Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Growling, grinding noise from front end
Reply
Thread Tools
Old 03-20-2008, 08:02 PM   #1
1998explodersprt
CA
98 explorer sport 2wd
Vehicle Specs
(Original Poster)
vehicle: 1998 ford explorer sport, 5spd, 2wd
problem: i have a noise from the front end of the vehicle. it is sounds like a grinding-ish growling type of sound
when: i have a slight growling noise that is there when im driving straight ahead. when i turn left or right, the growling/grinding noise gets much worse.
what ive done:i figured, "well duh, its the wheel bearings, time to replace them". so i bought brand new timken bearings (2 inners and 2 outers with races) new cotter pins, and valvoline "ford" wheel bearing grease. removed old bearings and races, but the old bearings looked just fine, no scoring no blueing, no nothing. i said, "eh, maybe i just cant see it with my eyes". put the news ones in, followed fords wheel bearing torquing procedure, but instead of using an in/lb wrench which i dont have access too (only 2 snap-on lb/ft wrenches) i just used my feeling and made sure there wasnt any play but the wheels spun freely with no noises. the symptoms CONTINUED. i remember having the tires replaced way back at walmart all the way around, and when i drove it home on turns i noticed some noise. not a lot though (i think, i dont quite remember) and certainly not as much as it is now, or i would of taken it back right away. when the car is jacked up, there is no play when rotating the wheels, or any growling, grinding, binding.
could tires cause a noise like this?
1998explodersprt is offline   Reply With Quote
Old 03-21-2008, 08:49 AM   #2
rizzjc
Scubajoe - Radio Mod
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
Welcome aboard!
Since you replaced wheel bearings, I am sure this is a stupid question, but did you check the brake rotors? A bad caliper comes to mind. I'm sure you woulda noticed that though.
__________________
Joe, N1LVN
'97 XLT AWD V8 STOCK
Amsoil Synthetics throughout. Amsoil Ea air filter. Bilsteins. Scanguage.
Search ExplorerForum
rizzjc is offline   Reply With Quote
Old 03-21-2008, 02:17 PM   #3
1998explodersprt
CA
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by rizzjc View Post
Welcome aboard!
thank you! i appreciate the response as well.
yup, in fact i did check the rotors, pads, etc. now that im thinking about it though i dont think a grinding sound is the best way to describe is as i would assume people are imagining metal to metal. its not quite like that. i think a growling or groaning is much more accurate. when i turn i can feel it in the steering wheel a little bit as well as my floorboard. its not shaking but there is a slight vibration which is noticible and the cabin of the explorer fills with the growling sound.
when im on the freeway going about 70, and straight the noise is much quieter, and it doesnt sound like much of a groan. but when im exiting onto an off ramp, at about 45-50 is when it gets louder (still going straight), 25-35 id say its the loudest (loud groan that disappears as speed increases when going straight, and just a loud ass groan when making a left or right) and at 5 or so you cant even notice it, EVEN if im turning left or right.
Old 03-21-2008, 03:05 PM   #4
rizzjc
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
I'm stumped!
__________________
Joe, N1LVN
Old 03-21-2008, 05:13 PM   #5
millerman23
Shawano WI
99 XLT
Vehicle Specs
Tires??
__________________
99' Silver 4dr 4.0 sohc "x" 31X10.5R15 Mud Terrains, BWM, upgraded tunes.
No one ever said that life is easy.
millerman23 is offline   Reply With Quote
Old 03-22-2008, 02:53 AM   #6
ignoreme
CA
98 Explorer Sport OHV
Vehicle Specs
ignoreme is offline   Reply With Quote
Old 03-22-2008, 11:36 AM   #7
1998explodersprt
CA
Vehicle Specs
(Original Poster)
well yes, thats one thing i thought about.
i tried deflating them a bit as well to see if the noise would change, so that i could kind of narrow it down to them, but no dice. its just really weird to me that tires could make this type of noise. maybe ill deflate them even more, or just do a tire rotation tomorrow.
