Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
2002 Explorer Shift Interlock Problem
Reply
Thread Tools
Old 07-29-2008, 06:59 AM   #1
Komobu
Newport News
92 Elporer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi;
I have a 02 Explorer that I can shift out of park. It starts and runs just fine. To shift, I have to use the emergency bypass under the steering column. (There is an access hole where you can release the interlock pawl.
I have tried moving the key out of the lock position and before the run position and it wont shift there either. I have replaced the brake switch and the interlock and it still wont come out of park. There are five wires at the connector. I checked them with AllData and they are OK. I am at a loss as what to do next. AllData says if there is a problem with the Shift Interlock to replace the steering column. That doesn't sound right. Any ideas where to go next? I am thinking maybe the body control module.
Thanks for any advice
Komobu is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-29-2008, 07:47 AM   #2
JCUZ
Canberra, Australia
2004 Explorer Limited V8
Vehicle Specs
Quoted: 7 Post(s)
I assume you have your foot on the brake, and the truck turned to On before shifting? OK, had to get that out of the way. Ours is sometimes hard to get out of Park when we park on a slope, but a bit of gentle persuasion usually sees it move OK in the end. Though I just remembered yours is column shift - might be a broken tooth on the gear handle, rather than anything wrong with the interlock itself.
__________________
2004 Ford Explorer UZ Limited 4.6 V8 5spd auto Pearl White, Thermo fans, 4WD (with BWM 2WD mod)
Lukey sports centre mufflers and rear resonator, Roof mount DVD system, HID driving lights, 120W 20" LED light bar, Expedition Nudge Bar,
Pod filter in the air box, Black factory 17s with 265/65/17 Kumho KL61 ATs, 2" King Springs coil lift, JVC 7" screen - DVD, reverse cam & bluetooth
JCUZ is offline   Reply With Quote
Old 07-29-2008, 01:52 PM   #3
Komobu
Newport News
92 Elporer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I saw a lot of posts on this site about not being able to shift out of park. It is probably a Shift Interlock issue. To see if it is, under the steering column is a little access hole that you can rotate. Then insert a small screwdriver. While holding the screwdriver in place, see if you can now shift. If you can it is the interlock where your problem is.
The first thing to check is to see if you have brake lights. The brake switch feeds 12 volts to the interlock. So if you dont have brake lights, then more than likely your brake switch or fuse is bad and fix that before you go further.
There are two fuses to check. They both must be working for the Shift Interlock. They are in the cabin under dash on drivers side. Fuse # 23 is 15 amp for brake lights. Fuse # 26 is 7.5 amps for Shift Interlock. If either of these fuses are bad, the shift interlock will not activate and you wont be able to shift.
If the fuses check out and you have brake lights, then look at the 6 pin connector under the steering column. You will have to remove the column shroud to see it. A picture of it is here:
http://i47.photobucket.com/albums/f1...u/P1000674.jpg
This is a six pin connector with 5 wires being used. the wires are as follows.
1 Black---Ground
2 Red w/ Light Green Stripe---12 volts when brake pedal applied
3 Grey w/ Yellow Stripe ---12 volts when vehicle in Start or Run
4 White w/Red Stripe ---Ignition switch to Brake Shift Interlock
5 Not Used
6 Black---Ground
So, check for your 2 outer wires being ground and your #2 wire with 12 volts when brake pedal applied. If all this checks out, check the interlock itself. It is located on the left side of the column near the Key and can be seen here:
http://i47.photobucket.com/albums/f1...u/P1000676.jpg
To remove it, you will have to remove the one torx in the photo and three screws under the steering column holding a wire loom to the column.
Once it is removed, let it hang and it will look like this:
http://i47.photobucket.com/albums/f1...u/P1000673.jpg
You will notice it has three wires. They are Green, Black and White. The green should have 12 volts with the vehicle in start or run. The black wire in the center should be ground. The white wire should have 12 volts with brake applied. With the two outer wires being hot, and the center being grounded, you should see the interlock activate. If it doesnt, you know the interlock is bad and must be replaced. Check the connector because that is where my issue was.
Note. The center ground is received from a micro switch near the key. It looks like this:
http://i47.photobucket.com/albums/f1...u/P1000675.jpg
The six pin connector sends the ground to the microswitch, and then it goes through the switch and back to the shift interlock. Sometimes when the brake is pressed, or if the shifter is not in the right position, there wont be a ground. So check for loss of ground if your two outer wires are hot and the shift interlock doesnt work.
