Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
1991 explorer fuse panel diagram
Reply
Thread Tools
Old 05-01-2008, 04:05 PM   #1
jamenblack
Islad Park, NY
'91 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
how can I find a diagram to the fuse panel of my '91 xlt if I don't have the owner's manual? It's not in the Hayne's repair manual either. If anyone could help me with this I sure would appreciate it
jamenblack is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-01-2008, 04:26 PM   #2
Old Hippie
Spartanburg, SC
93 XLT 4x4
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Fig. 7: 1991 Explorer 4.0L engine wiring
Fig. 8: 1991 Explorer body wiring
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Hippie is offline   Reply With Quote
Old 05-01-2008, 05:16 PM   #3
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Quoted: 3 Post(s)
Dk Exp
the above post was the wiring diagram,
here's the fuse panel layout
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
fixxxer is offline   Reply With Quote
Old 05-01-2008, 08:07 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
Welcome to this forum!
BrooklynBay is offline   Reply With Quote
Old 08-09-2008, 01:50 PM   #5
kaneda_77
Honolulu, HI
'94 XLT
Vehicle Specs
Quoted: 0 Post(s)
thanks, that was helpful. i lost my owners manual and its not printed on the plastic cover like on other cars.
kaneda_77 is offline   Reply With Quote
Old 04-14-2013, 05:52 PM   #6
jwfelts
R.Rapids NC
1991
Vehicle Specs
Quoted: 0 Post(s)
I have a 1991 Ford Explorer that has not been driven in two years and would not start. I read the codes, replaced the fuel pump, and started the engine with no problem. It seemed to be running fine until I put it in gear and drove it down the road. It begain to spit and sputter and had no power at all. I can push the gas petal to the floor and it will only go slow. I returned home and put the transmission in park and it seems to idle fine. Do not have a clue what could cause this problem. Please Help!
jwfelts is offline   Reply With Quote
Old 01-03-2014, 02:47 PM   #7
FatherMcD
1988 F250
Vehicle Specs
Quoted: 0 Post(s)
Ground issue?
If you haven't already fixed this, check the fuel pump ground. I have a '94 ranger that had similar symptoms. If you have a fuel pressure tester, check that the pressure stays in the 20+ psi range when you open the throttle. Does your fuel gauge read empty when you still have 4-5 gals in the tank? I found over 80 ohms between the ground wire from the fuel pump that connects to the grounding bolt on the top of the drivers side fender under the hood and the battery ground. (Your ground connection may be in a different place and ALWAYS test to the negative post on the battery, not the wire connected to it.) I replaced the connector on the end of the wire and resistance dropped to less than 1/10 ohm. Fuel gauge problem fixed, but still had the low pressure problem. The connector to the fuel pump on top of the tank looked charred so I pulled the pump and found obvious overheating in the wiring. High resistance at the same voltage requires higher amps to provide the power, hence the wiring was burning out between the connector and the pump, and the pump itself was nearly fried. Replaced the pump/sender and was able to remove the wires from the old connector on top of the tank and clip them into the new one. (the connector was charred, but the wires themselves were OK) You've already replaced the pump, but a weak ground will cause it to have low output and eventually burn out. I suspect that is what happened to your original pump. I had been having driveability issues with this truck for months, but couldn't pin them down. This fixed them. Hope this helps!
FatherMcD is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