Old 03-22-2008, 01:22 PM   #8
steventadams
New Jersey
2001 Sport
Vehicle Specs
Is it like a rumble kind of noise or is it a like metal-on-metal grinding? I had a rumbling noise coming from my front end that I assumed was a wheel bearing and had planned to replace over the summer when I got home from college. Got new tires because mine were dangerously bald and the noise disappeared...
__________________
-Steve
2001 Explorer Sport 4x4, Silver.
steventadams is offline   Reply With Quote
Old 03-22-2008, 03:16 PM   #9
daffy
Ex-Wannabe
Peoria, Il
daffy's Avatar
'00 EB 4x4 4.0 SOHC
Vehicle Specs
When mine did that, it was tires, it was nearly deafening when I was on new, fresh pavement going 35-40mph. Got new tires, I can now hear myself breathe while driving the same stretch of road.
daffy is offline   Reply With Quote
Old 03-22-2008, 04:37 PM   #10
1998explodersprt
CA
Vehicle Specs
(Original Poster)
Quote:
yea a rumble is a accurate way of describing it as well. its not quite like a metal to metal grinding but if you use you're imagination it could be close but only when i at a quick speed, the sharper the turn the louder the noise. the thing is though mine arent bald, infact they are still in what i would call, perfect shape. i got them replaced because the old ones were screwed. the tread is perfect on them in my honest opinion. did yours get louder when you made turns? btw, these are goodyears, if that makes any difference.
daffy: cool thanks man. i have to wait for a buddy to get off work and i'll ask him if i can use his jack to swap my tires from front to rear. hopefully the noise changes so that i can narrow it down to it being the tires. thanks for all the suggestions guys.
Old 03-23-2008, 03:35 AM   #11
Mud_Bone
Sioux Falls, SD
2000 XLS, 97 XLT, 95 XLT
Vehicle Specs
Check the tires for any "cupping" or uneven wear, especially on the inside of the tread, by running your hand around the top of the tread in one direction, then back the opposite direction. It should feel even and about the same in both directions.
If the tires are cupped, rotating them to the rear may only change where the sound is coming from but they will still make noise.
Wouldn't be the power steering pump growling would it? Just a thought....
__________________
'00 XLS "wife's weapon of choice"
'97 XLT 5.0 AWD "spare"
'95 XLT crap green work beater aka "Kermit"
'96 Mustang GT "The Toy"
Mud_Bone is offline   Reply With Quote
Old 03-23-2008, 06:37 AM   #12
millerman23
Shawano WI
99 XLT
Vehicle Specs
I just talked to a guy a little while ago about your problem. could it be that one of your cv shafts is wearing out like all the grease is gone?
__________________
Old 03-23-2008, 04:27 PM   #13
1998explodersprt
CA
Vehicle Specs
(Original Poster)
will check the tires. i havent been able to get it as of yet (swapping the tires) .i hear you on the noise just moving to the back, but at least this way i know its not a big deal. currently im a little nervous that it isnt something more dangerous.
as for the power steering pump noise, im gonna have to say negative on that one. although i dont know exaclty what a bad steering pump sounds like, if im at a standstill, turning a full turn from lock to lock only results in that standard ford steering pump sound, like Chewbacca from star wars that i have become accustomed to since i was a child riding in my dads aerostar
millerman23: i dont think it is my CV shafts...because this generation 2wd explorer doesnt have any. your buddy probably assumed i owned a REAL explorer (4wd), but unfortunatley i own the soccer mom version lol
Old 03-23-2008, 04:59 PM   #14
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
'04 Jeep Grand Cherokee
Vehicle Specs
http://www.explorerforum.com/forums/...+bearing+noise
Still having problems with the same thing... haven't figured it out either, I'm guessing its CV's as I've replaced my wheel bearings, pulled the drive shaft and it did it before/after I swapped diff's
Oh, and I replaced the driver's side caliper and flexible brake hose because it was hanging up.
