Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
93 Ranger 4.0liter Rough Idle/ Miss
Reply
Thread Tools
Old 04-01-2008, 11:06 PM   #1
sunrse777
New York
'91 XLT Supercab 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The engine runs very rough at idle. Feels better at higher rpm.
Spark plug wires are relatively new. I pulled out all the sparkplugs. 5 have nice light brown color, no major deposits ... the 6th one, which was in the back position on the passenger side, is clean (porcelin core is white like new) and dry, as if it wasn't firing or getting fuel. I'm thinking it's a bad fuel injector. What else should I check? Have not had to change an injector before.... How much of a job is it ? I know the upper intake has to come off. Is it fairly easy to do on these? Do you need to replace any gaskets on the intake ? While it's off, are there seals on the other injectors that should be checked and/or replaced? I'm also thinking the injector might be plugged up .... any ideas on what fuel additive cleaners might work to clean it out in place ???? Thanks to all.........
sunrse777 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-02-2008, 12:52 PM   #2
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
Did the problem exist before the wires and plugs were replaced? If not, could be a bad wire or plug. If you have an idea what cylinder it is, disconnect the wire to see if there is any difference in the way it runs. If you have isolated the problem to a specific cylinder, replace the plug and swap the wire with another cylinder to see if the problem moves with the wire.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 05-10-2008, 06:49 AM   #3
sunrse777
New York
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks.... I guess I should also do a compression check.... But since the sparkplug is dry and like new (clean) when I take it, I was thinking that the cylinder wasn't getting any fuel,, otherwise it would be wet if it was an ignition problem...
Old 01-02-2009, 07:45 PM   #4
bmxr152
Bakersfield, ca
bmxr152's Avatar
91 xlt
Vehicle Specs
Quoted: 0 Post(s)
did you ever find out the problem? Im having the same issue
__________________
91 XLT look here my registry
97 Mustang Cobra 100 shot, magnapacks, o/r x, jlt intake, kooks headers, C heads, fluid dampner, sct tune, drag suspension
bmxr152 is offline   Reply With Quote
Old 10-18-2009, 10:07 AM   #5
sunrse777
New York
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yeahh--- Bunrt valve and blown head gasket...
Old 11-02-2009, 01:48 PM   #6
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 294 Post(s)
...sunrse777's repair thread can be found here..
http://www.explorerforum.com/forums/...d.php?t=257552
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
