Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
No AC, A/C cycling switch ?
Reply
Thread Tools
Old 04-20-2008, 11:35 PM   #1
joeydj4u
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
I have a 99 Explorer Sport
My A/C worked Last summer and this spring I just turned it on and noticed it just blows air. The compresor clutch is NOT cycling. I bought one those self charge kits, connected it to the low side it had 40-45psi, ok according to the guage.
A/C cycling switch on the Accumulator/Drier? I noticed the commpresor clutch does not go on at all. I unpluged the connector on the A/C Cycling switch, jumped the connector and boom, the clutch on the compresor kicks in. Is it possible that the problem lies within the A/C cycling switch and or low refrigerent and NOT the A/C presure cut off switch on the Compressor itself?
Are A/C cycling switches common to failure?
The A/C Cycling switch contacts are supposed to open when pressure drops to 22-28 psi and close at 40-47 psi.
Now given that on the gauge I had 40+ psi and the clutch only went on when Jumped, I suspect my cycling switch is stuck on open position and therefore not energizing the compresor clutch, Hmmm. Thoughts?
The Cycling Switch runs $15-$25 should I just give it a whirl? It's not that expensive, I just did'nt want to start throwing parts in
Thanks in advance to any responses.
( Join the Elite Explorers )
Old 04-21-2008, 12:00 AM   #2
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
Whats the high pressure side reading? It may be overcharged if you charged it up recently.
Blee1099 is offline   Reply With Quote
Old 04-21-2008, 12:35 AM   #3
joeydj4u
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
I no longer have manifold gauges to check both sides basicly I figured since it worked well last summer it may be low, went to a local auto parts store bought the recharge kit that comes with gauge the shows where your at pressure wise on the low side I'm believe being thats where directions stated to connect the the can. I't read full so I did not proceed to charge the system. I just jumped the switch to make sure I did not have a compressor/ clutch problem.
Old 04-21-2008, 05:57 PM   #4
joeydj4u
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
OK update, I got a set of gauges hooked them up here's what I had
70 Degrees Ambiant Temp Today
25- 30 Low side
140-145 Hiigh side
65 degrees out of the vents
The compressor started cycling litlle by little
I replaced the A/C Cycling switch
Recharged with 2 small cans of 134
The compressor started cycling little by little and finally seemed to cycle at normal state as I Charged.
Readings are now
35 - 40 psi Low side
145 - 150 psi Hi side
38 - 40 degrees comming out of the center vents.
I will drive the vehicle for a few days and see what happens
Are my readings close to what spec should be?
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
