Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
stalling
Reply
Thread Tools
Old 11-01-2000, 08:38 AM   #1
Cw2185
Vehicle Specs
(Original Poster)
Hi there,
I have a 94 Explorer, V6, 5 speed manual, 125,000. I have an intermittent stalling problem. The engine will cut out for about 5 to 10 seconds - with the manual trans. it will jump start if I'm at highway speeds. The engine always restarts after about 10 seconds. I have had it to my local shop twice. No codes and the check engine light does not come on. I may not have any problem for a couple weeks and then it could stall as much as 10 or 12 times in one day. It does this under any driving conditions. My local shop told me to take it to a dealer. Other than this problem my Explorer runs perfect although I do here some possible carbon ping.
Thanks
Charlie
Cw2185 is offline   Reply With Quote
Old 11-02-2000, 01:42 PM   #2
TPLYNCH
Brewster, NY
1999 XLS
Vehicle Specs
Welcome to the site. Here goes..... Fuel filter - if not changed in a while, do it. Can clog, causing stalling. Fuel Pump - If that's going bad, need to remove gas tank to replace. There is also a relay that goes bad as well I believe... Try searching for Fuel Pump for more info.
__________________
Tom Lynch
'99 XLS
4 wonderful very used (80K miles) but still like new Michelin XC LT4 tires
"Forget world peace. Visualize using your turn signal."
TPLYNCH is offline   Reply With Quote
Old 11-02-2000, 05:11 PM   #3
SteveVB
Gaithersburg, Maryland
SteveVB's Avatar
04 Rubicon w/stuff
Vehicle Specs
Check the TB and the IAC. also check your vacuum hoses. I am assuming the stall happens on coat or when you are comming to a stop.
The TB and the IAC may be dirty, or the IAC valve may be malfunctioning.
TB= throttle body
IAC= idle air control - the canister looking thing to the right of the TB
__________________
Steve VB
04 Rubicon
SteveVB is offline   Reply With Quote
Old 11-04-2000, 12:26 AM   #4
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
depends....
I think I'm with both of the above... if it does it at idle/when coasting, it's probably the IAC failing to maintain the idle speed. Can of carb cleaner and 1/2 hr and it'll be as good as new. If it's happening on the freeway at speed, I would DEFINATELY suspect the fuel system is starving the engine. Start with the filter (cheap and quick) then move to the pump (expensive and RoPITA!!!). Let us know what you find.
-Joe-
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will — we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
96 XLT stalling Fender5 Under the Hood 4 03-15-2004 08:33 AM
Win98 Stalling espnfreak Exploring Computers!! 25 12-24-2001 11:28 PM
94 4.0L stalling Loopster Under the Hood 4 12-12-2001 06:27 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
