Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks 2011 Explorer Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo.
Reply
Thread Tools
Old 06-24-2008, 07:57 PM   #1
little x
SW VA
'91 XL
Vehicle Specs
How to: Push Button Starter
First off: What you do to your truck is done by you, not me. This is just an overview of what I have done to my truck. If you do the same and it F’s your truck up, or someone steals it, or you kill yourself, It’s Not My Fault!
This is a write up of how to install a push button starter on your 1st gen X. I have been running my truck this way for 3 years now with no problems. If you set up your truck the same way as mine then you will be able to start and run the truck without the key. But, the steering wheel will be locked without the key. So the engine runs, but you can’t drive it any where. I find this useful for warming the truck up in the mornings without anyone being able to steal it. And plus it just looks cool.
My set up is using one switch to turn on the accessories, one switch to turn on the ignition, and a push button for the starter. I bought this mounting plate to make the installation go a little smoother and look a little flashier, but it’s not required. You could just pick up a few high amp switches and a button at the local parts store and put them just about anywhere.
First off disconnect your battery. There are several Hot wires you may be messing with.
Now you need to remove the plastic part of the dash that is underneath the steering column. First disconnect the hood release, it is held on with 2 bolts.
Then unscrew the 2 bolts at the bottom corners of the panel, and remove it, the top is just wedged in.
Now you need to remove the two large bolts that support the steering column. The wheel will sag down giving room to access the ignition switch which is on the top of the steering column, close to the firewall.
Disconnect the ignition switch, there are clips on the front and back.
This is a pic of my ignition switch, after some wires have been trimmed.
By now you should have already planned out where you are going to mount your switches and push button. Have you? Ok then. What you are going to do is cut off certain wires that are running to your ignition switch, and extend them to the switches and button you are installing.
Here is a diagram of the Ignition Switch. Each wire with a black bar across it is going to be cut and run to a switch. The wire colors in this diagram and the next remain the same. I’m not 100% sure what the “proof” wires are, or what the ignition bypass circuit is, so I left those wires, and the 2 power wires all connected up.
You will need to run 2 power wires from the battery to your switches, every other wire (except for one jumper) comes from the cut ignition switch wires.
Wire up you switches and button.
Reinstall the ignition switch so that the proof wires will still get power. Reconnect the steering column support. Put the dash panel back on. Reconnect the hood release. Reconnect the battery and start it to see if it works.
Let me know if you have any questions.
little x is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 06-24-2008, 08:30 PM   #2
LBarr2002
Leesville, SC
'91 XLT 4x4, '92 XLT 4x4
Vehicle Specs
Looks clean. I've been running mine with push button for about a year now because the metal silver piece on my ignition switch came off and I didn't want to mess with it any more. The differences are:
I didn't cut any wires to the ignition harness. I had previously had a bulldog remote starter, so I ran a new hot wire to my switches and from the switches tapped in to the ignition and accessory wires. So, it can still be started and driven with a key and not touching the buttons.
For my switch panel, I put a Moroso drag racing panel, 5 switches and a momentary for starter, in the top of my center console lid. I cut the lid, set the panel in, did all the wiring inside the console, so its easy to access and the arm rest covers up the switches. So if you don't know its there...you can't see it.
I also removed my key switch, turned it "one click" (one tooth on the gear) forward and reinstalled it. That way when the key is out and the switch is locked, it is in the area where the steering wheel and transmission shifter are unlocked, but nothing is on. So you don't need a key to drive at all, and it can't "accidently" lock the steering wheel while you're driving without a key.
If anyone's interested let me know and I'll take some pictures.
__________________
'87 Samurai, Dana 44's, 5.89's, spooled
'92 XLT 4x4, 5.13's, Locked, SOLD!
'91 XLT 4x4, stock, SOLD!
'07 Honda Civic SI sedan, DD
'01 Chevy 2500HD Duramax 4x4 - The Toy Hauler
LBarr2002 is offline   Reply With Quote
Old 06-25-2008, 04:41 AM   #3
seth247
Tulsa, Oklahoma
seth247's Avatar
'92 XLT 4X4
Vehicle Specs
Nice rightup man.
But you don't have to take apart the steering wheel to get to the ignition and starter wires.
They(along with all the other wires in the column) come out of the top of the column underneath the dash. You don't have to remove any panels. Except to mount your switch.
If I remember correctly the ignition on wire is red w/light green stripe and the starter contactor wire is red w/light blue stripe. Though that could be backwards.
Go to comandocaralarms.com or the12volt.com and you can find wiring diagrams.
Will make the install go faster.
I finally hooked mine up last weekend using the oil pressure switch as a failsafe. It was acting up the other day. Think I may have made a bad connection.
__________________
-Matt
Forest Green'92 XLT 4X4 302/4R70W
To all those in uniform, past and present. Thank You.
seth247 is offline   Reply With Quote
Old 06-25-2008, 08:44 PM   #4
Rust_Sucks
Chillicothe, Ohio
Vehicle Specs
Hey, can someone tell me if I`m right. To kill the engine all you would do is turn the ignition switch off, correct?
Rust_Sucks is offline   Reply With Quote
Old 06-25-2008, 11:13 PM   #5
sn0border88
Master Apprentice
Souderton, PA
sn0border88's Avatar
1992 XLT
Vehicle Specs
I was in a hurry one day and the ignition wasnt working so I ran a 12v from the battery to a push button and ran the other to the starter sol. You still need to turn the key to on.
__________________
My Photos---Emily Rose---SAS Thread---My Mug
1992 4dr XLT. SAS'ed HPD44/9" 5.13's Locked F/R 36" SX
1999 4.0 5spd sport on 31" BFG Muds
sn0border88 is offline   Reply With Quote
Old 06-26-2008, 08:41 PM   #6
LBarr2002
Leesville, SC
Vehicle Specs
Rust- the Way little X and I have it set up, to kill the engine you turn off the switch that you have on the ignition. I think that would be the one that he has as a covered switch.
__________________
Old 06-27-2008, 04:55 PM   #7
mechjames
Triangle Beach Explorer
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
my buddy did this to his 86 jeep cherokee
mechjames is offline   Reply With Quote
Old 07-09-2008, 03:58 PM   #8
jawlessemu
buffalo, new york
91 sport
Vehicle Specs
how many amps should the switches be?
jawlessemu is offline   Reply With Quote
Old 07-09-2008, 08:45 PM   #9
little x
SW VA
'91 XL
Vehicle Specs
I think I used 25 amp switches, I just picked up the most powerful switches advance auto had.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