Hope you find this useful
Old 07-29-2008, 02:09 PM   #4
rrgone
Tucson, AZ
'02 XLT
Vehicle Specs
Quoted: 22 Post(s)
Quote:
Wow, you took that all apart, diagnosed it, took pics, and then wrote it up, all between 4 am and 11 am!!! You da man! Very nice write up too.
rrgone is offline   Reply With Quote
Old 06-26-2009, 02:05 AM   #5
jessejames82
fresno, ca
2002 explorer 2wd 4dr
Vehicle Specs
Quoted: 0 Post(s)
what is the part called that is conected to the shifter that has the pin going through it? mine is worn out and it is the only thing that hold the shifter on. any help would be great, thanks
jessejames82 is offline   Reply With Quote
Old 08-17-2009, 11:50 AM   #6
chas2002
memphis, tn
2002 xlt
Vehicle Specs
Quoted: 0 Post(s)
I am having trouble with this fix
I am trying to replace the bsi switch as indicated in this thread. I have spent an hour trying to get the wiring harness out of the brake shift interlock switch and I can't get it. I have the switch out and hanging by the harness
I have broken off the tabs as TSB 04-22-12 indicates and I have tried using a small screwdriver to press the tab. It still wont come out. I worry I am going to break the harness. It is already getting a bit chewed up. I am considering trying to tear apart the bsi switch around the harness since I am rplacing it. Any advice would be appreciated.
I am attempting to replace a bad Brake Shift interlock switch on a 2002 explorer.
The presenting problem was (in dollar tree parking lot) truck would start, but not shift out of Park. When I got the steering exposed, the switch began working intermittantly. I got it to my house. Not wont work, but I can overide it.
I should have the part this afternoon.
Thanks for any help
chas2002 is offline   Reply With Quote
Old 08-17-2009, 03:30 PM   #7
chas2002
memphis, tn
2002 xlt
Vehicle Specs
Quoted: 0 Post(s)
I finally got it. I pushed an icepick into the gap created when you break off the tabs on the Brake Shifter interlock switch. And it finally clicked and came off.
Unfortunately I went through all that and the $98 for the BSI switch and found that was not the culprit.
I think it was a loose wire over the break pedal.
Seems to be working now.
Old 08-20-2011, 10:24 AM   #8
victorf2
Hackensack, NJ
2003 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thumbs up Thanks for your great troubleshooting information.
1 Black---Ground
5 Not Used
6 Black---Ground
victorf2 is offline   Reply With Quote
Old 04-16-2012, 09:01 PM   #9
aryoupa
Vehicle Specs
Quoted: 0 Post(s)
04 Explorer Stuck in Park
Hey I know this thread is over a year old but I am currently having a similar problem on my 2004 Ford Explorer and I am still trying to fully understand how the Brake Shift Interlock all works. I am having trouble getting the vehicle out of Park. Most times all I have to do is jiggle the shifter and it will then come out of park. My brake lights are working fine and I have checked my fuses and they are fine too. I pulled the plastic covers from the steering column and I can see that the Brake Shift Interlock seems to be working when depressing the brake. The pin drops, but I still have trouble getting it out of Park. Is there something else that I cant see that should be happening when depressing the brake? I have noticed that when I turn the key to the "on" position, but dont turn the vehicle over I can depress the brake and move the vehicle out of Park and into Neutral without any issue. I can then start the vehicle and be on my way. Can anyone give me any insight as to what the actual problem is?
aryoupa is offline   Reply With Quote
Old 04-17-2012, 12:53 PM   #10
rokr1292
richardsville va
'01 Explorer Sport Trac
Vehicle Specs
Quoted: 1 Post(s)
ive been running without the interlock for months now, i didnt know there was a bypass. or is it just on 2002-2005 explorers?
__________________
Gold 2003 Ranger regcab 2.3 xlt. (Old dd, handed off)
Silver 2001 Explorer Sport Trac 4x4 (new dd as of 3/7/11)
rokr1292 is offline   Reply With Quote
Old 04-18-2012, 04:41 PM   #11
aryoupa
Vehicle Specs
Quoted: 0 Post(s)
As far as I am aware most cars and trucks have the bypass button. Its just normally hidden and never used.
Old 01-29-2015, 09:05 PM   #12
safensound5178
2003
Vehicle Specs
Quoted: 0 Post(s)
Intermittent Shift Interlock and brakes lights!
I am having the same problem with my 2003 Explorer with the Shift Interlock pin not releasing all the time when pressing the brake.
I was checking the brake lights to see if it they were working and sure enough they are intermittent as well and work at the same time the Shift Interlock pin drops.
Could the brake light switch be faulty?
safensound5178 is offline   Reply With Quote
Old 05-21-2015, 07:16 AM   #13
bonz1234
98 eddie bauer 4.0
Vehicle Specs
Quoted: 1 Post(s)
I have a 98 explorer are pretty close to the 2000's for wireing and mechanical
bonz1234 is offline   Reply With Quote
Old 04-26-2016, 09:25 AM   #14
Iridium
Milwaukee
2002 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
Hopefully I have found the proper place for my question. I have a 2002 explorer that is getting stuck in park. I came here to find out how to get it out but it still happens once in a while. The fuses mentioned here ...23 and 26 seem fine but now the brake warning light on the dashboard is flickering. Should i tackle the stop light switch on the brake pedal first? Thenthe shift interlock if needed?Thank you all so much for your posts!!!
Iridium is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
