Robert
- October 26, 1999
- Location
- CA
- Kelseyville, CA
- '13 Ram 1500 Longhorn
I posted this under a previous thread, but I think it should get it's own thread since there are several people here that have experienced either the intake manifold o-ring leak or camshaft tensioner rattle, or both.
I just found out that apparantly Ford has issued a voluntary recall on the camshaft tensioners as well as the lower intake manifold o-rings. The bulletin number is 00M12. It is not listed on NHTSA.com yet though. The latest one they list is 00M11 which is the voluntary recall for the broken swaybar links. The camshaft tensioner warranty sounds like it is lumped in with the intake manifold o-ring warranty. The warranty on both was supposedly extended to 6 years/72k miles. It is apparantly an "Owner Notification Program" and covers certain '97-'00 Explorers with the SOHC V6. The vehicles covered are vehicles built at the Louisville and St. Louis Assembly plants from Job #1, 1997 through April, 2000. If either item requires replacement, the dealer is instructed to replace both with upgraded parts at the same time, at no charge to the customer. Part of the message isn't too clear about how long it will last, but it appears that it will only last until April 30, 2001. That seems likely though considering their voluntary recall on the oil pump a few years ago only went for so long before it expired. I will be calling a Ford dealer on Monday to see if they know anything about it. If it is as new as it looks, they may not.
