Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Offroad Runs and Events > Meet and Greet and, International Explorers > UK Explorer Owners Forum
Notices
Lucas auto transmission stop slip-any good?
Reply
Thread Tools
Old 05-17-2008, 04:36 PM   #1
SB98UKexplorer
UK croydon
98 explorer 4.0 SOHC v6
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
on ebay here Item number: 220233199861
says:
Lucas Transmission Fix has a polymetric film which renews worn bands to stop slipping. It cleans and lubricates sticking valves for proper shifting and controls heat and foaming. This product will extend fluid life up to three times longer. It completely stops most seal leaks and results are usually immediate. It is the perfect preventative maintenance product to stop initial wear in newer transmissions, and is a must for motor homes, towing vehicles and all other hard working transmissions.
is this worth buying to sort my flare 2-3 or just a waste of time and money?
__________________
OBX headers,75mm TB,decats,true duals,screamin demon CP,walbro255 FP,FSE fuel reg,KYB shocks,LED interior
SB98UKexplorer is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-17-2008, 05:24 PM   #2
rich uk
surrey
1998 sohc 150k Purple LPG
Vehicle Specs
Quoted: 0 Post(s)
Hi sb
I put wynn,s conditioner in mine and it stopped the leak I had and improved how the box worked,but I had it in there a week only because I put the wrong fluid in....doh..... but I was advised not to use it because it can soften the seals which can make them wear more quickly.
dunno if that helps m8 looks like different stuff plus its more expensive sounds good tho if it works
rich
rich uk is offline   Reply With Quote
Old 05-17-2008, 06:12 PM   #3
SB98UKexplorer
UK croydon
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
i think ill actually have that solinoid replaced to be on the safe side, found it Item number: 200213825528 on ebay, the shipping fee is 55 quid but its only 25quid, i dont think thats stocked here in the UK???
__________________
Old 05-17-2008, 07:15 PM   #4
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
'01 Ford Ranger, RIP 93 X
Vehicle Specs
Quoted: 13 Post(s)
Quote:
says:
i used this when my transmission was starting to go. it fixed it for about 5-6 months until it finally went and when it went it killed itself.
i've purchsed this at the local auto store, you might be able to do the same.
__________________
I haven't been on this forum in a while and I'm trying to work my way back into it. I'm going for Mod or bust!
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger Edge 5.0L Swap Thread
1991 Nissan 240sx Drift Pig
Blacksheep Josh is offline   Reply With Quote
Old 05-18-2008, 01:55 AM   #5
kevin p
Telford Shropshire England
97 4.o sohc
Vehicle Specs
Quoted: 15 Post(s)
UK
I thought it was a wonder cure but alas the symptoms came back after about 3 months.
I've posted about a company called 'sonnax' before.
They do all manner of repair kits for the valve body block. Nobody seems to have responded before about their site.
If you look at their kits for the 5R55E they describe what syptoms the kits cure.
I would say that nearly all the syptoms people are having problems with are valve body block related.
It could even just be the valve body block seperater gasket that has developed a leak.
I took my sump off to get to the solenoids and they tested okay with an OHM meter, but this doesn't mean that they arn't sticking in the bores.
Please read about 'sonnax' and make sure you ain't wasting your money. They really sound as if they know what they are talking about.
Kev.
kevin p is offline   Reply With Quote
Old 05-18-2008, 02:56 AM   #6
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
What's the link to your thread on Sonnax? I've used Lucas for many years in many different transmissions. It does not completely cure everything. It causes seals to swell temporarily to make a tighter bond, but parts eventually wear out, and have to be replaced.
BrooklynBay is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
