EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Show Off Your Sport Trac!
Reply
Thread Tools
Old 07-19-2012, 02:00 PM   #1841
Travis Stevens
Sterling, PA
2005 Sport Trac Adrenalin
Vehicle Specs
also if anyone is curious im running 22 psi in all 4 tires and getting even treadwear... this is how i figured it out...
Take the max weight that the tire can support (on sidewall) and multiply that by 4. This gives you the total weight that all four tires can support. Next take the weight of your truck and divide that into the total weight. You should get around 1.5-2 something. Now divide this number into the max psi stated on the sidewall and you'll have your ideal air pressure.
For instance:
2500 lbs at 35 psi max
2500 x 4 = 10000
My trac with addons 6000 lbs
10000 / 6000= 1.6
35/1.6 = 21.875 psi
My dad taught me this formula years ago when i started driving because we never had chalk laying around to use. Since i was 16, i've never had any uneven wear on any of the tires of my vehicles. It works great!!!
Travis Stevens is offline   Reply With Quote
Old 07-19-2012, 02:17 PM   #1842
interscope8
Purdue University
2001 Sport Trac 4x4
Vehicle Specs
Purdy!!
How does that super lift do with the front end wear?
__________________
2001 Sport Trac 4x4- Being tweaked one weekend at a time!
Clarion CZ500 Head Unit, 4 Hifonics Zues 3 way Speakers, 2 Fosgate R2's, 1210w of power, RS5000's, TT/ Shackle Lift, Bull Bar
Learn by Doing
interscope8 is offline   Reply With Quote
Old 07-19-2012, 02:24 PM   #1843
Travis Stevens
Sterling, PA
Vehicle Specs
i havent had it on long enough to really give a good answer but IMO the wear will come from the oversized tires on the balljoints and hub bearings but im ok with that cuz all my parts are warrantied... but so far so good
Old 07-19-2012, 03:07 PM   #1844
Gse Brent
Small Wonder
Gse Brent's Avatar
2001 Explorer Sport Trac
Vehicle Specs
Quote:
Originally Posted by Travis Stevens View Post
been a while since i posted pics of my trac... so heres an update... i now have 4" superlift, 3" body lift, 2" TT and shackles and am running 35 12.5 15 cooper discoverer STT's on procomp 98 15x10 with 3.75 BS... tell me what you think
Very nice! You going to carlisle truck nationals in a couple weeks?
Gse Brent is offline   Reply With Quote
Old 07-19-2012, 03:09 PM   #1845
Gse Brent
Small Wonder
Gse Brent's Avatar
Vehicle Specs
Take the max weight that the tire can support (on sidewall) and multiply that by 4. This gives you the total weight that all four tires can support. Next take the weight of your jeep and divide that into the total weight. You should get around 1.8-2 something. Now divide this number into the max psi stated on the sidewall and you'll have your ideal air pressure.
For instance:
2000 x 4 = 8000
10000 / 6000= 1.6
50/1.6 = 21.875 psi
Good info i'll have to take that into consideration since i'm running 33x13.50s.
Old 07-19-2012, 04:33 PM   #1846
TGtrac05
Texas A&M University
2005 Sport Trac XLT
Vehicle Specs
finally finished off my system. Ended up with a 10 inch RE audio rex series sub, and Memphis SR series amp 250 watts @2 ohm. Perfect sound I was looking for
__________________
05 ST 2wd, 3" PA BL, Hankook Dynapro AT 265/70 r16, Pioneer head unit, JL door speakers, 10 inch RE audio sub, Memphis audio amp, de-badged, 15% tint, plasti-dipped cladding, LOTS to come
TGtrac05 is offline   Reply With Quote
Old 07-21-2012, 06:13 PM   #1847
WidgetTrac
Cypress, TX
2001 Sport Trac 2wd
Vehicle Specs
Red Exp
Wow, there are some awesome and very nicely modified Tracs in here!! Mine is still pretty much stock and getting kinda run down now, after 12.33 years and >125k miles of remarkably dependable and versatile service. Here it is from many years ago, all shiny and almost new:
Aside from consumables - filters, oil, brakes, batteries - the only thing i've had to replace was the thermostat... a $5 part! I'd call that low-maintenance. The original 255/70-16 Firestones still looked halfway decent when pulled off at 44k to be replaced with Michelins under the recall program, then those lasted another 67k, so up to about 112k I was riding on "OEM" rubber to boot!
Actually, I still haven't had to buy tires - when the "replacement" michelins finally quit, I put on a still-useable set of 245/70's I got when my dad put snow tires on his mountaineer - also Michelins from the recall program. They're about down to the wear bars now in addition to being very old, so I took some "before" pics with the worn out 245's and torsion twisted up:
WidgetTrac is offline   Reply With Quote
Old 07-22-2012, 09:53 PM   #1848
LONO100
Bay Area CA
LONO100's Avatar
03 sport trac XLT
Vehicle Specs
got some new pics of the trac while on my latest exploration into the sierra mountains. while exploring, we found a free campground that was pristine and beautiful.
some flex shots
a few more
LONO100 is online now   Reply With Quote
Old 07-23-2012, 02:09 PM   #1849
WidgetTrac
Cypress, TX
2001 Sport Trac 2wd
Vehicle Specs
Pristine and beautiful indeed!!! what was the elevation there? I would have to drive a loooong way to get to somewhere that nice!! Trac looks good too- I read your buildup thread or registry or whatever where you started from stock and showed each mod up to where it is now - nicely done!
