EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
odometer on 1996 x sport
Reply
Thread Tools
Old 05-15-2008, 08:43 PM   #1
sino
New York
sino's Avatar
2001 SOHC Sport
Vehicle Specs
(Original Poster)
Question odometer on 1996 x sport
whats goin on ppl..
well i was originally supposed to buy a 99 x sport and wound up not getting it because some one else came with a better offer but that didnt stop me from getting an x sport.. so boom.. i just bought a 96 sport for $1800 with only 2 problems that i wanna fix as fast as possible..
one is that the passenger window wont go down, i dont think it would be too much trouble with getting that fixed right?
& two is that odometer isnt working.. it reads 65,xxx miles but the guy said that it hasnt worked for awhile so he cant assure me that there aren't too many miles on this truck. it runs great i must admit but now i need to get it inspected..
do you think that there will be a problem with this truck passing inspection with the odometer not working? & do you have any advice or suggestions on how to or where to get my odometer fixed? im on long island .. let me know.. thanks ya'll..
-sino
sino is offline   Reply With Quote
Old 05-15-2008, 08:49 PM   #2
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Welcome to the forum
The odometer is motor driven right at the instrument cluster-
usually a small worm gear-or driven gear breaks causing this problem
use this thread to access the instrument cluster
http://www.explorerforum.com/forums/...ndiglo+install
For the windows, there are some power window relays near the gas pedal-
also-check all of the fuses,
try opening the door a bit-move the door around and see if the wndow operates intermittently. This would indicate a wiring problem
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is online now   Reply With Quote
Old 05-15-2008, 09:05 PM   #3
sino
New York
sino's Avatar
2001 SOHC Sport
Vehicle Specs
(Original Poster)
very informative thread thanks!
but when i get to the cluster, what
am i looking for to know what to fix?
Old 05-15-2008, 09:14 PM   #4
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
OK
first-you need to note the position of the needles when you turn the key on-after the truck has sat all night. Be sure it is cold.
then, once you remove the cluster-
you'll need to dis assemble it. It will take a while, just be patient.
You'll need to get behind the odometer-and gain access to the small gears driving it. You will know it when you see it.
to remove the needles-wrap fishing line around the center near the shaft, making a loop. This way you can get a pulling action from two sides.
When you complete the repair, leave the clear window off-plug the cluster in and switch the key on. Install the needles in the positions you noted.
Or--
you can look on ebay for another cluster--
I have no idea how you'd get the little gears without another cluster anyway
__________________
Jon
2000 Mountaineer
Turdle-gone
Old 05-15-2008, 09:30 PM   #5
sino
New York
sino's Avatar
2001 SOHC Sport
Vehicle Specs
(Original Poster)
thanks.. lol
ill take those steps
to actually make it the cluster first
just for personal knowledge and then i guess
ill be off to buy another cluster .. lol .. thanks again jt!
-sino
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
