EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2004 Ford Explorer Cruise Control stopped working
Reply
Thread Tools
Old 05-12-2008, 08:06 PM   #1
Lurch16th
2004 Ford Explorer
Vehicle Specs
(Original Poster)
Cruise Control won't even turn on. Any idea what the problem is and how to fix it?
Lurch16th is offline   Reply With Quote
Old 05-13-2008, 07:45 AM   #2
Curtis
Orlando, FL
04' and 96' XLT's
Vehicle Specs
Does your abs light come on? There are known problems that cruise will quite if the abs light is triggered.
I have an 04 too. abs light on.
my cruise doesnt work.
I know its the abs pressure switch. its only a $20 part, but havnt done it yet.
__________________
Curtis
2008 Expedition EL Limited
2004 Explorer XLT 4x4 4.6
1970 Buick GS 455 Silver Mist
Curtis is offline   Reply With Quote
Old 05-13-2008, 08:32 AM   #3
Lurch16th
2004 Ford Explorer
Vehicle Specs
(Original Poster)
hmmm, well the abs light had come on once in a while, would stay on for a few minutes. But next time i would drive it it would be off. Never noticed at what point the cruise control stopped working. So does this mean that any time the abs light comes on and the crusie control stops working, it needs the new pressure switch?
Old 05-13-2008, 09:06 AM   #4
Lurch16th
2004 Ford Explorer
Vehicle Specs
(Original Poster)
I guess i should guet this straight in my head. If the abs light goes on, eventually goes off and stays off, the cruise still won't work because of that switch? My abs light hasn't been on for weeks, but cruise still doesn't turn on, no indicator light or anything.
Does the cruise have a fuse somewhere that can blow?
Old 05-13-2008, 10:38 AM   #5
Curtis
Orlando, FL
04' and 96' XLT's
Vehicle Specs
Not sure .. .my abs light comes on daily...
__________________
Curtis
Old 05-14-2008, 10:15 AM   #6
dmstangu
Arlington, VA
2004 Explorer XLT
Vehicle Specs
Check the circuit break switch under the brake pedal. It may stick and CC thinks you are braking, therefore will not engage. At a stand still, press the brake pedal, then get out of the car and check if the brake lights are still on.
__________________
"Better to remain silent and be thought a fool than to speak out and remove all doubt" - A. Lincoln
dmstangu is offline   Reply With Quote
Old 05-14-2008, 10:26 AM   #7
Lurch16th
2004 Ford Explorer
Vehicle Specs
(Original Poster)
ok, just checked brake switch. foot on brake, brake lights on, Brake off, brake lights off.
Old 05-14-2008, 10:54 AM   #8
Lurch16th
2004 Ford Explorer
Vehicle Specs
(Original Poster)
Just installed a new pressure switch on the master cylinder and No Joy.
Old 05-18-2008, 06:50 PM   #9
Lurch16th
2004 Ford Explorer
Vehicle Specs
(Original Poster)
Very odd situation, but appears I fixed the Cruise control, by fixing something else.
Upon routine check and (a hunch)of air cleaner, I found the air cleaner housing, was stuffed about half full with a mouse nest. I cleaned out the nesting material and duct taped a piece of aluminum screen around the inlet hole in the chassis, behind the headlight.
Day before i pulled and checked All color-coded fuses inside and out, which may have cleared PCM memory.
End Result: Took the car on a errand trip and it appeared to be running rough and re-adjusting itself. On the return trip, the Cruise Control worked.
So possibly the stuffed air cleaner housing sent some false info to the MAF and it shut down the cruise control.
Then either pulling the fuses, or cleaning out the housing or both, caused the systems to reset or give proper data, allowing the cruise to work.
This is the 3rd or 4th time the rodents have done this to my vehicles. something to keep an eye out for.
thas all
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
