Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
BEST PLUGS for a stock 4.0 OHV...?
Reply
Thread Tools
Old 05-05-2008, 06:35 PM   #81
Flandry
Birmingham, AL
1993 Sport
Vehicle Specs
Quote:
Originally Posted by YourNameHere View Post
My truck pings like crazy when I try to accelerate on the highway. Will the plugs cure that?
From what I've read here, a lot of pinging problems come from carbon buildup. Changing the plugs may help. But before you do that, you might want to Seafoam the engine first. You may also have a dirty MAF sensor. Search and you'll see lots of threads covering both. I've also had pinging occur because my spark plug wires were shot.
Flandry is offline   Reply With Quote
Old 05-05-2008, 07:58 PM   #82
YourNameHere
Haverhill, MA
94 Explorer
Vehicle Specs
(Original Poster)
I cleaned the MAF a few times. 1 of the wires was real DIRTY, but i cleaned it up.
Which vacuum line can I suck the seafoam in through? I'm not familiar with these trucks at all.
__________________
-P.J.-
Winter Beater: 1994 Explorer XLT 4wd
Summer Car/ Daily Driver: 1998 Mustang Cobra coupe #4941 of 5174 Born on June 19, 1998. 263rwhp/258rwtq untuned, with nonfunctioning IMRC's. Hoping for 285-290 next spring with a much needed tune.
YourNameHere is offline   Reply With Quote
Old 05-05-2008, 08:27 PM   #83
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
You can use the brake booster vacuum line.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 05-05-2008, 08:47 PM   #84
YourNameHere
Haverhill, MA
94 Explorer
Vehicle Specs
(Original Poster)
That is the line to the left of the master cylinder, correct? I disconnect the side thats at the booster?
__________________
-P.J.-
Old 05-05-2008, 09:22 PM   #85
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Yes. Yes.
__________________
Al Franklin
My truck
My Quest for 30
Old 05-18-2008, 02:52 AM   #86
Greasemonkey
Fullerton, California
1992 XLT
Vehicle Specs
The owners manual recommends Motorcraft copper tips. Some of you might not know it, but if your ignition system is in good shape copper tip plugs will give better performance than platinum or iridium tipped plugs. The reason is platinum and iridium plugs fire at a lower voltage, which means a lower energy spark. This is good if you have a weak ignition system that can just barely fire a copper tip plug, but if you have a strong ignition the plugs will fire with too low an energy to give peak performance. The main reason some manufacturers are using platinum plugs is its so hard to change plugs in modern crowded engine compartments.
The parts guy at Napa confirmed the research I did, and said many people have worse performance using platinum plugs.
Greasemonkey is offline   Reply With Quote
Old 05-18-2008, 09:24 AM   #87
YourNameHere
Haverhill, MA
94 Explorer
Vehicle Specs
(Original Poster)
That's what I was saying way back in this thread.
FWIW, I ran Seafoam through the brake booster, and ALL my pinging is gone!
Too bad I still have the acceleration of a snail.
__________________
-P.J.-
Old 05-20-2008, 03:07 PM   #88
BIGHVM
UK, Richmond, Surrrey.
2000 Northface
Vehicle Specs
UK Wrong!
Plats are a huge waste oh money.
Their only benefit is that they last longer between plug changes.
No need to waste money on the plats.
I guess i'll go with the Autolites. I use them in my 98 Cobra and it runs like a raped ape.
I have used double plats for years now in both of my Exs, I ran autolite in one loved that, ran smooth and never missed a beat- and last 60K!!
I just put in NGK PTRD-13 plugs in my Northface and the same result.
YOu can buy normal plugs and change them every year, but I believe that double plats maintain the gap for longer so help to keep the engine at its best.
__________________
H
http://www.reverbnation.com/scratchthemonkey
Kevin P shackles, TT twist, induction kit.
UK 2000-Northface.
BIGHVM is offline   Reply With Quote
Old 05-20-2008, 04:22 PM   #89
mhatten02
Columbus, Ohio
1992 Explorer 4x4
Vehicle Specs
WOW... month long convo about spark plugs LOL Didn't think it was possible. HAHA Just messin.. I'm new and figured this was as good of a place as any to get my first post. Just my $.02 worth... Ford = Motorcraft.... end of story!
mhatten02 is offline   Reply With Quote
Old 05-20-2008, 08:50 PM   #90
YourNameHere
Haverhill, MA
94 Explorer
Vehicle Specs
(Original Poster)
eVERY 30K cOPPER PLUGS NEED TO BE CHANGED, THAT'S EVERY 2+ YEARS.
Sorry about the caps.
__________________
-P.J.-
Old 05-20-2008, 09:51 PM   #91
mhatten02
Columbus, Ohio
1992 Explorer 4x4
Vehicle Specs
Hmmmm copper sounds nice!!!!!
