Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Throttle Cable (s) ?
Reply
Thread Tools
Old 05-17-2008, 04:44 PM   #1
pugsy
Toronto, ON
'92 XLT 4x4 (4 door)
Vehicle Specs
(Original Poster)
A4LD Tranny Kickdown Cable
I've done the zip tie throttle cable fix, but when down there, I saw another cable that apears to just be hanging there. Not sure if it's an old throttle cable that has broken and no one removed it or if it's supposed to be attached to the accerator pedal. There's 2 groves in the pedal - one has the throttle cable in it (the one that works), and the other grove is empty. Is there supposed to be anything in there?
Also, I attached a pic of the firewall side from under the hood. The gromet on the right is the hood latch, the middle one is the throttle cable, and the one on the left is a wire that runs to the transmission gear selector. The one of the left, I'm not sure if that's the cable that's just hanging there on the inside of the cab. Is a cable supposed to go from the pedal to the transmisssion?
Thanks for the help. The pics explain it a bit better!
pugsy is offline   Reply With Quote
Old 05-17-2008, 05:02 PM   #2
Masterd
Upland, CA
1993 Explorer Sport
Vehicle Specs
Kickdown cable?
Masterd is offline   Reply With Quote
Old 05-18-2008, 12:47 AM   #3
pugsy
Toronto, ON
Vehicle Specs
(Original Poster)
what's a kickdown cable?
Old 05-18-2008, 01:16 AM   #4
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
1993 Ford Explorer XLT
Vehicle Specs
Quote:
lol. i'm wondering this as well
__________________
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger (New!!)
"You can hear me when I'm coming" - Yung Joc
Blacksheep Josh is offline   Reply With Quote
Old 05-18-2008, 01:22 AM   #5
little x
SW VA
'91 XL
Vehicle Specs
Connect it up. When you floor it hard the tranny will automatically "kick down" a gear, maybe 2. You'll have a much better shifting tranny with it connected.
little x is offline   Reply With Quote
Old 05-18-2008, 10:53 AM   #6
pugsy
Toronto, ON
Vehicle Specs
(Original Poster)
There's more then enough slack that if i connect it, it won't be doing anything...that's why I thought it was an old throttle cable. My tranny shifts fine and kicks down a couple gears good when i floor it.
Old 05-18-2008, 08:06 PM   #7
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Well its going to kickdown anyway becuase the modulator senses a difference in engine vacuum but with the cable connected it will do it sooner and when its supposed to.
__________________
91 Eddie
Bunch 'O' Mods- 35's, winch, gears, blah blah
www.southernxplorer.com
91exploreron37 is offline   Reply With Quote
Old 05-19-2008, 12:25 AM   #8
pugsy
Toronto, ON
Vehicle Specs
(Original Poster)
I see. Well, it seems to run fine and shift good as is.
Upon further investigation, the housing for the kickdown cable is all rusted out and broken, that's why there's so much slack, as the wire is supposed to pull on the tab on the tranny but with the lack of the hard housing in place, there's just a loose wire.
To the tranny guru's out there....is it necessary to replace the kickdown cable? I've been driving for God knows how long now without it - will it affect/hurt/stress the tranny more with out it? It's obviosly there for a reason?
Where can you get a replacement and how do you go about replacing it?
Thanks guys!
Old 05-25-2008, 10:48 AM   #9
pugsy
Toronto, ON
Vehicle Specs
(Original Poster)
Well, I picked up a kickdown cable that's in perfect shape at the scrap yard for $10. Installtion was very easy and it just snaps in, no tools needed. Adjustment was straight forward with the adjustment button, as long as you have someone to press the pedal when you hold the adj. button in. Once it's set that way, minor tweaks were necessary to make sure I had full travel of the gas pedal and that when the pedal was pressed to the floor, the piece that cable is attached to on the tranny is pulled to it's full fwd. position.
One thing I noticed after connecting it that didn't happen before was that now when I hold the pedal to the floor (when passing for example), the tranny will hold the lower gear longer or until I let off the gas. Where as before when the cable wasn't connected, it would upshift too early, limiting the power when passing.
All in all, I'm glad I reconnected it.
Old 05-25-2008, 03:16 PM   #10
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer A4WD
Vehicle Specs
Bingo, well done, that's what it was for.
__________________
Don
91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Old 05-26-2008, 09:34 AM   #11
boggs1227
Flowery Branch , Georgia, 1994 sport 2wd auto
2005 colorado 2wd 5spd
Vehicle Specs
hey ....i like yall to know after reading the thread here and reading the past threads of zip tieing the throttle cable fix ( read it but never did it till a few days ago ) and boy let me tell you .....it's almost like driveing a new truck
( lol ) .before when i would head out down the road i would give the gas a 1/4 push and the truck responed well but getting up to final drive maybe took 20 seconds but now i have to be carefull because now i can get into final drive in about 10 seconds ....no more lagging at red lights or trying pull out quicklly into traffic ! for a quick performance mod to do for the explorer this is a breath of fresh air so to speak .
i'm interrested in seeing what happens when i zip tie the other cable ...maybe the truck will shift quicker (not that the transmission is shifting badlly by any means ((just had it rebuilt)) ...we'll see tho !
__________________
Scott .
boggs1227 is offline   Reply With Quote
Old 05-26-2008, 10:25 AM   #12
pugsy
Toronto, ON
Vehicle Specs
(Original Poster)
Boggs...you shouldn't have to zip tie the kickdown cable, there's supposed to be slack in it at rest.
There's a "self adjuster" under the hood (see my pic above). What I did was hold the adjust button in so the unit will "slide", then have someone stab the gas to the floor. This will adjust it properly. You may need to tweak it a bit to give slightly more pull at full throttle though.
There's supposed to be slack in the kickdown cable - as the tension that pulls on the tranny is only needed at full throttle. If you zip tie the kickdown cable like the trottle cable, you'll find that your gas pedal won't go to the floor anymore.
Let me know if you have any questions on it.
Old 05-26-2008, 08:11 PM   #13
boggs1227
Vehicle Specs
ahh... did not know that ...thanks ,i think for now i'll just leave that alone.the truck shifts good enough with out doing anything more to it after thinking about it .besides i dont want to screw up my warranty on my transmission just incase anything does happen .
__________________
Scott .
Old 10-19-2009, 03:50 PM   #14
Pdwight
North West Alabama
94 Limited
Vehicle Specs
I know this is an old thread but where is the picture , I need to do this to my 94 Limited
Thanks
Dwight
__________________
A hundred years from now it will not matter what my bank account was, The sort of house I lived in, or the car I drove, But the world may be different because I was important in the life of a child
Pdwight is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
