Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
how do you test coil packs?
Reply
Thread Tools
Old 05-25-2008, 03:01 AM   #1
92xltriceeater
wisconsin
92 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
besides spark being totally absent how can you test coil pack? getting poor gas mileage and just did a full tuneup and wanna make sure my coil packs are still good and strong???
92xltriceeater is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-25-2008, 03:05 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 426 Post(s)
Check the resistance of each one, and compare the results.
BrooklynBay is online now   Reply With Quote
Old 05-25-2008, 03:15 AM   #3
92xltriceeater
wisconsin
92 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
key on engine off? while cranking?
Old 05-25-2008, 03:32 AM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 426 Post(s)
Remove the entire coil, and test its resistance. Do one at a time.
Old 05-26-2008, 03:49 PM   #5
btprofessional
Sacramento, CA
'91 XLT
Vehicle Specs
Quoted: 0 Post(s)
what should the resistance be?
btprofessional is offline   Reply With Quote
Old 05-26-2008, 09:56 PM   #6
atistang
Ohio
94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
idk, gm waste spark coil packs are like 40-60k ohms
but you could always just compare them, if one is way off from the others then it is probably bad
atistang is offline   Reply With Quote
Old 05-26-2008, 11:13 PM   #7
redneck21
Georgia
1999 sport
Vehicle Specs
Quoted: 0 Post(s)
Get some on to sick a screw driver on it and crank it. If they scream then it's fine. Mint need 6 friends to check them all tho. lol
redneck21 is offline   Reply With Quote
Old 05-27-2008, 02:59 AM   #8
seth247
Tulsa, Oklahoma
'92 XLT 4X4
Vehicle Specs
Quoted: 1 Post(s)
this test works pretty good.
Dont forget to check the degree of burn on there hands. this can be a good indicator of coil condition.
also make them sign a waver before hand. i forgot and the judge didn't seen to understand the logic behind my train of thought that led to the test.
__________________
-Matt
Forest Green'92 XLT 4X4 302/4R70W
To all those in uniform, past and present. Thank You.
seth247 is offline   Reply With Quote
Old 05-27-2008, 01:23 PM   #9
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Anything less than a 3rd degree burn indicates a bad coil
__________________
91 Eddie
Bunch 'O' Mods- 35's, winch, gears, blah blah
www.southernxplorer.com
91exploreron37 is offline   Reply With Quote
Old 05-27-2008, 02:02 PM   #10
redneck21
Georgia
1999 sport
Vehicle Specs
Quoted: 0 Post(s)
You for got the smoking hair too.
Old 08-02-2008, 04:41 PM   #11
duke16
Raleigh, NC
1997 5.0L AWD XLT
Vehicle Specs
Quoted: 4 Post(s)
I have my coil packs off, but I'm confused as to how to check the resistance. My multimeter keeps reading "1" no matter what I do. What exactly do I touch to what?
Thanks
__________________
1997 Explorer 5.0L AWD XLT
Torque Monster Headers | BFG A/Ts (31/9.50R15) | Rancho RS5000s Shocks
Remote Transmission Filter/Mobil 1 Transmission Fluid | Class III Hidden Hitch
Mac Performance Intake | Engine Rebuilt | Warrior Shackles/TT Lift | Flo Pro Muffler (FP736)
duke16 is offline   Reply With Quote
Old 08-02-2008, 10:25 PM   #12
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 426 Post(s)
Is your multimeter a digital autoranging model?
Old 08-02-2008, 10:55 PM   #13
duke16
Raleigh, NC
1997 5.0L AWD XLT
Vehicle Specs
Quoted: 4 Post(s)
Quote:
It's digital, but it has various ranges that need to be set manually.
__________________
Old 08-02-2008, 11:19 PM   #14
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 426 Post(s)
Maybe it's in the wrong manual range?
Old 08-02-2008, 11:20 PM   #15
duke16
Raleigh, NC
1997 5.0L AWD XLT
Vehicle Specs
Quoted: 4 Post(s)
I tried them all.
__________________
Old 08-02-2008, 11:29 PM   #16
90ranajo
The Little TJ that could
Not here nor there
90ranajo's Avatar
O|||||O
Vehicle Specs
Quoted: 2 Post(s)
1. Turn the ignition switch OFF, disconnect the battery, then detach the wiring harness connector from the ignition coil to be tested.
2. Check for dirt, corrosion or damage on the terminals.
PRIMARY RESISTANCE
Use an ohmmeter to measure the resistance between the following terminals on the ignition coil, and note the resistance:
1. B+ to Coil 1
2. B+ to Coil 2
3. B+ to Coil 3
The resistance between all of these terminals should have been between 0.31.0 ohms. If the resistance was more or less than this value, the coil should be replaced with a new one.
SECONDARY RESISTANCE
Measure, using the ohmmeter, and note the resistance between each corresponding coil terminal and the two spark plug wire towers on the ignition coil. The coil terminals and plug wires towers are grouped as follows:
1. Terminal 3 (coil 1) spark plugs 1 and 5
2. Terminal 2 (coil 3) spark plugs 2 and 6
3. Terminal 1 (coil 2) spark plugs 3 and 4
If the resistance for all of the readings was between 6,50011,500 ohms, the ignition coils are OK. If any of the readings was less than 6,500 ohms or more than 11,500 ohms, replace the corresponding coil pack.
__________________
O|||||O
KG7MXH
90ranajo is offline   Reply With Quote
Old 08-05-2008, 08:29 AM   #17
duke16
Raleigh, NC
1997 5.0L AWD XLT
Vehicle Specs
Quoted: 4 Post(s)
Ah, well that makes more sense. Thanks.
I got around 13.54 - 13.76 K between the 4 pairs. I compared those numbers to another set of identical coil packs and got numbers that were a little higher, 15.03 - 15.22 K. So seeing as the numbers on my coil packs were all in same ballpark and close to a set that a pulled of an Explorer that has no idle/hesitation trouble, are my coil packs OK?
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
