Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
Egr valve help
Reply
Thread Tools
Old 07-06-2008, 09:00 PM   #1
V8powerbaby
Altus,OK
'00 V8 XLT
Vehicle Specs
(Original Poster)
Egr valve help
well been haveing this trouble code going on here latly and i checked come to find out its my egr valve. my question is any good write up on how to do this? i looked it a couple days ago and all it did was start to piss me off those bolts are in the worst postion ever. I need and kinda of help here guys. thanks
V8powerbaby is offline   Reply With Quote
Old 07-06-2008, 09:03 PM   #2
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
What code are you getting?
p0402 ? or p0401?
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is online now   Reply With Quote
Old 07-09-2008, 01:26 PM   #3
V8powerbaby
Altus,OK
'00 V8 XLT
Vehicle Specs
(Original Poster)
p0401 is the one im getting JT
Old 07-09-2008, 01:35 PM   #4
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Thats a low flow code-
could be just plugged up, or maybe even a leak? Is the egr tube crakcked? to you have the tick tick-gurgle old engine sound?
__________________
Jon
2000 Mountaineer
Turdle-gone
Old 07-09-2008, 01:47 PM   #5
V8powerbaby
Altus,OK
'00 V8 XLT
Vehicle Specs
(Original Poster)
i got tick tick old engine sounds no gurgle
Old 07-09-2008, 01:53 PM   #6
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
You might have a cracked egr tube-which would cut the flow of egr to the dpfe sensor, giving a po401 and an exhaust leak noise-
this tick gets worse as the truck warms up, and when giving it gas, like going up a hill. Yes? You might even listen in that area, while someone gives it a bit of gas. I'll bet you'll see something then.
Your truck should have the strnger cast manifolds, but i would be sure all the bolts are present, and tightened. I have seen 2 so far with missing bolts.
Any exhaust leak on the passenger side of 97-01 V8 will also be an egr leak
egr valve rarely go bad, but they do get plugged up-
however, the egr tubes on these crack left and right.
The best thing to do is get the air box -and coolant reservoir thingy out of the way. Then you can get the tube off.
It's about 65.00 at the stealership.
__________________
Jon
2000 Mountaineer
Turdle-gone
Old 07-09-2008, 01:56 PM   #7
V8powerbaby
Altus,OK
'00 V8 XLT
Vehicle Specs
(Original Poster)
sweet deal thanks man
Old 07-18-2008, 07:18 PM   #8
nternes
Black Canyon City
2000 Mountaineer 5.0
Vehicle Specs
Found the EGR valve at auto zone for $46 it was a nightmare to get off, not quite as bad going back on. It did not fix the problem.
nternes is offline   Reply With Quote
Old 07-18-2008, 11:11 PM   #9
KPT
NC
'95 XL 4x4
Vehicle Specs
Every EGR problem I have personally seen the problem has been the DPFE.
KPT is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
