Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Street Truck & Performance Forums > Street Trucks > Need for Speed!
Notices
Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move!
5.0 swap
Reply
Thread Tools
Old 07-27-2008, 02:30 PM   #1
D rock
MN south st.paul
94 sport
Vehicle Specs
(Original Poster)
5.0 swap
i really need help should i do a 5.0 swap or sup up my 4.0its a 94 sport any one do it that can help me how hard is it is it worth it let me kow thank you all
D rock is offline   Reply With Quote
Old 07-27-2008, 03:06 PM   #2
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
1993 Ford Explorer XLT
Vehicle Specs
Quote:
First you have to ask yourself a few questions:
1. How much are you looking to spend?
2. How long are you wanting to spend?
3. What is your reasoning for the buildup or swap?
4. If you do the 5.0L swap, can you deal with not having the Explorer as a driver for a few weeks, or possibly a few months?
5. Do you have access to get all the parts for the 5.0L swap? Harness, Engine, Transmission and anything else needed?
When you answer these, you can figure out which will be better for you. I'm not trying to discourage you, but a lot of people talk of doing the 5.0L swap without knowing what they'll be getting into. Each goes into what you're thinking about. Granted 410 did his in a Bronco, he was switching from the same style engine you have to the 5.0L
Here are a few threads to help you out though. Read them, front to back, and THEN make your decision.
Dreaming of one mean 4.0: The Build up - Creager's 1992 Sport
410 fortune - 5.0L EFI 4R70W drivertrain conversion SUCCESS!!
__________________
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger (New!!)
"You can hear me when I'm coming" - Yung Joc
Blacksheep Josh is online now   Reply With Quote
Old 07-28-2008, 11:05 PM   #3
D rock
MN south st.paul
94 sport
Vehicle Specs
(Original Poster)
ok thank you how fast can i make my 4.0 with out forced indution
Old 07-29-2008, 02:43 PM   #4
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
not fast
Its a 4500# 4 door SUV with a 165 HP 235 ft lb torque V6, its never going to be fast
even with the V8 its still not fast
I have 300 HP in a Bronco II, its quick, its a heck of alot of fun to drive, it will pull down a mountain if it needed to, but it still has a difficult time keeping up with a Civic Si
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 07-29-2008, 06:56 PM   #5
Jakee
Huntsville, Texas
Jakee's Avatar
01 Sport
Vehicle Specs
Well, he does have the sport which is not as heavy but it does take money to make it fast.
__________________
STS turbo charged
Jakee is online now   Reply With Quote
Old 07-29-2008, 07:01 PM   #6
Blacksheep Josh
Statesboro, GA
Vehicle Specs
Do you want it fast, or powerful? Cause depending on what you want is going to determine where you go (as far as build wise). If you want it fast, then you'll want good control, steering, suspension. Which most likely means you'll want to lower at some point and throw on some lightweight rims with low resistance tires.
If you want it powerful, we're talking about lifting and some serious beefing up of the rear end, tranny, and engine.
Research man, research.
__________________
Old 07-31-2008, 03:00 PM   #7
D rock
MN south st.paul
94 sport
Vehicle Specs
(Original Poster)
i have it dropped and its a two door sport with cold air intake its almost piped out just needs headers trac bars in back stiff ass coils in front bumpy ass ride im looking for rims now or headers i dont know what ones i want more all the emissions shit is out except for a few by passes
Old 07-31-2008, 03:38 PM   #8
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
Quote:
Hehe.. lifted doesnt mean powerful. And powerful doesnt require lifted. Plenty of rock crawlers and off roaders have tiny tiny engines -- like in the 1 - 2 liter range (Civic engines, Suzuki engines, and so on...). Plus lifting and putting on larger tires kills power because then the vehicle has more resistance and the engine must rotate a larger torque arm (the tires' radius). Translate that into economic terms, then you're talking about decreasing MPG and a lighter wallet
Power is a measure of work over time. And more often than not, it is the street guys that want that tremendous power. Off roaders are more leisurely because most off roaders are more worried about torque (which is time independent, unlike power), and we accomplish this via gear ratio.
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 07-31-2008, 08:11 PM   #9
Jakee
Huntsville, Texas
Jakee's Avatar
01 Sport
Vehicle Specs
Actually, how to you define fast or powerful? My definition is when you mod your truck and can take almost all production vehicles from the factory, then you're in the "fast or powerful" category.
__________________
STS turbo charged
Old 07-31-2008, 08:31 PM   #10
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Power is in the eye of the beholder.
Money is power, so power = money
A brick will fly if you throw it fast enough.
The F-4 phantom comes to mind here--
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is offline   Reply With Quote
Old 07-31-2008, 09:39 PM   #11
seth247
Tulsa, Oklahoma
'92 XLT 4X4
Vehicle Specs
I say do the swap. It's easy enough if you go carb. Harder for efi.
Without the efi it's all basic stuff. Drill hole here, tighten these bolts, tighten those bolts, cut and payst the aircon plenum hook up tranny, slap on a t-case adapter and go.
__________________
-Matt
Forest Green'92 XLT 4X4 302/4R70W
To all those in uniform, past and present. Thank You.
seth247 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
