Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
Want to confirm JBL sub wiring.
Reply
Thread Tools
Old 04-10-2008, 07:24 PM   #1
Anthony_
97 XLT AWD 5.0L
Vehicle Specs
(Original Poster)
So from the searching I did I found a schematic with black/light green as postive and black/white is negative. Can someone confirm that?
Anthony_ is offline   Reply With Quote
Old 04-10-2008, 09:03 PM   #2
ford freak
coplay,pa
2004 xlt
Vehicle Specs
I'm not sure if everyone's gonna approve of what I'm gonna suggest but here goes.....You could try the old 9 volt battery trick. Tap into the two wires going to the sub and hold the two bare wires against the two terminals of the battery. If you have them correct then the sub will pop out. If they're backwards the sub will pop in. The battery will not damage the sub. Just don't use anything larger than a 9 volt and I would not let the signal from the battery go back to the amp. I would just cut the wire and then heat shrink it back together when you have your + and -.
ford freak is offline   Reply With Quote
Old 04-11-2008, 07:12 AM   #3
Cobraguy
Phoenix...Greatest City on Earth
1995 EB & 1999 EB 5.0
Vehicle Specs
Actually Ford Freak, that is a tried and proven method. No flame suit should be necessary. But try it with a AA 1.5V battery first. It should work with that.
Anthony, I have wiring manuals for 95, 96, and 99 Explorers. No 97. But I just looked at the 96 diagram and it is indeed how you say. Black with light green is positive and black with white is negative.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 04-12-2008, 06:45 PM   #4
Anthony_
97 XLT AWD 5.0L
Vehicle Specs
(Original Poster)
OK I tried the battery trick on the old sub that I took out. According to the experiment, I have them wired backwards. Now the question is, why in the world would all the wiring diagrams I found have the black/LG wire is positive when the experiment says it's negative?
Old 04-13-2008, 09:04 AM   #5
Cobraguy
Vehicle Specs
Maybe the test instructions are backwards??? All I can tell you for sure is what I posted above. That wiring is straight from the book and is exactly how I would wire it if I were you.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
