BrokeExplorer
- March 20, 2008
We have recently acquired a 97 Explorer 4.0 OHV 2wd with an auto. Ive tried searching and have tried some stuff, but to no luck.
Before: As soon as I would start moving the speedometer would go up to 50mph and stay there. It wouldn't go up or down until the vehicle was shut off.
I replaced the speed sensor with no luck, then the abs sensor
Now, it will read speeds under 50 mph, but not accurately. and as soon as it goes past 50 mph it drops to 50 and stays there.
The code that autozone pulled is P0714 but the description on the scanner does not match the one online. The scanner said it was the turbine/input speed sensor (not sure what that is).
We were thinking of replacing the cluster but since it sort of started to work we think it might be some sensor/electrical problem.
Any ideas? Experience with this?
Sorry for being long wanted to share all info. Thanks guys
