Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How to roll up auto window manually??
Reply
Thread Tools
Old 06-08-2008, 05:23 PM   #1
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Hey guys, passenger window decided not to roll up today, neither from driver door or passenger door switches. The motor is getting power from the driver side and passenger switch, checked the power at the motor, relays seem fine, not sure which of the like 6 it is. Does anyone know which it is? Bottom to top there is big one, big one, 2 smalls next to each other, two smalls next to each other. I'm sure you all know. But if anyone knows which is the one to check than I can pay more attention to it.
Anyways, of course it's stuck down so i was wondering if anyone knows a way to get it up without pullin the whole thing apart. Thanks.
__________________
98 Mountaineer - Chopped top, welded, 3" BL, TT, shackles, jeep lift spring bastard pack, 34x10.5x15 swampers on white wagon wheels, cb, alpine deck, Infinity Speakers, 1 mile 2 way remote start/alarm, etc.
oplitic is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-08-2008, 05:55 PM   #2
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
I assume you have a two door... and the driver's side works fine... right? IF SO, then you have a broken wire and since you checked for voltage at the motor... right....;-).... it would "appear" not to be a voltage problem... :-) maybe... what wire at the motor did you find voltage on?
PS. take a meter to the switch on the passenger side and make sure that the switch is functional (ie. you continuity thru the switch when it is operated in either direction).
budwich is offline   Reply With Quote
Old 06-08-2008, 06:26 PM   #3
Charlie
Wisconsin
2000 Limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
It's a mountaineer, so, a 4 door
__________________
Link to lift and max tire size info
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
Charlie is offline   Reply With Quote
Old 06-08-2008, 07:09 PM   #4
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
OK... let's start over then, you need to check at the motor whether you are seeing voltage and a ground, voltage only, ground only.... and then do the same check at the switch.
Old 06-08-2008, 08:36 PM   #5
Pensa
Pensacola Florida
1995 Explorer Expedition
Vehicle Specs
Quoted: 1 Post(s)
If yours did what mine did I don't know of any way to fix it short of taking the door panel off. My driver door window stuck down and it wasn't the motor. I removed the moter and it was fine. I had to put the window up manually a little ways and then re-install the motor.
It hasn't happened again, but I don't put the window all the way down. I leave it up about a quarter of an inch.
Pensa is offline   Reply With Quote
Old 06-08-2008, 10:54 PM   #6
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Forgot, they're reverse polarity, correct? Like locks on some older cars, damn should thought of that. I was definitely getting voltage at the motor and switch from both driver and passenger side switches. I'll check to make sure it's getting ground on the other wire. Guess it's time to put it back in. I took the motor out and was gonna make sure and see it wasn't working. I didn't see any other way to get it rolled up. If I didn't have over $2k in audio I wouldn't have even bothered, but I work in the middle of a city.
__________________
Old 06-08-2008, 10:56 PM   #7
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
You just took it out, put it back in and it worked? Hope that works for me tomorrow when I put it back in to see if it's giving it ground.
__________________
Old 06-08-2008, 10:58 PM   #8
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
One more thing. The motor can just go in, doesn't need to be at it's original spot when I took it out, cause it only senses the resistance of the motor and won't go farther, correct?
__________________
Old 06-09-2008, 07:47 AM   #9
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
its sounds like your passenger switch is broken.
Old 06-09-2008, 08:03 AM   #10
Pensa
Pensacola Florida
Vehicle Specs
Quoted: 1 Post(s)
Quote:
I had to raise the window manually a little bit before I put the motor back in.
Apparently mine was binding when the window was all the way down.
The pinion on the motor doesn't have to be in any particular position when you install the motor.
Old 06-09-2008, 09:12 AM   #11
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Ok, thought so.
__________________
Old 06-09-2008, 09:14 AM   #12
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I am starting to think that too. I'm at work now and just tested the motor on the bench we use to test radios and it works fine, back and forth. So it apparently wasn't switching ground on the other wire. I'm gonna hopefully through it back in tonight when I get home and try it. Then try a switch from a junk yard and see if that helps it. Are the switches on the rear door the same cause there's only one switch on those doors too? I can use one of those for now.
__________________
Old 06-09-2008, 09:44 AM   #13
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
Yep... that will "quickly" help you determine if it is a switch (replaced with a known working one) or a broken wire going to the switch which is still a possibility.
Old 06-09-2008, 10:35 AM   #14
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
it was giving power to the motor on each wire back and forth9the reversing polarity) so part A of reversing works, lol. it's the part B of switching the other wire to ground that i think isn't working.. I'll have to play with it
__________________
Old 06-10-2008, 09:03 PM   #15
btimm86
virginia
'95 explorer expedition
Vehicle Specs
Quoted: 0 Post(s)
haven't found a thread that answers the initial question. How do you actually roll up the window manually? forget the motor, its broken. for now i'm trying to get the window up on someones explorer manually.
btimm86 is offline   Reply With Quote
Old 06-10-2008, 09:31 PM   #16
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Quote:
I ended up taking my motor out and pulling it up. Couldn't figure out any other way. Tomorrow I'll be putting it back in though cause the motor works fine. Than be doing more testing of wires to see what's wrong.
__________________
Old 06-11-2008, 05:59 AM   #17
btimm86
virginia
Vehicle Specs
Quoted: 0 Post(s)
did you have to drill the motor out of its rivets and find some way to put it back in? I dont even know how you could line it up inside there, no room! and all that stuff to attach.
Old 06-11-2008, 10:28 AM   #18
oplitic
Deering, NH
98 Mounty
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
It sucks. Yeah, I drilled out the rivets. And tkaing it out was a bitch, so I'm sure putting it back in will suck too. Putting it back in today. There wasn't much to attach though... three little black bolts from the gear holder thing, the three rivets, which I will be replacing with bolts cause I'm out of rivets and don't want to rivet it back on just incase there's some other problem. Oh, and there's one or two nuts I believe. You don't have to line it up how it went originally, so that makes it easier too.
__________________
Old 06-11-2008, 11:22 AM   #19
Pensa
Pensacola Florida
Vehicle Specs
Quoted: 1 Post(s)
You can pull the window up manually, but you will have to remove the motor to do that. Once up re-install the motor and that will hold it up.
Old 06-11-2008, 11:26 AM   #20
btimm86
virginia
Vehicle Specs
Quoted: 0 Post(s)
wow yeah doesn't sound like i'll be doing this. Its not my car its my step dads. he can pay 250 to have it fixed
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
