Original Poster)
Replaced the ignition switch (PITA), still won't crank. Neutral safety switch is next.
Old 02-28-2008, 03:13 PM   #3
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Quote:
What about the fender mounted starter relay?
96eb96 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
