Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Removing the Catalytic converter
Closed Thread
Thread Tools
Old 04-26-2008, 03:54 PM   #1
ParkerRocker
Hayden, ID
92 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I am trying to remove the cat from my 92 sport. But i'm having some trouble, i have let the bolts sit in a break free solution for about an hour, and they still won't budge. Does anybody know the size of the bolts that hold the cat on? i removed the bolts from the end connected to the muffler, now i'm stuck on the last 2 bolts at the front. I'm trying to use a 9/16 but its not working, it keeps slipping and i'm worried about rounding it off...
thanks!
__________________
-ParkerRocker
ParkerRocker is offline
( Join the Elite Explorers )
Old 04-26-2008, 04:11 PM   #2
boggs1227
Flowery Branch , Georgia, 1994 sport 2wd auto
2005 colorado 2wd 5spd
Vehicle Specs
Quoted: 0 Post(s)
vise grips ?! also maybe get a tap and a hammer and hit the nut to see if it will break free from the rust
__________________
Scott .
boggs1227 is offline
Old 04-26-2008, 04:23 PM   #3
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
I live in Sourthern Az (no rust) and we have never been able to take off the cat that way..
When I replaced the cat the local shop just cut the cat off and then squished a 3" pipe and put it in the collector looking thing and welded it in..
I've even had to replace the cat once since then.. that time he cut it closer to the cat where it was a regular round pipe so it was easy to put in..
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline
Old 04-26-2008, 11:31 PM   #4
ParkerRocker
Hayden, ID
92 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
tried an impact gun and had no luck, completely mangled the nut. Might just have to cut it off now...
__________________
-ParkerRocker
Old 04-27-2008, 09:12 PM   #5
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Yea its a 14mm or 9/16 and I had to cut mine off on my 91 but my moms 97 came right off.
__________________
91 Eddie
Bunch 'O' Mods- 35's, winch, gears, blah blah
www.southernxplorer.com
91exploreron37 is offline
Old 04-27-2008, 10:09 PM   #6
benjammin4x4
Asheville North Carolina
'93 LTD
Vehicle Specs
Quoted: 0 Post(s)
Should be 14 mill thats what mine was
benjammin4x4 is offline
Old 04-28-2008, 03:53 PM   #7
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
You need 6 point sockets to really grab these under-the-car nuts and bolts. 12 point tools will just spin off and strip them.
__________________
1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
Tony H is offline
Old 04-28-2008, 11:27 PM   #8
ParkerRocker
Hayden, ID
92 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
well i figured since i had such a hard time with the one that was EASY to access, i would just cut it off at the exhaust pipes and work from there. I'm going to clean out the inside, so i have two questions i suppose. Should i just clean the carbon buildup and such out, or should i completely bore it out? i have heard that this causes problems with backpressure on some engines and was wondering about this one.
I live in idaho
emissions are not a problem...
__________________
-ParkerRocker
Old 04-29-2008, 08:27 AM   #9
Tony H
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Cutting it is the easy way out for sure.
I bet you will not have any Backpressure issues.
There will be less backpressure, I can't see why that would hurt you.
__________________
Tony H is offline
Old 04-29-2008, 08:39 PM   #10
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Clean the carbon deposits out of what? the exhaust pipe? There shouldnt be that much inside of there or maybe I'm missing the question sorry.
I did like maniak and cut the pipe at the flange and welded a bent 3in pipe in there.
Yea I believe the less backpressure the better(to a certain extent) but there's alot of people that think otherwise so I'm staying off that subject.
__________________
91 Eddie
Old 04-30-2008, 08:17 AM   #11
ParkerRocker
Hayden, ID
92 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i was speaking of the cat itself, i know that it can get clogged, and i suspect mine is. really i wanna bore it out and have it like a straight pipe, just still have it look like theres a cat.
__________________
-ParkerRocker
Old 04-30-2008, 10:27 AM   #12
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
When a cat get clogged its not actually clogged with soot. Normally when they are clogged it means they got hot and the honey comb looking material is now a solid glob.
That normally happens when the vehicle runs rich for a long time and the cat get too hot and melts the materials inside.
