| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems. |
Thread Tools |
#1 |
Wannabe Elite Explorer
New Jersey
'97 Eddie Bauer
Quick and Easy Blend Door Replacement Tutorial
Blend door replacement:
Today's test subject is a 1997 Eddie Bauer Explorer. Hopefully yours will be somewhat similar. I’m going to assume that you’ve correctly assessed the problem, and that your blend door indeed needs replaced. You’ll come across all sorts of instructions on the internet for repairing your blend door. Forget them. It’s less than $10 for a replacement, and unless “you want fries with that” is part of your daily work routine, your time is worth more than the cost of a replacement. http://www.napaonline.com/MasterPage...r+Repair+Latch is the blend door from Napa. Please check that that part is correct for your year and model before ordering. I purchased the Dorman replacement kit from Rock Auto, but for some reason it isn’t showing up online now. Maybe I got the last one, sorry. The kit I received was really nice, with both a steel template for cutting the plenum to remove the blend door, and a self-adhesive steel panel to cover the hole when you’re done. The only problem is the kit assumes you’ve got access to the top of the plenum, and unless I’m mistaken, without a WHOLE lot of work, that isn’t going to happen. It also looks like the replacement door is made out of ABS, which should be a lot more durable than the cheap junk Ford made the original door from. What we’re going to do is do it the easy way (well, easier in any case), go in from the bottom. First, let’s get that glove compartment out of the way. Open it, and squeeze in the sides so you can open it fully to access the hinge. Using a #20 torx bit, unscrew the 3 screws holding the hinge to the dashboard. ![]() Next, locate the blend door actuator on top of the plenum, and remove the plug going to it. Tuck the plug someplace where it’ll be out of the way, but where it’ll be accessible again later when you want to hook it back up. NOTE: You really don’t have to remove the actuator if you know it’s working correctly, but it’ll be a LOT easier to install the new blend door if you do. Otherwise you’ll have to insert the new blend door in a position that matches the direction of the actuator’s stud, which could prove tricky. We’ll just assume that you want to remove it. If not, skip ahead 4 sections, and have fun installing the replacement! Depending on the year and possibly model/options, some folks have reported being able to pry the blend door actuator off of its mounting base. On my ’97 Eddie, I found it quite easy to do so after the actuator had been removed from the plenum, but not such an easy thing while it was installed. If you can pry it up without damaging anything, great (skip the next 2 parts). If not, get yourself a 5/16 wrench and socket. I used a ratcheting offset screwdriver and a 5/16 socket, for the back I was able to get a slightly longer “Great Neck” brand 5/16 socket from AutoZone which gave me the extra clearance I needed, YMMV. ![]() There are 2 bolts on the “front” side (facing the rear of the vehicle). One is easy. One is recessed behind part of the mounting base (hence the socket). The third is quite cruelly located on the opposite side of the actuator, where just about nothing can get to it. If you can, reach over the actuator and use your fingers to locate it, so you’ll know where the socket needs to get to. Once I got it aligned correctly on the bolt, I used one hand to keep downward pressure on the socket, to prevent it slipping off and assure that it was actually turning. I used the other hand to move the ratchet handle back and forth. There isn’t much room to do this, so if you can get one click per movement, you’re doing fine. If you feel like it, keep doing this until the bolt is removed. Otherwise, after about 30 clicks, you should be able to pry up the front of the actuator, and either cut the bolt with a hacksaw blade, or any other implement of destruction you deem fit for the job. I don’t know anyone who’se ever considered putting that bolt back anyway. ![]() Okay, now that we’ve got the blend door actuator removed, plug its connector back in, and cycle back and forth between hot and cold, ensuring that the “D” shaped stud protruding from the bottom of the actuator moves when you do this. If it does, and there’s no clicking from the actuator, it might be in good enough shape to go back in. If it doesn’t move, either replace it, or check your wiring to make sure there isn’t some other problem. In my case, both my blend door was broken, and its actuator was shot (click, click, click went the stripped gears). Finally, the moment you’ve all been waiting for; Removal of the old blend door. Take a good look at the bottom of the plenum. The circular area which sticks down is where the bottom of the blend door shaft sits. By the somewhat triangular shape of the area around that, you should be able to judge where the door travels. We’re going to cut along the back edge (facing the front of the vehicle), the front edge (facing the rear of the vehicle), the small section between those two (facing the passenger side of the vehicle), around the shaft seat area, and partially along the last side (facing the driver’s side). We don’t want to completely cut that side, as we’re going to pry it down like a flap. This will make it easier to close when we’re ready to. ![]() My weapon of choice is the roto-tool (Dremel, Craftsman, or whatever). I made a trip to Sears, and picked up a general purpose