crossbones
- July 20, 2008
- OKC, OK
- 2001 Sport Trac
Hey guys need help, I have a 2001 Sport Trac and I am having problems with an 8.8 limited slip rear differential pinion seal leaking. Do any of you know if I can change this seal without having a problem with the preload on the bearings? I read where this can be a big problem if the preload is not set right.
If it is not a problem setting the preload, then how do I keep from getting the pinion nut too tight or too loose?