Mine is all stock, just TT and step bar delete. Tires and body mounts are toast, and shocks and UCA's are getting pretty worn as well. It's a 2wd, but I don't always keep it on pavement so the replacement parts will be more offroad oriented.
Before they built houses here I think it was rice fields, for miles & miles around, flat as a pancake! This is a vacant lot by the big ditch at the back of my neighborhood - I had to snap the pix FAST, before somebody called the cops!
Seriously, there is a network of giant drainage ditches around here, with nice wide grassy trails on both sides and also pipelines and ginormous power lines with grassy right-of-ways that are like 1/8th mile wide. They are all veeery tempting to go driving around on, pero es verboten!!
Old 07-23-2012, 02:17 PM   #1850
interscope8
Purdue University
2001 Sport Trac 4x4
Vehicle Specs
Somebody would call the cops for snapping pics in a vacant lot?? Jeesh. Out here no one gives a rats *ss about anything as long as their corn stays unharmed lol.
Clean, can't wait to see mods start
__________________
Learn by Doing
Old 07-23-2012, 06:54 PM   #1851
TGtrac05
2005 Sport Trac XLT
Vehicle Specs
I hate that there's no legal places to off road around me. Used to be able to at this river close to me, but they stopped that. Spring Creek off road park used to be big, then that closed. I'm about to go to school at A&M Galveston and there used to be tons of trails to ride there, now that's closed...no hope
__________________
Old 07-23-2012, 08:29 PM   #1852
LONO100
Bay Area CA
LONO100's Avatar
03 sport trac XLT
Vehicle Specs
thanks widget, the elevation was somewhere between 5500-6000 ft.
TG - there's hope. its called the west! if you want the great outdoors, move west. starting in colorado and the rockies, to southern utah and the great northwest, to my home, california. where i live, i can reach deserts, mountains, forests, snow, beaches, lakes, rivers, city life, and yosemite all within 2 hours of my house. if you dont believe me, just check out my previous explorations. all within a few hours drive of my garage. before the summer ends, im planning on visiting the redwood forests, a few ghost towns from the gold rush days, and in the fall im planning on my first mojave desert run with some buddies, and maybe even hitting up the nextg truck haven.
Old 07-23-2012, 09:10 PM   #1853
LONO100
Bay Area CA
LONO100's Avatar
03 sport trac XLT
Vehicle Specs
one more
Old 07-23-2012, 10:22 PM   #1854
OffTrac
Dublin, GA
OffTrac's Avatar
'01 Sport Trac 4x4
Vehicle Specs
Lono, I think you have the most photogenic Trac on here. The backgrounds might help.
__________________
My Registry
OffTrac is online now   Reply With Quote
Old 07-24-2012, 12:10 AM   #1855
LONO100
Bay Area CA
LONO100's Avatar
03 sport trac XLT
Vehicle Specs
thanks trac, i think its the backgrounds that do it.
Old 07-24-2012, 12:22 AM   #1856
WidgetTrac
Cypress, TX
2001 Sport Trac 2wd
Vehicle Specs
Yeah that last one rocks! Usually when I'm in the mountains they're all covered with snow, but I have spent some time in southwest Colorado in the summertime. It's very nice, but the trees don't look as cool as the ones at Lono's campsite.
Scope, I was mostly trying to be funny, contrasting the serene mountains with the overcrowded city. but there is a grain of truth in the joke... I doubt anybody would hassle me, unless the lot is owned by one of the homeowners across the street - which I doubt. There is also a water plant across the street, and I think the lot is probly utility district or flood control land, so if any of "those people" came around they might run me off.
TG, you're in my old neck of the wwoods - does Spring hs still have the old ratty lion in the entrance?
Old 07-24-2012, 10:57 AM   #1857
shooterdude199
Irmo, South Carolina
01 Sport Trac
Vehicle Specs
alright guys its been a while since ive posted. been very busy but here are some shots of the a arms:
all finished up:
gonna get the hoops done thursday and bolt everything on friday hopefully. ill try and see if ill be able to snap some pics as this is a pretty big project especially for one to handle. the builder is really helping me out with it. hopefully before anything i can integrate a bumpstop pad for the hydros. which also need to be welded on. let me know what ya think! special thanks to CFS Off road!
__________________
My Registry
shooterdude199 is offline   Reply With Quote
Old 07-24-2012, 01:10 PM   #1858
TGtrac05
2005 Sport Trac XLT
Vehicle Specs
Widget, I actually live in The Woodlands so I'm not sure about Spring hs since I don't get out of the bubble often haha. But I'm ready to.
__________________
Old 07-24-2012, 07:46 PM   #1859
zTeeJay
Mcleansville NC
03
Vehicle Specs
new to the forum hears my Trac
zTeeJay is offline   Reply With Quote
Old 07-24-2012, 07:48 PM   #1860
zTeeJay
Mcleansville NC
03
Vehicle Specs
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