cutting bit for $3.99. It’s similar to a drill bit, but works like the blade in a roto-zip, and once inserted, can be moved laterally to make the cuts we need. ![]() Start in the back (facing the front of the vehicle), towards the center and work towards you. There’s a crease in the plenum along the back edge, let this be your guide and carefully cut along it. Next, cut the front edge (facing the rear of the vehicle), again on the corner where the flat surface meets the vertical one. Then cut the remaining short edge between your first two cuts. Carefully cut around the shaft seat, going about 1/3rd of the way towards the back (front of the vehicle) edge. At this point, see if you can bend down the flap like in the picture. If not, start at the back corner (front of the vehicle), and cut back towards you until you can. Once you can pry the flap down, you should be able to reach in and remove the old blend door. Feel around for any broken bits (never found mine) and remove any small plastic pieces left from your cutting (otherwise they’ll just blow all over you vehicle when you next turn on the air). ![]() ![]() Old Broken Blend Door ![]() The old and new Blend Doors side by side Insert the new blend door, large circular part upward. I found it easier if I put one hand over the hole on the top of theplenum, then I could tell when the new blend door was properly aligned. Slip the bottom stud into its seat. Rotate the blend door towards the front of the vehicle as far as it will go. This will put it into an alignment where it should be out of our way when we re-secure our flap. Push the flap back up into its original position, and secure it with a few thin strips of duct tape. Now we just need to seal it into its original position. There are a variety of different ways to do this, from epoxy to silicon to fiberglass to just plain duct tape, but I wanted something that would be fairly rigid when done, wouldn’t need replaced, wasn’t too messy to work with, and didn’t take forever to cure. I selected QuickSeal Plastic Repair Putty, JB Weld makes a similar product, both claim to cure in 4 hours. ![]() I opted to take a 2-stage approach to sealing the flap. I didn’t want to get much of the putty on the inside of the plenum where it might hinder the movement of the blend door. I also wanted to be sure I got the flap back in its original position. You could probably seal it back up in one shot if you’re careful. ![]() As seen in the photo, I sealed most of 2 sides, with the duct tape strips holding the flap in place. Once that cured, I removed the duct tape and filled in the rest of the holes. As the whole shebang will be hidden behind the glove compartment, there’s no need to make it look pretty, as long as it’s functional, you’ve done the job. Once your adhesive has cured, replace the blend door actuator. You may need to hook up the wires and cycle it back and forth between hot and cold a few times to correctly align the actuator stud with the blend door. Once that’s done, screw it back in place (or pop it back in its holder if you were able to pry it out without unbolting it), and check for proper operation of your HVAC unit. You should have hot heat, and cold air, and everything in between. Altogether, aside from the sealant curing time, it should take less than an hour to do the whole job. Under $20 worth of parts sure beats $1400 at the stealership. Last edited by Magicland; 04-27-2008 at 08:25 PM. |
| Sponsored Links (Less Ads) |
#2 |
2003 explorer
just to let folks know the 2003 ford explorer has had the blend door location moved so that it sits horizontaly behind the center console and as best I can tell Can't be changed. any help would be great.
#3 |
south carolina
97 eddie
heater blend door
i did the same repair and it worked perfect..
#4 |
Georgia
1998 Eddie Bauer
Blend door repair
Magicland, i am about ready to do your procedure and want to make sure i understand the result. After i do this, i will be able to set the tempature at, say 72, and the blend door will adjust for that tempature? Some of the remedies i read say that you will get either "AC" or "heat." Thanks, and thanks for the pictures.
#5 |
New Jersey
'97 Eddie Bauer
Provided the rest of your explorer's HVAC system is working correctly, it'll give you AC, Heat, or anything in between. Most of the other "repairs" involve cutting a hole and sticking the door in one position or the other, so you get one or the other. This is simply an easier way to replace the door, without removing your dashboard or other HVAC components to get to it.
In my case, both my blend door was broken AND my blend door actuator was shot. If that's the case, without replacing the blend door actuator, you'll only get whatever the actuator happens to be sitting at (heat, AC, etc.). You can confirm proper actuator operation by removing it from the duct, and seeing if it responds as you change the settings (or, as in my case, without removing it if it makes a loud clicking noise because of the stripped plastic gears). |
#6 |
Georgia
1998 Eddie Bauer
Magicland, I am about to begin the "surgery" part of this procedure (I did get the actuator off and it is working). I noticed in your photos that your cut of the plenum was beyond the knob (circular area) that the bottom post of blend door sits in. This seems like this could affect the operation of the door even after sealing it back up. Am i seeing your photo correctly -- that the cut goes beyond this knob which is part of the flap bent down? Does this affect the door operation? Thanks.
