Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Can You Adjust Steering Play???
Reply
Thread Tools
Old 04-21-2008, 11:04 PM   #1
Explodr94
Vista, CA
1996 XL
Vehicle Specs
Quoted: 8 Post(s)
(Original Poster)
Last weekend, put in new bearings and races. Wheels felt nice and tight up and down. When I grabbed the tire from side to side I noticed that there was a lot of play. I did not put the car down and check the tie rods properly, but will do that. However, when I did the same check on the driver side, I noticed that the steering gear had a lot of play and I am starting to think that is the issue, not tie rods. On my friend's old corvette you can adjust the play on the steering gear. The gear box on the ex looks like it has an adjusting nut, but I could not find an adjustment procedure in the Haynes manual. Can you adjust the steering play on a 94 ex? And what is the procedure?
Explodr94 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-22-2008, 06:11 AM   #2
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
As you have found the steering gear can be adjusted with the set screw located on the top. You would loosen the lock nut and turn the set screw clockwise to tighten up the gear. I did this a several years back when my steering felt really loose. I first loosened the locknut, turned the setscrew a 1/4 turn, tightened the locknut and drove around the block. I repeated the above until it felt the best. BTW If you over tighten the setscrew the steering wheel will NOT return to center on its own which will be obvious when you take a test drive.
Bear in mind the set screw only tightens the gear and doesn't remove any unwanted slop do to internal wear (which was the problem I had). I ended up replacing the steering gear and my steering has been Fantastic ever since.
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 04-22-2008, 09:42 AM   #3
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
'01 Ford Ranger, RIP 93 X
Vehicle Specs
Quoted: 13 Post(s)
yup, i'm having to adjust my stearing gear. i'm not willing to pay to replace it yet. my steering wheels (if centered) can travel 3 inches either way before starting to turn. yikes!
__________________
I haven't been on this forum in a while and I'm trying to work my way back into it. I'm going for Mod or bust!
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger Edge 5.0L Swap Thread
1991 Nissan 240sx Drift Pig
Blacksheep Josh is offline   Reply With Quote
Old 04-22-2008, 10:18 AM   #4
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
check your pitman arm and steering linkage for looseness
3" is nothing, I haev 1/2 a full turn of steering slop
My slop was in my steering linkage
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 04-22-2008, 11:36 AM   #5
Blacksheep Josh
Statesboro, GA
Vehicle Specs
Quoted: 13 Post(s)
linkage would be what's viisble under the hood correct?
__________________
Old 04-22-2008, 08:34 PM   #6
underconstruct
St-Hubert,QC
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
Look iunedr your truck ... look for tie rod end pitman arm and the steering box ...look if you can play with the centerlink... if you can move it with your and and the steering doesn't move check for loose side by side and look for the joint on the pitman arm ...
underconstruct is offline   Reply With Quote
Old 04-22-2008, 11:33 PM   #7
Explodr94
Vista, CA
1996 XL
Vehicle Specs
Quoted: 8 Post(s)
(Original Poster)
Thanks, I let you know the results when I get it done.
Old 04-22-2008, 11:51 PM   #8
wolfnutts
chester nh
91 nav ho. 96 5.0 4 dr
Vehicle Specs
Quoted: 0 Post(s)
id say it may be your rag joint . just behind the box their is a plastic cover move that outa the way an look their while some one turns steering wheel back an forth
wolfnutts is offline   Reply With Quote
Old 01-13-2009, 05:26 PM   #9
Masterd
Upland, CA
1993 Explorer Sport
Vehicle Specs
Quoted: 3 Post(s)
Ive narrowed mine down to box wear, probably.
The rag joint is solid, and you can turn the steering shaft both ways a bit and clearly see the play is in the box.
Now to the good part...I'd adjust the screw if I had ANY way of breaking that lock nut loose. No amount of liquid wrench did any good, even after taking a hammer to the back end of the wrench.
