Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Fan Clutch Tool
Reply
Thread Tools
Old 04-19-2008, 08:40 PM   #1
Andiamo
West Lafayette, IN
'01 SOHC XLT 4WD 140K
Vehicle Specs
(Original Poster)
Fan Clutch Tool
I have a 2001 SOHC Explorer and I was trying to removed the fan today. I borrowed a tool kit from Autozone and it says it works for 1997 and up Explorers. Well the kit has two wrenches in it, the smallest being a 40mm. It was still too big to fit the fan clutch nut. Anyone else have this issue? What is actual size that I need? Thanks for the help.
Andiamo is offline   Reply With Quote
Old 04-19-2008, 08:44 PM   #2
briwayjones
Sykesville, MD
briwayjones's Avatar
'00 XLS, '03 Sport
Vehicle Specs
You could use a large adjustable wrench.
__________________
2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual
Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body
My 2000 Explorer
briwayjones is offline   Reply With Quote
Old 04-19-2008, 08:48 PM   #3
Andiamo
West Lafayette, IN
Vehicle Specs
(Original Poster)
That's my next step tomorrow. Where do those "H" looking things go to hold the pulley. Does it slide over the bolts?
Old 04-19-2008, 09:08 PM   #4
Nocturnall
Tempe, AZ
1997 Sport
Vehicle Specs
I bought the amco tool kit which is probably the same thing you got rented and it works fine....I think I used a 10mm box wrench or something to hold the fan so it wouldn't spin. Actually you shouldn't have to have anything hold it because the belt on the water pump should hold things from spinning.
Nocturnall is offline   Reply With Quote
Old 04-19-2008, 10:03 PM   #5
skoal_mint
Geraldton ontario
97 explorer sport 4.0
Vehicle Specs
Most of the time the belt will be enough pressure.
What I did one day was cut up a bunch of wrenches and drilled a pilot hole, then used my air hammer with a 2 foot center punch...you could even hold the pully with your hand and the fan would come off in a flash
skoal_mint is offline   Reply With Quote
Old 04-21-2008, 10:04 AM   #6
Andiamo
West Lafayette, IN
Vehicle Specs
(Original Poster)
OK, went to purchase a large cresent wrench yesterday and it is a no go. The wrench is too wide to fit between the space provided by the pulley bolts on the engine side and the fan bolts on the radiator side. There is not that much space to get the wrench in there. Talk about frustrating. I had to drink a beer after that one. I'm going to Sears tonight to get a 38mm wrench. Cross your fingers.
Old 04-21-2008, 08:38 PM   #7
Andiamo
West Lafayette, IN
Vehicle Specs
(Original Poster)
OK, I'm an idiot. I'll admit it. I was just too frustrated yesterday to think about removing two of the bolts from the fan clutch to make room for my cresent wrench. All I can say is, "Duh". Thanks guys.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
