| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Aiken, SC
99` XLT
The other day i was trying to reverse and the reverse suddenly stopped working . The vehicle has 129,000 miles on it and has been properly maintained. The drive works PERFECT, but no reverse. It almost feels as though the reverse is in neutral or something. The RPM`s go up, but the tires don`t move. The first thing i did is fluid change, then cable adjustment, and finally range sensor for transmission. None of the above corrective actions worked. The only bit of information I have is when it went out I gassed it a little hard then almost felt as if I hit something. So I am thinking valve body, solenoid, or possible spring or something. I dont`t think transmission needs to be replaced because it runs too good in drive. As a matter of fact i did a cross country drive from el paso,TX to Aiken, SC a week ago(1700 miles). If anyone can help I would greatly appreciate.
#2 |
Anchorage, Alaska
98 5.0L V8 AWD XLT
Common problem with the SOHC trannies.. your reverse band is toast.. time for a re-build and it's not going to be cheap.. Sorry to be blunt but it happens.
__________________ Lifted 98 302 Ford: Fixed Or Repaired Daily. But still going, kicking and screaming all the way. =D Yeaaah. |
#3 |
Aiken, SC
99` XLT
ok thanks alot for the reply. Is there any way that I can maually replace the reverse band?
#4 |
Anchorage, Alaska
98 5.0L V8 AWD XLT
It's inside the transmission.. and they're far from simple devices IMO...
#5 | |
ny
1998 ford explorer xlt
Quote:
#6 |
Flunked daycare
outside shovelling snow
................ 96 XLT ™
My 96 did the same thing when my parent's owned it, although the transfer case was the problem...
__________________ Kent - 1996 XLT - Hypertech Programmer, Gibson Catback, K&N FIPK, Alpine V12 MRV-100M, 8" round 2ohm Kicker Solobaric
1992 Toyota Paseo - Tein Super Street coilovers, Whiteline swaybars 22MM(F) 20MM(R), Prothane endlinks & mounts, VVR poly control arm bushings, K&N drop-in, Dynomax Ultraflo, Gibson stainless tip, Pirelli Winter Carving Edge(F) Kumho HP4 716(R) on steelies |
#7 |
Anchorage, Alaska
98 5.0L V8 AWD XLT
Bea, there's many other threads that are about this.. search for them, you may be able to find the information you need.
#8 |
Central NJ
99 Sport
Mine did this too and it was indeed the reverse band. Had to have the entire transmission rebuilt.
#9 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! It could be a broken shift fork in the transfer case.
#10 |
Will County , Illinois
99 4 door SOHC 4x4
Dont know how a transfer case cant do this....but. Usually it is reverse band or reverse high clutch. But if High works then broken band, Band is about the first thing you put in the bottom of the case on rebuild. I have not seen the reverse band break but if it is you can drop pan and pull the four bolts off the small thick cover toward back of valve body and remove piston and spring. If band is broken you should be able to push up through the piston pin hole and have no resistance. If not broken it should have spring tension. Good luck
__________________ 93 F350 Crew cab 351 E4OD
#11 |
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
A t-case can cause the same symptoms, but there's generally others... Like a grinding noise on coast-down from freeway speeds. Eventually when the shift fork/rail fails, the gears get forced apart when in reverse, but mesh and engage in drive. It's an oh-so-common problem.
Wouldn't a busted reverse band cause a loss of one of the forward gears too? -Joe __________________ -98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress! -'00 F-150, mucho mods "We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz We must believe in free will — we have no choice. ~ Isaac Bashevis Singer I'm not smart, just a resourceful idiot. ~ Me |
#12 |
Brooklyn, NY
The reverse band is also for low (1st) gear. It's called the low/reverse band.
#13 |
va
99, sport w/35" MTZ's
if you do not have engine braking in low 1 then it is the reverse band. Put the explorer in 1 and drive to run the rpms up, let off the gas. if the engine does not maintain the current rpm it is more than likely the band. Typically if it is broke the engine will fall back to idle. Of course it is at the back of the tranny so there is no simple fix.
I just went through this last fall |
#14 |
Danville, Pennsylvania
1999 Sport
the same thing happened to my 1999 exploder sport with the sohc motor. Wen i took it to a friends shop to get it checked he told me tat my reverse band had snapped. He said it is a common problem in the second gens but it wasn't that bad of a fix. I don't know how much it is gonna cost you but i got my reverse band fixed and my transmission completely rebuilt by ford certified mechanics who work directly for the ford dealership here near Danville. Good luck with your problem.
#15 |
'03 Explorer XLT
My explorer has the exact problem you described above. Just happened yesterday and I was wondering how much would this cost? I've been trying to get a good quote but the mechanics in my area are far from trustworthy
#16 |
russellville, ar
1998 sport 4x4
Mine's doing the same thing for the 2nd time.
1998 SOHC, 4x4 I got quotes of $600.00 from 2 different places to repair it |
#17 |
Long Island, NY
'01 EB AWD 5.0
Wow... the 5r55e really is the worst transmission ever made...
__________________ 2001 Explorer Eddie Bauer 5.0 AWD - Custom Cat-Back, CAI, Ceramic Pads, LED Puddle Lamps, Sony MEX-BT3000P, Infinity 1060W sub, Boston Acoustics GT275 amp |
#18 |
Brooklyn, NY
I wouldn't go that far.
#19 |
Long Island, NY
'01 EB AWD 5.0
I meant to say as far as Explorers are concerned
#20 |
Brooklyn, NY
The internal parts are more upgraded than the A4LD. The Frankentranny is a combination of A4LD, and 5R55E parts which make it stronger.
| Thread Tools | |
