| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Bridgeport,Ct
'98 Explorer 4X4
Driver Side door lock?
Well as it seems that every so often when i go to open my driver side door with the key, i get resistance and have to play with the key a lil bit or often times i can turn the key torwards the front of the truck and back twice which then opens all the doors. but i cant for the life of me get the key to turn torwards the back of the truck to just open my driver side door. and this is becoming a pain cause it wouldnt open at all the last time it rained and i got drenched.
seems to me it only does this every so often though cause just this morning it worked fine then it wouldnt after i came out of the store.....ggggrrrrrrrrrr this is aggravating is there anything i can do to fix this or is this a common problem? also i got the truck with only one key so i cant try a different one. |
#2 |
moline il
98 AWD v8 Limited
replace the latch assembly...it fixed mine..there is a post on here with instructions on doing it took me about 45min the first time...Good lUck
#3 |
Bridgeport,Ct
'98 Explorer 4X4
is there any other way to fix this without having to change the latch assembly? i dont have the money right now to get a new one, or even a used one at that.
#4 |
Edmonton, AB, Canada
Explorer 97XL
wd40
-mc |
#5 |
Glendale, AZ
1998 Explorer 4.0 4x4
try that idea first ^^^^^ might be that easy
i had a similar problem where i had to jiggle the handle to open the door with the key, but the power locks worked fine. turns out a spring in the latch assemby gave out. to check if this is your problem, open the passenger side front door. put the key in the door. now with the door open, look at the moving parts carefully. you can see a spring in there. check if the drivers door has this spring intact. i bought a pack of various sized springs for about $4. Using the passeneger door assemby as a working guide, i found a near match spring and installed it. works fine now. __________________ 1998 Xplorer 4.0 OHV 4x4, 3.73 L/S, 31x10.5 Good Year Silent Armor A/T, All Synthetic Fluids, Sony Audio System, Yakima Roof Rack w/ 3rd Crossbar, Bilstein Shocks, Silverstar Ultras, Clifford Alarm & Keyless Entry, Throttle Cable Mod, Moog Front End |
#6 |
Bridgeport,Ct
'98 Explorer 4X4
hey guys thanks for the post . i tried WD-40 and it worked good for a day or two then the same thing, so i was reading up and decided to try graphite lube as it doesn't dry up supposedly and now it works like a charm
| Thread Tools | |
