Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Crack at the rear window panel
Reply
Thread Tools
Old 04-21-2008, 11:02 AM   #1
ykkspring
Simsbury, CT
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi,
I noticed a crack on the back panel ( below the rear window ) on my explorer during past winters, it autoatically fills up when its hot outside and it shows up again when its cold weather (looks more like a case of metallic expansion/contraction at different temperatures), I am interested in knowing if anyone else has observed this phenomena in their cars or is it just a crack in my car only and not by design?
If its just a crack, what should be done in order to fix it (instead of changing the whole panel).
Please advise.
Thanks.
Yogesh
ykkspring is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-22-2008, 01:34 AM   #2
Black92LX
2003 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
it's very common place.
The best i can see is that water gets between there and freezes causing enough expansion to crack the plastic.
Then of course with temps it expands and contracts making the crack visible or not Dependant upon temperature.
Black92LX is offline   Reply With Quote
Old 04-22-2008, 09:42 AM   #3
ExplorerDLUG
Atascadero, Ca
'02 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Thats what that is. The crack in my rear panel is so perfect it looks like someone took a saw straight to it! Now if I wash the truck water will stay in there for even a few days and I get a shower when I go to get into the back!
__________________
2002 Explorer XLT 4x4 4.0L
ExplorerDLUG is offline   Reply With Quote
Old 04-22-2008, 06:29 PM   #4
ykkspring
Simsbury, CT
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks Guys,is there anything available in the market to fill the crack?
__________________
Explorer'02 XLT 4x4 4.0L 6 Cyl.
Old 04-30-2008, 05:43 PM   #5
planman4y2k
Lincoln, NE
2002 EB V8
Vehicle Specs
Quoted: 0 Post(s)
Cool Mine too!
Hi,
I have the same thing on mine. Cracked right by the ford logo on the right side. I contacted Ford and they told me too bad and wouldn't do anything.
So, I called the dealer and they said that they would replace it for 100 dollars.
The service guy said that its a common problem and normal replacement is 400 dollars. Didn't get it replaced yet due to no warrenty on the replacement part doing the same thing.
I also did some research on the problem. I was on car complaints.com... I think, and found many other people with the same problem. They were trying to organize and get Ford to pay for full replacement due to the crack happening from a design flaw.
My best advise is to check with the Ford dealership where you purchased your Explorer and see if they will cover part of the cost to replace the rear panel.
Hope this helps.
planman4y2k is offline   Reply With Quote
Old 04-30-2008, 07:03 PM   #6
ykkspring
Simsbury, CT
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks so much , it helped indeed !!
__________________
Old 05-02-2008, 10:11 PM   #7
pennstatejeff
West Chester, PA
2002 XLT 4.6L V8
Vehicle Specs
Quoted: 0 Post(s)
Obvious design flaw...
ykkspring: Have the same crack on my liftgate. Reason is that Ford oval logo right in the middle, leaving a much thinner section of the plastic panel above and below the logo, where stress concentrations occur due to freeze-thaw cycles, eventually cracking the plastic. Vibrations from closing the liftgate probably contribute to problem as well. Yes, I have been reading about folks having this problem for some time, and no, Ford is not likely to pay to fix since it's not really a safety issue. I've been meaning to look into trying to fill the crack with clear caulk, if I can only do a nice "clean" job. Maybe now that the weather is beginning to break...
Keep us posted if you hear anything about Ford getting off their @$$ and offering to fix it.
pennstatejeff is offline   Reply With Quote
Old 05-03-2008, 12:35 AM   #8
crash594
2005 XLT
Vehicle Specs
Quoted: 1 Post(s)
Marine-tex works great for that type of repair. It can be found in most marine stores. I have used it to repair fairings on aircraft. It is sandable and I have painted over it with no primer. I always keep some around. If you use rtv you can not paint it. The pain will not stick. Marine/tex acts like bondo but will not crack and it bonds to almost anything. Cold temp will not cause it to crack. -20 to above 100 degree
PS
It comes in grey and white
http://www.discountmarinesupplies.co...OXY_PUTTY.html
crash594 is offline   Reply With Quote
Old 05-03-2008, 10:28 AM   #9
regina falangy
US Virgin Islands
'04 xls
Vehicle Specs
Quoted: 0 Post(s)
This problem is not just due to freezing. My 04 has never seen a temperature below +70 degrees F. and mines cracked.
regina falangy is offline   Reply With Quote
Old 05-03-2008, 10:47 AM   #10
hellodavey
2002 Limited
Vehicle Specs
Quoted: 0 Post(s)
I've had three explorers (1 '02, 2 '03) that all had this problem. My assumption was that this was the result of different thermal expansion and contraction rates of the plastic vs the glass window that the plastic is bonded to. The cracks open up almost 1/8" in the cold but seal so tightly you can't see them in the summer sun. Nothing seems to be in danger of falling off. It's just cosmetic. I wouldn't want to fill the cracks with anything given the way they swell shut in the sun. You may induce even more strain on the component.
hellodavey is offline   Reply With Quote
Old 05-18-2008, 12:25 AM   #11
DavidS
Kingsport, TN
'02 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
According to my research on my '02 EB, there was an issue with the plastic formulation used for this panel, which is glued onto the all-glass upper liftgate section. When mine first started becoming noticeable, the dealer told me that I'd used the wrong window washer fluid and it'd damaged the plastic(?). Since almost everyone's window washer fluids consist of methanol/detergent/water mixes, I told them that was BS but they wouldn't budge. I had brought it in for the recall over the hinges in the upper liftgate. They told me that if they broke the glass during the hinge replacement, then they'd replace that section as well, otherwise it was $269 for the replacement panel and the paint job. Mine has now cracked both vertically and horizontally and on cold days the crack is almost 1/4" wide! On warm days it's less, proving that an inferior material was chosen for the design. Mine was under extended factory warranty at the time it was reported but they said it only covered drivetrain issues which they paid dearly for when my rear axle bearings and a few other transmission-related issues showed up. Crap over responsibility for things like this is just one of the many reasons Ford is in trouble.
