#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Cd player Error
Reply
Thread Tools
Old 04-14-2008, 05:18 PM   #1
2002XLT21
Yakima
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Cd player Error
i wnet to load a cd in the 02 X today and when i hit eject it ejected the cd then said error, i cant play any cd now and the cd is stuck open. its a 6disc in dash. plz help...
2002XLT21 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-14-2008, 05:34 PM   #2
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Quoted: 3 Post(s)
Dk Exp
Try removing the power to the deck, not sure how the supply is wired in the disk changers, might be faster and easier to disconnect the battery cable from the battery for a few minutes. Just like resetting the on-board engine computer
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
fixxxer is offline   Reply With Quote
Old 04-14-2008, 06:30 PM   #3
2002XLT21
Yakima
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ill give it a shot i guess
Old 04-14-2008, 06:35 PM   #4
best X
IRB florida
'96 SPORT
Vehicle Specs
Quoted: 0 Post(s)
my mom had same problem wiht hers but it had gotten wet and we just unplugged it and let it dry out and it worked fine good luck tho
__________________
'96 explorer sport 4x2
'87 samurai 4x4
best X is offline   Reply With Quote
Old 04-14-2008, 08:11 PM   #5
2002XLT21
Yakima
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
well i just took the panel off and when i took it out of the slot it started mixing the cds around the thing closed and when i put it back in i clicked cd and it worked. weird idk, tks neways
Old 04-15-2008, 10:22 AM   #6
rockfisherman
South Kingstown, RI
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Mine does this all too often (2004 single CD). Pull the fuse to the CD player, wait a minute, and then put it back. This will set the player back to default settings and let you eject the CD. It will also wipe out your radio station programming, so write it down first. The error I get is EJ Err.
I also burn copies of all my CDs...this error seems to happen more often with store bought CDs that may be thicker than a copied CD.
http://www.explorerforum.com/forums/...d.php?t=174768
rockfisherman is offline   Reply With Quote
Old 04-15-2008, 10:38 AM   #7
Thelt
Lenoir, NC
2002 Limited
Vehicle Specs
Quoted: 1 Post(s)
When mine does that I can usually just slide another CD into the slot and hold it there while I press eject and it will spit it out.
__________________
2002 Explorer Limited, V6, 3.73 limited slip
265/75/16s
Blacked out trim
Thelt is offline   Reply With Quote
Old 04-15-2008, 11:29 AM   #8
Skotty
In the Pasture,Ok
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
The cd changer in my 03 Mounty HATES burned cd's seems to error on every one I put in.Had to get some forceps and actually pry the last one out because it got stuck and wouldn't load or eject.
I see aftermarket in my near future!
Skotty is offline   Reply With Quote
Old 04-15-2008, 12:18 PM   #9
rockfisherman
South Kingstown, RI
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
Any tips on using the forceps?
Pulling the fuse trick didn't work this time. Neither did inserting another CD partway. Looks like I am going to be listening to "Long Road Out of Eden" for a Long time.
Old 04-19-2008, 03:20 PM   #10
Skotty
In the Pasture,Ok
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
when I got the errror I could see the CD.WARNING! Using the forceps will probably ruin your CD.I just grabbed it and gently tugged it out.I had to reset the radio as it thought there was still a cd in there.
Old 04-19-2008, 07:27 PM   #11
Monty02
FL
'02 Monty
Vehicle Specs
Quoted: 0 Post(s)
CD error
My wife's 02 Monty w/ 6 disc, constantly pops up with CD ERROR. I've had to pull the whole thing out a few times now. It's a pain, I pop open the halves and mess with some of the micro switches and it works for a couple weeks. There's a warning though that says not tip it upside down or it's garbage...read the labels!!
Monty02 is offline   Reply With Quote
Old 04-19-2008, 07:43 PM   #12
rockfisherman
South Kingstown, RI
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks. I kept trying the Eject button every once in a while (the definition of insanity...trying the same thing over and over again and expecting a different result ) and one time the CD just popped out! So I didn't have to try the forceps trick....this time.
Old 04-19-2008, 08:16 PM   #13
rrgone
Tucson, AZ
'02 XLT
Vehicle Specs
Quoted: 22 Post(s)
I had to pull a couple of home made cds out once. They had paper labels on them which I've found out is a no no. I got them with a pair of needle nose pliers that have long very skinny blades. They were right near the lip of the opening when it flipped open so were easy to grab. They still worked fine after i got them out. I've never had any trouble with home made CDs that don't have those paper labels.
rrgone is offline   Reply With Quote
Old 04-27-2008, 04:55 PM   #14
MrTeeThyme
Wake Forest, NC
2010 ST Ltd
Vehicle Specs
Quoted: 0 Post(s)
I just had this happen this weekend. I ejected # 6 to put a new one in, then when I tried to load, it gave me the CD Error message. Now it won't eject, load, or play any CD. I pulled the fuse and it cut the power, but it didn't fix the problem. I can't see any CD jammed at the door. Does anyone have any other idea what might fix this?
Thanks.
MrTeeThyme is offline   Reply With Quote
Old 04-30-2008, 03:40 PM   #15
cristal201
'02 EB
Vehicle Specs
Quoted: 0 Post(s)
Hey All
Hi All,
I need help. My '02 EB keeps saying CD Error. It won't play or eject. Whenever I turn on the car you can hear the CD player like it's trying to move but then I get the CD error. I took it out and was able to remove the CDs. But it still shows that the player is full and it's still making the same noise as it did before. Could it be that a tray is off track? How to I get it back on track if that is the case? PLEASE HELP!!!!!
cristal201 is offline   Reply With Quote
Old 04-30-2008, 10:48 PM   #16
High_Order1
near Oak Ridge, TN
2005 Jack Bauer Edition
Vehicle Specs
Quoted: 1 Post(s)
my 05 has a lot of problems with both ripped and commercial CD's. anything above 5-6 tracks and it's a crapshoot whether or not it will play the entire track, or part of it before skipping badly.
I like it - it reinforces the fact I need an AVIC....
-Shawn
High_Order1 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
