Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Project X = Window Repair
Reply
Thread Tools
Old 03-02-2008, 01:52 AM   #1
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...i repaired 2 front windows in 2 1/2 hours thanks to this great writeup which has lots of info and pics...any questions please check that link first...
http://www.explorerforum.com/forums/...d.php?t=145469
...since i got my X i had to always pull the drivers window up to get it to close...friday, my passenger side stops working and this morning it rained...needless to say, my spotter harley got bent out of shape so this needed to be adressed a.s.a.p....
...after pulling the front panel (drivers side) and the front speaker you will see 2 of the holes and on mine the screws were 5/16 heads...
....you need to drill the dimple out with a 1/2" bit but since mine was packed up i had to use a 1/4" and i got a little creative......
...after getting the 3 screws out, unplugging the window motor and pulling it out, there was one rivet left on the cover...i pulled it straight back so it would go over the gear and be able to spin around so you could easily work on it...
...i then pulled the c-clip out and then the metal gear...if you will look close you can see the c-clip, it is pulled out but viewable...
...i then used a flat head screwdriver to dig the remnents out of all the nooks and crannies...(for surfers it's like digging out dr zogg's sex wax and for boarder's, it's like digging out p-tex)
...be sure to get the remnents out of the big plastic gear too...
...i installed the dorman's help pack (see below),window regulator gear plugs, greased her back up, closed the lid, and re-installed...
...the help pack was #74410 and it worked perfect as stated in the other thread...
autozone - by me did not carry it
pepboy's- 12.99
kragen-11.99
...now my spotter is happy again and so am i...
...I still need help finding the writeup for the rear window fix as mine has the cables, thanks
..Here is the fix for rear window's with cables...
http://www.explorerforum.com/forums/...ghlight=window
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-02-2008, 01:58 PM   #2
Jack Flash
Ethel, MS
(3) '88 BII's, '99 Ranger
Vehicle Specs
Quoted: 2 Post(s)
this thread/post shows the rear windows...
...jjf
__________________
Jack of All Trades
Retired From Most
www.internationalcuemakers.com
www.jimboarmy.com
Latest Project: '86 Ranger 4X4
Jack Flash is offline   Reply With Quote
Old 03-02-2008, 02:59 PM   #3
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...it's the one i followed but i can't find any info on the cable install...
EDIT...found it here starting at post #64...
http://www.explorerforum.com/forums/...=145469&page=4
__________________
Old 03-09-2008, 08:15 PM   #4
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
I did mine about 2 mons ago but I bought the kit off ebay for 10bucks. The rear motor unbolts then pulls off the cable
__________________
91 Eddie
Bunch 'O' Mods- 35's, winch, gears, blah blah
www.southernxplorer.com
91exploreron37 is offline   Reply With Quote
Old 03-09-2008, 08:17 PM   #5
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Whoops
__________________
91 Eddie
Old 03-29-2008, 03:33 PM   #6
SHARK X
Yosemite
92 XLT 4WD
Vehicle Specs
Quoted: 2 Post(s)
source for window track/sashes?
What a great diy! just when I was about to through in the towel on my Xplorer.
2 windows in 2 weeks
Question, my driver window has jumped track, and the outside rubber has deformed. I suppose its cause the gear bushings are trashed Gonna need a new track to keep the wind noise and get a good seal around the door. Wanted to find out where to buy a new track, any ideas?
SHARK X is offline   Reply With Quote
Old 03-29-2008, 08:02 PM   #7
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...you can try the local junk yard, or contact kbabiak who is a member here and he is on the bottom of the forums page, or http://lmctruck.com ...
__________________
Old 01-05-2009, 02:18 PM   #8
Robrt32
Sledge Mississippi
94 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks guys for this write up... NO windows work on my Sploder.. I have fixed both of the passenger side windows today. I'm gonna do the drivers side back next.. The window in the drivers side door is off the track and has a 2x4 holding the window up.. I suspect its gonna be a little more to that one...
Robrt32 is offline   Reply With Quote
Old 01-05-2009, 03:31 PM   #9
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...Your welcome and Good luck on the rear window...Mine has the cable system and I haven't fixed the rear window yet...My 2x4 is still doing good though...
__________________
Old 06-29-2009, 03:23 PM   #10
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...I finally fixed the rear cable window on my X...The write up can be found here...
http://www.explorerforum.com/forums/...d.php?t=248065
__________________
Old 04-28-2011, 06:17 PM   #11
BigRed22
Wichita, KS
1991 XL
Vehicle Specs
Quoted: 0 Post(s)
Thanks a lot. Im not a car guy but this made it very easy!
BigRed22 is offline   Reply With Quote
Old 04-28-2011, 10:03 PM   #12
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
..I'm glad to be of some help..
..My windows are still working fine and they pretty much get daily use...It's getting summertime and it's great to have all the windows in working order..
__________________
Old 04-29-2011, 11:58 AM   #13
Wade99
Palm Harbor, FL
99
Vehicle Specs
Quoted: 0 Post(s)
Had to do this on my 87 Stang as well. It's kind of a pain getting it back together with three brand new pieces but can be done. I have to do both front windows on my 99 Exploder.
Wade99 is offline   Reply With Quote
Old 04-29-2011, 07:58 PM   #14
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...My trick was to fit all 3 pieces in at once and then sandwich the unit closed..
..I did first try to put them in one at a time and it wouldn't work that way.. Went together real easy after I figured they would only work without damage if they all went in together..
__________________
Old 07-23-2011, 09:27 PM   #15
Old Hippie
Spartanburg, SC
93 XLT 4x4
Vehicle Specs
Quoted: 1 Post(s)
pepboy's- 12.99
kragen-11.99
OUCH! Those Chinese like driving automobiles! Where's Chiang Kai-shek when we need him?
Dorman Help! Window Regulators Gear Plugs #74410 O'Reilly auto parts - $7.99
Old Hippie is offline   Reply With Quote
Old 04-17-2013, 09:38 PM   #16
smegun
florida
1994 ford explorer xlt
Vehicle Specs
Quoted: 11 Post(s)
when you get the three screws out just pull on the back of the motor where the two cables are. it will just pull off and allow you to get the motor out. The cables are attached to a female gear that plugs into the metal gear on the window motor. When you put the motor back in you will have to line up the metal gear on the window motor to the one attached to the cables. Not too hard, just a little time consuming.(Trust me, the second one will be easier than the first) The three screws that you take out also hold the female gear in place on the metal gear of the window motor, so make sure that those line up as well. Hope this helps
smegun is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