DavidS is offline   Reply With Quote
Old 05-18-2008, 08:22 AM   #12
daprez1963
Florida
daprez1963's Avatar
05 XLT 4dr 4WD 4.0 V6 FFV
Vehicle Specs
Quoted: 0 Post(s)
Okay....Some of you are a bit offf in your guesses. I have had this problem on another exp and I had it in Arizona and it never saw a temp under 60. The reason it is "common" is that fact FORD used a thin cheap plastic in an area that has in some cases and people, a lot of traffic with opening and shutting of door. There is no insulation between the plastic panel and the glass door. I would suggest that you use the glass window for access and if you need to open the rear door, you close it softly but firm enough to shut. It also helps where you push on when doing this. The cracks all appear to head or start in the same area (center). You can find a replacement panel from $50-100 but it comes unpainted and attaching it to look like day one is not as easy as it looks. Unless it really bothers you, I would just leave it alone. If you replace it, the new one will just crack as well unless yo9u take care of it (something everyone should have done in the first place to avoid this). Ford has not nor will pay for this. Sorry, all those complaints will just be ignored.
daprez1963 is offline   Reply With Quote
Old 05-19-2008, 07:01 AM   #13
regina falangy
US Virgin Islands
'04 xls
Vehicle Specs
Quoted: 0 Post(s)
Quote:
The "crack" has nothing to due with "taking care of" or "opening and shutting of door" My 04 has 13000 miles and the "rear door" has rarely ever been opened. It's a poorly designed part and thermal expansion is the culprit. But not just freezing causes the crack, high temps will crack the pos as well.
Old 05-19-2008, 11:40 AM   #14
trolsk
Salt Lake City, Utah
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
Cheap crap plastic
It's academic at this point don't you think as to the reason the stupid plastic cracks? It cracks, it's crap, it needs to be replaced. I got the part for about 40 bucks after-market, painted it and stuck it on. No problems.
trolsk is offline   Reply With Quote
Old 05-19-2008, 12:16 PM   #15
High_Order1
near Oak Ridge, TN
2005 Jack Bauer Edition
Vehicle Specs
Quoted: 1 Post(s)
I saw a TSB for this too. Are y'all sure there isn't an owner dialog program for this problem? It seems to be pretty widepread.
-Shawn
High_Order1 is offline   Reply With Quote
Old 06-18-2008, 08:19 AM   #16
dorf16
Upstate NY
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
The panel cracked on my '02 when less than a year old. Ford replaced it for free and acknowledged a problem. It has been fine since. I have seen numerous others with the same crack in the panel, always near the center. One other owner I was telling about how Ford foot the bill for mine told me he had already had Ford replace his once, and it had happened again. This time, he told me, Ford would not cover it.
__________________
dorf16 is offline   Reply With Quote
Old 06-18-2008, 08:54 AM   #17
Black92LX
2003 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
it's always going to be near the center because that section of the plastic is extremely thin since it's recessed to fit the Ford Emblem there
Old 06-18-2008, 09:30 AM   #18
03Redfire
Dayton, Ohio
03 XLT
Vehicle Specs
Quoted: 0 Post(s)
Has anyone talked to a body shop about replacing the entire tailgate with one from a 2006 or newer with the different design? I have not looked at both vehicles side by side to see if it will fit the opening, and has the same mounting points. If you add this problem to the bad piller trim and door piller trim panels that the paint flakes off you have quite a big bill to keep your X looking good on the outside. I had to replace a tailgate on a Chrysler van and it was about $1,200.00. If you could buy the tailgate from a salvage yard it might be a nice mod if it will fit.
03Redfire is offline   Reply With Quote
Old 06-18-2008, 03:09 PM   #19
Curtis
Orlando, FL
04 XLT 4x4
Vehicle Specs
Quoted: 6 Post(s)
Quote:
True, but then you'd loose the low opening for putting stuff in and out with just the glass open. I like that feature.
Mine hasnt cracked (knock on wood) but on a hot day the top of the panel seperates from the glass like a bubble. cooler days its not even noticible.
because of this rain does collect in there. and I too can end up with a shower when I open the glass.
__________________
Curtis
2008 Expedition EL Limited
2004 Explorer XLT 4x4 4.6
1970 Buick GS 455 Silver Mist
Curtis is offline   Reply With Quote
Old 03-05-2010, 01:00 PM   #20
thewho6
Omaha, NE
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
well went to the store today and when i went to open the back door there was that crack that i had read about, i have had my 04 for 7 years and just paid it off, now it will start to fall apart, the more i have it the less i'm not liking ford, i think there trucks are good but for the exploers are junk, or i just bought the wrong year
thewho6 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