Masterd is offline   Reply With Quote
Old 01-13-2009, 05:31 PM   #10
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
use pb blaster on the nut to see if it will free it up..
If you still can't get it free the only thing I can think of is an impact wrench on it to break it free.. For something like that I'd use my 12V impact wrench as it has one hit every 5 seconds.. That way once it pops free it won't spin it all the way.. It also won't have the risk of spinning the adjusting screw if they screw and nut are stuck together still.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 01-13-2009, 05:36 PM   #11
Titan09
Southeast Georgia
'93 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
I have a '93 Sport, and I'm also having this issue. Is getting to the adjusting screw and actually adjusting it a simple procedure? Or is there dismantling involved? I've never had to deal with anything like that before.
Titan09 is offline   Reply With Quote
Old 01-13-2009, 07:11 PM   #12
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Quote:
I don't believe you need to remove anything to access the set screw.. its been awhile.. At the most you'd need to remove the air intake, but I do believe you can access the set screw from above with several long socket extensions.
__________________
Old 01-13-2009, 08:01 PM   #13
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 213 Post(s)
Quote:
As DeRocha said in this earlier post, the set screw is not there to correct freeplay. I recommend having someone rock the steering wheel back and forth (engine running) while you look down into the engine bay at the gearbox and the steering column, and then at the steering linkage itself. See where the looseness is. These parts all wear.
When I have major play, it was the splines on the very end of the steering column, where it clamps onto the splined end of the input shaft of the gearbox.
I suggest you look there, your splines may be wearing down. I put in a new used ragjoint section, and solved my problem.
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is offline   Reply With Quote
Old 01-16-2009, 08:11 AM   #14
Titan09
Southeast Georgia
'93 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
Well, thankfully I didn't have any major play in the wheel...I just tightened the adjusting screw a bit and it works great now
Old 10-03-2009, 08:20 AM   #15
monsterblur
mechanicsville, virginia
88, xlt
Vehicle Specs
Quoted: 0 Post(s)
I adjusted my steering box a little too much and the steering was tight, then when I tried to loosen it, I couldn't turn the adjustment scew back any. The locking bolt will move but not the set screw. Any suggestions?
monsterblur is offline   Reply With Quote
Old 10-03-2009, 10:16 PM   #16
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
I've done that too.. to get it to turn back, wiggle the steering column as you try to loosen the bolt. Each time it moves back/forth it will allow the bolt to turn a little.
~Mark
__________________
Old 10-04-2009, 01:51 AM   #17
nitro71
Spokane WA
Vehicle Specs
Quoted: 0 Post(s)
And if you want to know more about the inards of that thing here you go!
http://www.stangerssite.com/HowItWorksSteeringBox.html
That adjusting nut is setting the mesh between two gears. Two tight and it'll bind, cause wear. To loose and your steering wanders. I'm pretty sure that the text book way to set it is on a bench with a torque wrench turning the gear.
I've had luck using a longer screw driver on the adjusting nut and getting a wrench on the lock nut.
nitro71 is offline   Reply With Quote
Old 10-04-2009, 10:22 AM   #18
monsterblur
88, xlt
Vehicle Specs
Quoted: 0 Post(s)
That worked.
Thanks for the advice.
Old 10-04-2009, 11:12 AM   #19
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Quoted: 289 Post(s)
Sweet!
I was just going to do a search on this subject. I have a little play in the 94 steering after lifting it a little. Guess it couldn't hurt to try this. I wont go crazy, just a little bit at a time turning that screw.
__________________
The Black Hole
Pugly
gmanpaint is online now   Reply With Quote
Old 10-07-2009, 04:03 PM   #20
nak4af
Bellevue, Nebraska
nak4af's Avatar
1993 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
I'm gonna try this when I get home from work.
__________________
Chris
6.5" total lift, 33" Kumho Road Venture MT KL71
**In memory of John Smith**
MY TEMP MY MUG
nak4af is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
