| Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum |
Thread Tools |
#1 |
Wannabe Elite Explorer
Montreal
Twin I-beam infos needed
I am about to check the alignment on my 1992 X because the front wheels have WAYYYYYY too much negative camber. I wont adjust it myself but i wanted to check suspension component to know if its the adjuster sleeve or bushings. In Haynes book they are telling that on 4X4 model like mine with Twin I-beam if the bushing from i-beam to crossmember is worn then it will give too much negative camber. But haynes is haynes and they dont even show pics of this bushing. Can anyone post a picture here of this bushing and where its located on the truck please. You could also send it to my email X_1980_X@hotmail.com
Thank you |
#2 |
NEX Vice President
Brockton, MA
'93 XLT 4x4
They are referring to Axle pivot bushings. They are located at the very end of each Beam. The Left beam's axle pivot bushing is shown below.
__________________ John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck* 4x4 Trouble Shooting Guide See how cars work Axle and tire calculators U-joint replacement info/pics |
#3 |
Montreal
Do you mean the small round red bushing in the left middle or the crossmember? Also why theycall it Twin i-beam?? i mean theres always 2 i-beam even on the 2X4 model...
#4 |
NEX Vice President
Brockton, MA
'93 XLT 4x4
The Axle pivot bolt and bushing location are marked in RED. Its called a TTB (Twin Traction Beam) Because there are 2 beams instead of a (solid axle).
#5 |
Montreal
Really thank you ....So if theres slack in this pivot the two pivot will make more angle and then make too much negative camber if i understand well ??? They are talking that this bushing must be installed with a press...do you think that i can only drill or burn it out and reinstall the new one with a C-thing....i tell c-thing because i dont know the real name of the tool heheh but its normally red ..in C and you use it to manualle press buchings
#6 | |
NEX Vice President
Brockton, MA
'93 XLT 4x4
| Thread Tools | |
