| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Bitburg
94 XLT
94 steering knuckle removal problem
I am in the process of changing out my ball joints on my 94 xlt 4x4. i have read the forums, i have a haynes, but with all of the advice and direction i cannot get the steering knuckle off. I have all the snap rings removed, cotter pins out, the pinch bolt out, the nut completely off the lower ball joint, and obviousley the abs sensor removed, axel shaft out, and spindle off. I have hit the inside of the steering knuckle with a hammer, i have hit the outside, i have hit the top of both the upper and lower ball joint trying to force the spindle down and nothing happens. Am i missing something. I am in the USAF in Germany, i can fix a plane with no problem, but the ol ford is giving me a run for the $$$$$$. Any help, tips, point in a direction will be greatly appreciated.
#2 |
ELITE BRONCO2ERER
Crawlorado
B2 Mod
10# sledge right on top of the knuckle, hit straight down
Trick for stubborn ones is to also support the bottom of the torsion beam just inside the lower ball joint (block of wood, jack stand, etc) I have also used a pickle fork to destroy and separate the lower ball joint, but basically what you need is a bigger hammer. I have not met one yet that didnt come loose if you hit it hard enough with a big enough sledge It also really helps to wedge a large tip flat head screwdriver into the upper pinch bolt on the beam so you can easily rotate and remove the upper camber shim before attempting to drop the knuckle __________________ 96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's 88 BII 5.0L conversion - BII 5.0l drivetrain thread My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates Wifes 07 FJ build - 2007 FJ cruiser locked and lifted |
#3 |
Bitburg
94 XLT
The big hammer trick sounds good. Fogot to metion i have not removed the shim yet. the upper ball joint rotates when i turn the knuckle, but the lower one does not. What i mean by that is the shaft where the snap ring goes turns. The shaft where the nut goes on the lower ball joint does not rotate. is that normal? Thanks for the advice.
#4 | |
Springfield, MO USA
'93XLT4X2 (3:27 LimSlip)
Quote:
My advice...put the lower BJ nut back on just a few turns to secure the knuckle so it won't fall when you separate the joint. Then, take a pickle fork, place it between the lower edge of the knuckle and the BJ rubber seal, and bang hell out of it with good hammer. You will win! And thanks for your service.
| Thread Tools | |