It can also happen if the cat gets hit (like when wheeling).. It can break and then the little pieces move and block the flow. The pieces can even end up in the muffler and clog it.
~Mark
__________________
Maniak is offline
Old 04-30-2008, 11:03 AM   #13
TeckNine4
Fort Myers,F.L./Fairfax,V.A
'94 Explorer XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Ah just go ahead and get the sawsall or jigsaw out,lol,, My cat is clogged to, I think im going to take it out on the Interstate take it up to 80mph and high RPM to blow some of the carbon out
__________________
None!! looking for 94' XLT 4x4 Blue, Pioneer deck, Custom fabricated pistol holster, 12-inch sub-amp-box kit (Visonik,only 50 buckz!), Blue flake interior accent paint, Matching engine accent paint, Interior StreetGlow L.E.Ds blue and green,White face gauges, 15% Black tint all 'round, K&N Filter White StreetGlow full underglow neon kit(FREE!), White Streetglow washer nozzle L.E.Ds
TeckNine4 is offline
Old 04-30-2008, 11:19 AM   #14
boggs1227
Vehicle Specs
Quoted: 0 Post(s)
hows this for a idea....with the truck warmed up cat too ( from say 10 miles worth running time ) park the truck have someone either rev the engine up while someone hits the cat with rubber mallet to see if any clogs can be undone or cleared out while reving the engine up to say 3k .dont know but this may clog the muffler up to(hard to say) !?
maybe a good idea any thoughts on this ?
__________________
Scott .
Old 04-30-2008, 11:25 AM   #15
wolfnutts
chester nh
91 nav ho. 96 5.0 4 dr
Vehicle Specs
Quoted: 0 Post(s)
you are going to have to cut the nuts off , if these are the originals the bolt half half zz are pressed in an you can forget about moving them till the cat is off . then you can use a big vise to press umm out or grind them flat with the flange an then take a punch an hammer out what is left an its funn too bamm bammm ohhh !$$% my thumb
wolfnutts is offline
Old 04-30-2008, 03:20 PM   #16
TedJ
Fair Lawn, NJ
'94 Sport
Vehicle Specs
Quoted: 1 Post(s)
With rusty exhaust hardware, there is no "correct size" the bolt is usually whatever size it has rusted down to be now. Play with metric and standard sockets, and find one that you can pound onto it. If you have to dremel the flats of the nut a bit, do it. And always use 6pt, impact sockets. I also have a set of well used (inherited from grandpa) impact sockets that are actually a bit bigger cause they are worn, and they sometimes fit when nothing else will.
But since you have already stripped them, you are probably gonna have to cut them or split them (if there's clearance) with a nut cracker. Good luck, try not to eat too much rust
TedJ is offline
Old 05-02-2008, 12:17 AM   #17
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Either remove the cat and pound the honeycomb out or replace the cat with a new one. A while back I hollowed both cats out while they were still on the truck. Just took a really long pipe and a hammer. There's also some mesh in there that has got to be removed also.
__________________
91 Eddie
Old 05-06-2008, 05:13 PM   #18
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
'01 Ford Ranger, RIP 93 X
Vehicle Specs
Quoted: 13 Post(s)
i'll be doing this this summer. we don't have emissions checks, and i'm pretty sure the explorer puts out enough bad stuff
__________________
I haven't been on this forum in a while and I'm trying to work my way back into it. I'm going for Mod or bust!
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger Edge 5.0L Swap Thread
1991 Nissan 240sx Drift Pig
Blacksheep Josh is offline
Old 05-10-2008, 10:56 PM   #19
safn1949
Mankato, Minnesota
M60A1 my first offroader
Vehicle Specs
Quoted: 2 Post(s)
As I said in another post,if you are going to pound the honeycomb out of the cat,be careful that dust is a mean and poisonous thing,don't breath the dust.
safn1949 is offline
Old 05-10-2008, 11:45 PM   #20
Turdle
Move along people
Humboldt, KS
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 700 Post(s)
Please read
http://www.explorerforum.com/forums/...d.php?t=134980
Quote:
* Posts that are mean, derogatory, insulting or promote illegal activity may be removed from the board at the moderators/administrators discretion and can get you banned at the Administrators discretion.
Thread closed
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline
Closed Thread
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