Old 05-21-2008, 08:43 PM   #92
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
Whatever Motorcraft plugs are currently being sold for the application are usually the best. They used to be double platinum, then platinum plus, and now, who knows. The last set I bought was fully threaded and had a much smaller electrode, very similar to iridium plugs.
I'm not sure about running a platinum or double platinum plug for 100K+...copper is usually 30K, platinum 60K, and iridium 100K. I changed my last platinum plus set at 50K, and got a massive torque and power increase (meaning the torque/power it was capable of came back, not that the plugs added anything that wasn't already there) across the board with the new plugs. Sure, they'll last, but you'd have to pull and re-gap them to make up for the wear, and for the price of new plugs, I think I'd rather replace them then pull, re-gap, and re-install them.
NGK and Denso do make some of the best plugs out there. These are the ONLY plugs you should use in a Japanese brand car. I'd probably use NGKs in the X if the Motorcrafts didn't work so well and cost so little per plug when you buy 6.
As for wires, I do suggest Magnecor. Like good plugs, they just let the ignition do what it's capable of. They also don't claim any BS about their products. Their site is a good read, and a hoot depending on how much you've read about other wire manufacturers claims.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 05-21-2008, 09:38 PM   #93
EskimoEddie
SW Maine
1994 Eddie Bauer EX
Vehicle Specs
changing plugs tomorrow, weather permitting
Quote:
Originally Posted by Flandry View Post
Here are some instructions that are similar to the way I do it:
http://www.explorerforum.com/Singlet...es/plugs2.html
He advises:
and I can't stress enough how important this is. One of my few Snap-On tools is a 5/8" universal spark plug socket with extension, which I got specifically for this purpose.
So, my question is, will adding universal socket joints to change farthest passenger side plug alter torque readings on my torque wrench? I've also read to stay away from Bosch plugs, what about Bosch wire sets? I shop autozone and the bosch are the more expensive brand. Does high $$ = best performance and long life? Or will duralast brand work well enough? I've never changed my own plugs/wires so please excuse my newbie-ness, Thanks for any info. Greg (aka Eskimoeddie)
EskimoEddie is offline   Reply With Quote
Old 05-21-2008, 09:46 PM   #94
TedJ
Fair Lawn, NJ
TedJ's Avatar
'94 Sport
Vehicle Specs
I installed Duralast wires (guy was paying me and gave them to me to do the job with) on an Aerostar. Van came back about a year later, one of the wires had failed and lost it's grip on the plug, causing a miss. They are NOT the same quality as Bosch or Motorcraft, I fixed the van with a set of Bosch wires and they snapped on the plugs much better. I use Motorcaft on my own truck, ordered from Rock Auto for a good price....
TedJ is offline   Reply With Quote
Old 05-21-2008, 10:59 PM   #95
EskimoEddie
SW Maine
1994 Eddie Bauer EX
Vehicle Specs
How-to Seafoam my Ex?
great picts, looks like my Ex......but how do I do it? Remove vac line from booster and draw seafoam directly from can? How long? Do it before I change plugs? I've read that it tends to gum up plugs. Thanks for any info
EDIT
Seafom my Ex before tune up AND before oil change?
Old 05-22-2008, 05:07 AM   #96
YourNameHere
Haverhill, MA
94 Explorer
Vehicle Specs
(Original Poster)
Yes, to everything you asked above.
Use the whole can.
__________________
-P.J.-
Old 07-04-2011, 07:12 PM   #97
Snort
Seattle, WA
94 XLT
Vehicle Specs
I just put in a set of Motorcraft SP486 plugs which I thought were the latest platinum design, to replace my Motorcraft 42PP plugs. On the 42PP plugs, I can clearly see a small piece of platinum welded onto the ground electrode, nothing on the SP486. My understanding is that the 42PP had platinum on both the center and ground electrodes, so that they would work well on both sides of the motor (reverse coil polarity on the two coils). So what's the story on these new Finewire platinum plugs... where's the platinum?
Snort is offline   Reply With Quote
Old 07-09-2011, 09:18 PM   #98
mr cribb
Eufaula, OK
mr cribb's Avatar
92 4dr 5spd 2WD
Vehicle Specs
I just used the motorcraft plugs that advance auto parts sold. I also picked up a set of motorcraft wires to replace the ones that were on it.
__________________
Jeremy Cribb, SGT, U.S. Army Retired 2002-2013. Iraq Veteran 2005-2006
Engine down for a while.... awaiting money for bottom end rebuild
I collect license plates.... PM me if you have some up for grabs....
mr cribb is offline   Reply With Quote
Old 07-11-2011, 12:08 AM   #99
Delta_1980
livingsville, California
92' exploder
Vehicle Specs
i'm going to install some laser plugs then i'll only post on the modified 91-94 explorer forum....yeah right
Delta_1980 is offline   Reply With Quote
Old 07-11-2011, 12:19 AM   #100
Snort
Seattle, WA
94 XLT
Vehicle Specs
Quote:
You are either too hilarious or too insane to ignore. WTHeck are you talking about with your badass laser plugs?
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
