#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
What is Limp Mode?
Reply
Thread Tools
Old 05-19-2008, 05:18 AM   #1
no164ford
N-Cambria PA
2000 Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
What is Limp Mode?
I am haveing probblems with my 2000 explorer tranny and have been reading over old post to see if I can find any info. I keep seeing " transmission going into limp mode"? I think this is what mine is doing. What does this mean, How does the tranny react when this happens?
Thanks, Paul
no164ford is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-19-2008, 07:44 AM   #2
jimbo74
Elite Ranger
Nor*Cal
jimbo74's Avatar
98 XLT Supercab 4x2
Vehicle Specs
Quoted: 0 Post(s)
basically, the system detects a problem, and then dumbs down its sensor inputs to barely reacting to anything.... its like brain damage, but not permanent.... the computer senses there is a problem, and cuts off what it wants to do to just barely function to save itself from further damage
__________________
My Truck
jimbo74 is offline   Reply With Quote
Old 05-19-2008, 08:05 AM   #3
Mbrooks420
High Voltage.
Erie, Pennsylvania
Mbrooks420's Avatar
1998 Mountaineer
Vehicle Specs
Quoted: 2 Post(s)
Welcome to the site. Do you have a Check engine light, or flashing OD lights? If not then I doubt your going into limp mode. if so then there are codes stored in memory and you need to have those scanned. With a code someone here can point you in the right direction. What is the trans doing? Shifting sluggish, not holding a gear, waiting to long to shift?
__________________
1998 Mounty 5.0 AWD TT/Shackles/rear AirLift springs 31x10.5 Kelly TSR's
1995 Subaru Legacy AWD Sedan RIP---Killed by an suicidal deer
1972 El Camino---Project Dirty Old Chevy---Fresh Marine Longblock .060 over, Forged crank RV Cam 454/th400 swap, Hooker Headers, fresh coat of white
1999 KTM 300exc RaceTech Suspension, Rekluse Slipper Clutch, single track killer
Mbrooks420 is offline   Reply With Quote
Old 05-19-2008, 08:26 AM   #4
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
It's a fail-safe programming strategy that the system reverts to in the event there is a fault detected with the system. For example, if the VSS was to say, short out, and it saw 150 mph in 1st gear, the system would say, "That sensor must be off because it's way out of range. Use this programming strategy to run the trans for now, store a trouble code, flash the lights, and limp-home until the sensor reading is back in its specified value."
Make sense?
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 05-19-2008, 10:22 AM   #5
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! In FMEM or limp mode, the computer increases the pressure threshold of the EPC solenoid to apply more hydraulic pressure to the internal pistons, clutch packs, and valves in a situation where there might be some sort of malfunction. In regualar driving, it's not necessary to have such high pressure, but if a part is leaking like the valve body gasket, the vehicle won't be able to go into gear unless it has sufficient pressure to apply the before mentioned parts.
BrooklynBay is offline   Reply With Quote
Old 05-19-2008, 06:09 PM   #6
no164ford
N-Cambria PA
2000 Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy
Thanks for the anwers, I figured that it was something like that. Here is my probblem.
I have a 2000 4.0L 4x4 5 speed auto 5r55e I think 74,000 miles We bought it about 3 months ago and I don't know the history of the car except that it was vary well taken care of the thing is almost like new. My wife drove it for about 1,500 miles after we bought it then on a normal 20 min trip the od light started flashing, she turned the car off and restarted it and the light quit flashing brought it home and told me.
I took it for a ride to see what was up transmisson shifted great and still does untill around 15-20min running then the od starts flashing. When the od is flashing if you come to a stop and try to pull out it is stuck in 5th gear and will stay there untill you shift it into N then back to D then it pulls out fine. I did have a local tranny shop hook up a scan tool and go for a ride with me he got 3 codes I did not get the numbers but I think they were
Incorrect gear ratio 2nd gear
Incorrect gear ratio 3rd gear
Incorrect gear ratio 5th gear
He also vearfied that when I stoped the truck that the computer was comanding it to be in 5th gear?? And when this happens if you manualy shift it from D to 1st gear and try to pull out it gets stuck between 2 gears 1st and 5th I think (it is like trying to pull out with the E-break on) but the scanner said the computer was comanding 1st gear. He told me to take it to a Ford dealer he did not know what was wrong.
I did some reaserch and found out about the separator plate and pressure relef valve, called up Ford got all the parts and installed them yesterday put it back together with a new filter and some fresh mercon V tranny fluid took it for a ride and the same thing happened.
P.S. The valve body gasket was blowen in 2 places. Any idea what else it could be?
Thanks, Paul
Old 05-19-2008, 06:47 PM   #7
Glen4X4
Lewistown, Pa
2000 XLS
Vehicle Specs
Quoted: 3 Post(s)
Welcome To The Forum!
__________________
96 Explorer XLT Gone
03 Silverado 1500 LS 4X4
00 Subaru Outback Limited SDN
Glen4X4 is offline   Reply With Quote
Old 05-19-2008, 06:51 PM   #8
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
Feed the truck Viagara....no more "limp" mode...
Sorry...couldn't resist. Welcome to the site!
It almost sounds like you have a bad sensor that is feeding the computer bad information.
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 05-19-2008, 06:58 PM   #9
no164ford
N-Cambria PA
2000 Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
If I thought it would work I would shove 10 of them in the tank
Old 05-19-2008, 10:46 PM   #10
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Check the wiring harness, and the DTRS. This is the range sensor which is located near the shift linkage on the driver's side of the transmission.
Old 05-20-2008, 12:43 AM   #11
no164ford
N-Cambria PA
2000 Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I will check the wiring tomarrow, How do you test the sensor?
Old 05-20-2008, 12:58 AM   #12
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
You could use a continuity tester to test it in many ranges.
Old 05-20-2008, 02:56 PM   #13
no164ford
N-Cambria PA
2000 Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
wiring looks fine kinda like new did not test sensor yet got to get a new battery for my meter. You don't that it is in the valve body?
Old 05-20-2008, 05:20 PM   #14
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
It's not in the valve body. It's an external sensor.
Old 05-21-2008, 12:04 AM   #15
no164ford
N-Cambria PA
2000 Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
could it be a the computer?
Old 05-21-2008, 08:06 AM   #16
35Remmy
Binghamton NY, Hazleton PA, Northern NJ
'88,'99 Ranger, '00 EX
Vehicle Specs
Quoted: 0 Post(s)
I occasionally have the same, well kind of the same, problem. Sometimes when taking off from a start, typically right after I start the truck, the tranny seems like it is stuck in 2nd or 3rd gear...it will shift ONCE and then the RPM's will just climb with no other shift.
If I put it in Neutral and then shift it back to Drive, it corrects itself.
35Remmy is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