So I'm not sure what to tell you about yours doing it and its a 2WD truck
__________________
Brett
I get payed to sell and play with Cummins engines
My old '98 MTNR - 5.0 V8 4x4 My old '99 Sport
Hokie is offline   Reply With Quote
Old 03-23-2008, 09:37 PM   #15
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
OK Here we go... I have this same problem and I'll tell you what I know so far..
Does it sounds like about one revolution of grinding woosh per every 50 ft or so you drive ?
My problem started about a year ago , I have 2 exes so I hardly drive the grinding one.. at first I tought the same thing , its the wheel bearing but I changed the wheel bearings over from my 96 which were new and the sound didn't go away.
Weeks went by , after almost buying a new CV shaft I decided to take both apart and switch
them around, still no results , even with the 96 shaft in the 2000 the grinding was still the same or worse.. I noticed my CV boot was torn and I tought for sure this was the problem, but again the 2000 shaft that I changed the boot on is running silent in my 96..
So final analysis , its gotta be the damn bearing on the other side of the shaft.
I came to this conclusion just recently , my noise was always coming from the pass side but recently after driving it for a month I can no hear it from the driver side as well so its gotta be something that exists on both sides..
I called the dealer , $250 or so.. I will pull one from the junkyard and expirement this week.
Looks like a pain in the ass job , its like doing the brakes, joints, bearings, shaft and more all in one day..
PS: It is not your tires. if you pulled out of wal mart and it got louder it is because you bought a cheaper tire , it is normal for new cheaper tires to make noise.. trust me this is not tires..
__________________
'96 XLT 4DR <<< RETIRED
'00 Sport 2DR
Signature modified by Moderator
G-96XLT is offline   Reply With Quote
Old 03-24-2008, 01:16 AM   #16
1998explodersprt
CA
Vehicle Specs
(Original Poster)
i will be reading through that right now and will edit this post afterwards.
the revolution noise is not as you describe. its pretty much a constant sounds and just gets worse when turning. there isnt any "rotational" noise, its just a rumbling sound. as for the tire comment, well there was absolutely no noise that i remember of before i got to walmart (going off my shitty memory though ha). when i drove out i remember there being noise (i just dont remember if it was this loud or not) and i THINK it got worse over time. i remember hearing noise from them and thought "oh well its just because my old ones were bald as hell so its probably just the new tread and how it actually grips the road now" lol. im sure if it was this loud i would of went right back.
Old 03-24-2008, 11:37 AM   #17
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
Mine gets louder with vehicle speed and changes tone when turning... which is why I was guessing CV's
Mine seems to be coming from the driver's side, I know the bearings are good but I'm almost tempted to put a new bearing in it and a new cv... I don't want to start throwing parts at it but I'm getting tired of dealing with it.
__________________
Brett
Old 03-24-2008, 12:23 PM   #18
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Guys its gotta be the inner bearing... There is nothing left in there. Think about , it does't make a noise when you steer standing in one spot and it doesn't make a noise when the engine is just running so there is nothing there left there but the moving parts which are the axle and bearings.
I changed both bearing and CV , absolutely no difference , infact those parts when put back in my older 96 are dead silent so I know for sure it wasn't the CV or the hub and bearing.. What is left that rotates when you move ? the inner bearing
I'm sure everyones sound will be different , I have a sport so it wont sound like the 4dr , also the extent of the damage will determine the sound. Like I was saying I first heard it from the pass side and then 9 months later from both sides..
And it seems to be a problem after 98 , my 96 has 300,000km and its silent. The 00 has 200, and it growls like hell
__________________
'00 Sport 2DR
Old 03-24-2008, 12:27 PM   #19
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
hokie , read my post about the CV , its not the CV, my boot was busted , there was no grease left and after I changed the boot and put it on my 2nd ex it was silent while the silent one I put on the problem car was just as noisy ,,, nothing changed with a CV swap , its not the CV , I'm 99% sure
__________________
'00 Sport 2DR
Old 03-24-2008, 02:06 PM   #20
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
Are you talking about the bearing that the CV 'floats' on where it enters the diff?
__________________
Brett
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