#7 |
New Jersey
'97 Eddie Bauer
The circular area is where the bottom of the blend door sits. I don't know if the blend door can be removed and/or installed if the cut doesn't include the circular area. It certainly would be safer to not include it, but then you might find you can't either get the old blend door out, or the new one in.
I don't know if the top of the door's shaft will be able to go up high enough to allow the bottom of the door's shaft to fit into the recessed circular area unless it is removed. I suppose you can try it and see, and if you can't get it in or out, then make a 2nd cut to partially include the circular area. Of course, then you'll have slightly more patching to do if you have to include it later. I haven't had any problems with mine, however that's no guarantee that you won't. This isn't a factory-approved operation, so YMMV no matter which approach you choose... |
#8 |
Georgia
1998 Eddie Bauer
Magicland, your solution worked. Thank you for the instruction.
#9 |
ALL FIRED UP
Raytown MO (Kansas City suburb)
1997 Mountaineer 5.0
Just did mine today. If it were not for this thread I would have ended up pulling the complete unit (which is a biatch).
I'm so happy now since I won't be roasting my ass off come this winter. ![]() I forgot to mention on mine I used the foil tape made for home furnace ducting to tape the cut out piece up. __________________ P r i c k me, do I not bleed Ford Blue. Last edited by Dan Whitaker; 08-30-2009 at 12:37 AM. |
#10 |
North Charleston, SC
1996 Ranger
Great instructions
Be sure to follow these instructions carefully. I began to cut a larger hole than necessary, slicing into the heater core...OOPS!
#11 |
Yukon
1998
Awesome!!!!
This saved so much time and money. I was able to get a door and actuator at the wreckers for a great price. I had to extract it myself, which is a bit messy without the Dremel; however, still better than the Ford option - whole new plenum for about $400 (not in stock of course).
To make the cuts, I used the Dremel high speed cutter (#199). It is like a little circular saw blade and will reduce the chance of puncturing the heater core as it only breaks through the plastic. It is a little trickey getting contorted to access the cutting positions. Maybe warm up and stretch first! Thank for the great tutorial. It will be nice to have heat again. Cheers. |
#12 |
Gibraltar, MI
1997 XLT
Thank You ! Very much ! From the minute I figured out the problem with the heat ,and the time , broken skin and twisted limbs it would take to replace the door I was thinking I could just cut through the bottom, but I didn't and started to remove the dash. I got a half hour into it and decided to look for help and found your thread. This is the most helpful information I've ever gotten off a web page at the time I needed it. ............Thanks for taking the time to post this and the pictures.
#13 |
Sag Harbor, NY
'98 XLT
Verifying cut
Hello,
Looks like I will be attempting the repair in the next week (as soon as my blend door is delievered). I'm encouraged by the success rate by other posters on this forum. There is one question I have. I looks like the first 3 cuts are very intuitive, the firewall side the rear-facing side and the passenger side between the two. When making the cut around the cylinder where the blend door seats, I'm a little unclear about what needs to be cut. It looks like the dremel cut goes down a little bit toward the floor so that the remaining side can be bent. When I look at the bent down flap in the photo, I can not tell if there has been a cut made along that last edge (toward the driver's side). When I look at the photo where the epoxy is placed, it infers that the whole driver's-side edge has been cut given that epoxy has been placed along the whole edge. However, the instructions don't really say to cut across the whole edge so I'm a little unsure. Would it be accurate to say: Cut around the seat so that the bend point is behind the seat and, if need be, cut the driver's side a little at a time so that you can bend the flap? Thanks for this post. This is the one part that I was a little unclear about. It's a little tough to see where the cuts were made from the before and after photos. |
#14 |
New Jersey
'97 Eddie Bauer
In my case, only the 3 sides were cut, the fourth (as seen in the picture) remained connected and the "flap" was just bent down enough to allow removal and insertion of the blend doors. Take care cutting around the round "seat" area, which is where the bottom of the blend door shaft rests. You'll want the shaft to be able to move freely.
#15 |
Sag Harbor, NY
'98 XLT
Hmmm. Ok, then why in the photo is there epoxy on the driver's side along the side that has not been cut? Just for reinforcement due to being bent down?
#16 |
New Jersey
'97 Eddie Bauer
Upon further review, I think I cut most of the way along that side (might have needed to to get it to "flap". It's been a while. The "flap" piece wasn't completely disconnected from the duct.
| Thread Tools | |
