Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
1992 Ranger Clutch Problems
Reply
Thread Tools
Old 07-22-2008, 07:46 PM   #1
BTRs X
Maysville, KY
BTRs X's Avatar
'92 Explorer XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My 1992 Ford Ranger 4x4 4cyl 5-spd has a clutch issue. I have had a small leak in my clutch system which requires me to refill it every 3-4 months. Today after about a 120 mile trip, I pulled up to a stop light and noticed there was no clutch pedal pressure when I pushed it...and the truck stalled before I could pull it into neutral. The only way to take off is to put the truck into 1st gear and crank it, but that is just to move it...it won't let you shift into any other gears. The clutch has only 17K miles on it...could this just be my slave cylinder? Thanks for any help. I depend on this truck to get me to work!
__________________
Brandon Ross
'92 Ford Ranger XLT 4x4
4cyl./5-Speed
Daystar leveling kit
BTRs X is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-22-2008, 07:54 PM   #2
Jameskennedy
British Columbia
1996 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
could be just air in the system blled it and refill and see what ya get. Been dealing with clutch issue for months finally got clutch all good after a lot of work.
Jameskennedy is offline   Reply With Quote
Old 07-22-2008, 08:27 PM   #3
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Look under the truck and see if you can find where the leak is coming from but more than likely its the slave since these transmissions are bad about that.
__________________
91 Eddie
Bunch 'O' Mods- 35's, winch, gears, blah blah
www.southernxplorer.com
91exploreron37 is offline   Reply With Quote
Old 07-22-2008, 08:51 PM   #4
BTRs X
Maysville, KY
BTRs X's Avatar
'92 Explorer XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Since this just happened and the clutch just has 17K miles on it...could I just inspect the clutch and replace the slave cylinder? Thanks.
__________________
Brandon Ross
4cyl./5-Speed
Old 07-22-2008, 08:59 PM   #5
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Oh so you got the clutch replaced and didnt replace the slave cylinder? tisk tisk If so then yes you can do that.
__________________
91 Eddie
Old 07-22-2008, 09:06 PM   #6
BTRs X
Maysville, KY
BTRs X's Avatar
'92 Explorer XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Im really not sure. The clutch was replaced by the previous owner...Im not sure what all was replaced...how long does a typical clutch last? Thanks.
__________________
Brandon Ross
4cyl./5-Speed
Old 07-22-2008, 09:15 PM   #7
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
It really depends on driving style and such. Some clutches last forever while some maybe a few thousand miles. Mine lasted about 5,000 miles but that was with 35's, stock 3.73 gears and hard off-roading, while the clutch in my old 96 ranger was still factory and had over 130,000 miles and was still going strong. The slave cylinders in these vehicles are notorious for going bad and if the previous owner didnt replace it when he had the clutch done then thats more than likely your problem.
__________________
91 Eddie
Old 07-22-2008, 09:59 PM   #8
BTRs X
Maysville, KY
BTRs X's Avatar
'92 Explorer XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well Im leaving on vacation tomorrow so it will be Tuesday before I can get the transmission out and be for sure what the problem is. But I did just go out and look and there is a puddle of fluid under the front of the bell housing. What is a good brand/store to get the clutch and slave from? Thanks for all the help.
__________________
Brandon Ross
4cyl./5-Speed
Old 07-22-2008, 10:07 PM   #9
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 221 Post(s)
Quote:
dialaclutch.com. Stay away from parts store slaves.
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is online now   Reply With Quote
Old 07-22-2008, 10:09 PM   #10
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
If your replacing the clutch then I'd go with the centerforce dual friction. I'm extremly happy with mine.
http://store.summitracing.com/egnsea...115+4294907830
And as far as the slave I guess ford would be the best. I just picked one up from napa.
__________________
91 Eddie
Old 07-22-2008, 10:12 PM   #11
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Originally Posted by RangerX View Post
http://www.dialaclutch.com Stay away from parts store slaves.
Hmm never heard of them before looks like they have some pretty good prices and luk's a pretty good brand.
__________________
91 Eddie
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
