Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
BAD oil Leak
Reply
Thread Tools
Old 11-26-2000, 08:08 PM   #1
Lamah
Michigan
91 XLT
Vehicle Specs
(Original Poster)
My explorer started leaking oil about a week after i got it. I took it to a instant oil change place just in case they had someway to fix it. Some way or another, the leak stopped for a day or so. I also put in some Gunk leak stopper stuff, and that might been why. But then i was on some dirt trails and when i accelerated, the oil pressure completely dropped and went back up when i let off the gas. When i checked the level, it wasnt even on the dipstick, so i added 3 quarts of oil tha i had with me. I got to a gas station and put in 2 more quarts there. The oil was practiaclly pouring out. Then i stopped by meijers and got 6 quarts and another leak stopper and put in another 3 quarts + leak stopper and for now it seems to have stopped leaking. But i dont trust it enough to take it anywhere that i could get stranded. The oil looks like its comming from around the oil filter area on the the passenger side. The oil place said it looked like valve gaskets and the rear main. Both times it started leaking again were after the rpm's had hit about 4000, the first time was when it wasnt moving, the second was in first gear.
My uncle said it could also be a bad pressure sensor and its leaking from there. Any advice on what i should do is always welcomed.
Thanks and sorry for the length =/,
Jeff A.k.a. Lamah
__________________
<sold>
1991 Explorer 4x4;
SOLD:Pioneer deh-p7200 hu, ppi a600.2, two Infinity Kappa Perfect 12" subs;
5-speed manual;
V6, 4.0;
Warn Manual Hubs;
</sold>
1991 Jeep Cherokee Laredo ( i know, but it was cheap )
www.Sheepz.net;
Lamah is offline   Reply With Quote
Old 11-27-2000, 02:25 AM   #2
Ray Hutchinson
Moderator Emeritus
Dana Point, CA
Ray Hutchinson's Avatar
'93 XLT
Vehicle Specs
Thumbs down Bad Oil Leak
Lamah,
You probably already know this, but first step is you've got th find out exactly where it's coming from. You need to clean up everything under the engine really well: go to a pressure wash place or something similar to get all the old oil off the motor so you can spot a new leak right away. Then your'e going to have to get underneath with a light, while someone else revs it up to boost the oil pressure, and try to find the source. Since you said the oil was coming out near the oil filter, presumably the oil change shop checked for a bad gasket on the oil filter. Ideally, they put on a new filter. I've heard of the old oil filter gasket sticking onto the filter socket, when the filter is removed, and then a new filter with gasket is installed, and this will sometimes cause a leak, also the gasket can get pinched when the filter is screwed down... two other things to check for. Hope it's something simple and cheap!
__________________
Ray, & Debby Hutchinson, AE6H
AKA: Pack Rat
'93 White XLT, Modified, lotsa radios
'06 F250 SD Dsl (Big Red 'Plorer Puller)
'01 Lincoln LS-V8
'66 'Stang CA Sprint
Ray Hutchinson is offline   Reply With Quote
Old 11-27-2000, 03:15 PM   #3
Lamah
Michigan
91 XLT
Vehicle Specs
(Original Poster)
thanks
__________________
<sold>
1991 Explorer 4x4;
5-speed manual;
V6, 4.0;
Warn Manual Hubs;
</sold>
www.Sheepz.net;
Old 11-27-2000, 03:22 PM   #4
CHH777
Once...
Houston, TX
CHH777's Avatar
1994 Mazda Navajo LX 4x4
Vehicle Specs
As your uncle suggested check your oil pressure sending unit. They are half plastic and half metal and the point where the two materials meet is notorious for developing leaks. Good luck...
CHH777 is offline   Reply With Quote
Old 11-27-2000, 10:48 PM   #5
Lamah
Michigan
91 XLT
Vehicle Specs
(Original Poster)
i think tommoror i'll drain the oil so i can take the oil filter off, the oil runs down the oil filter and i cant see past it. I'll check the stuff you guys suggested, but if i cant get it, i'm taking it to the mechanic. It needs some other stuff anyways and its my first car, so i'll let them take car of this problem.
Also, the oil doesnt leak, if at all it drips a little bit, but when i start it it POURS out. If that helps anyone think what else it might be, let me know. This explorer is begining to get a pain. Ah well, thats the price i pay for a nice truck
Thanks,
Jeff A.k.a Lamah
__________________
<sold>
1991 Explorer 4x4;
5-speed manual;
V6, 4.0;
Warn Manual Hubs;
</sold>
www.Sheepz.net;
Old 11-28-2000, 05:37 PM   #6
Lamah
Michigan
91 XLT
Vehicle Specs
(Original Poster)
Bah, looks like its not the pressure thing ... i didnt drain the oil or anything yet, but where is the oil pressure thing located? i think its underneath near the front of the engine, but if thats not what usually leaks, please let me know =/
Thanks,
Jeff A.k.a. Lamah
__________________
<sold>
1991 Explorer 4x4;
5-speed manual;
V6, 4.0;
Warn Manual Hubs;
</sold>
www.Sheepz.net;
Old 11-28-2000, 11:42 PM   #7
Lamah
Michigan
91 XLT
Vehicle Specs
(Original Poster)
well, just keeping you posted. Some kind of support for the wireing harness, i think, came loose and rubbed a hole in the oil filter, which explains why getting the filter changed stopped the leak temporarily. And also why it poured out with pressure.
Note to all car owners: Never over look simple things!
Thanks for the help, luckily it was a cheap 5$ fix
Jeff A.k.a Lamah
__________________
<sold>
1991 Explorer 4x4;
5-speed manual;
V6, 4.0;
Warn Manual Hubs;
</sold>
www.Sheepz.net;
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
You smoke cigarettes? FourXFred General Topic Polls 167 11-12-2011 09:12 PM
gas in oil? = bad mpg? 94billybad*** Under the Hood 8 01-25-2003 11:33 AM
OK How does a bad lower intake gasket cause you to burn oil????? please help! Isaac Under the Hood 4 10-21-2001 07:16 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
