Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Water leak at back of the engine - FIXED
Reply
Thread Tools
Old 07-30-2008, 09:12 PM   #1
tieoneon
Poland, OH
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
2000 Explorer, 4.0L push rod engine. 165,000 miles
Water is leaking from the back side of the engine. Passengers side. It leaks without the engine running. If I put water into the raditor after it stops leaking it will start again until it drains down.
What is the most likely cause? Head gasket? Intake manifold gasket? Is there a sensor back there? Core plug?
I've removed the air plenium already but still can't see back there.
Is there a usual problem that causes this?
The engine runs fine, no smoke, good power, I obviously can't run it long before it will over heat. This just started all of a sudden.
Thanks for all help and suggestions.
tieoneon is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-30-2008, 09:17 PM   #2
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Yeah probably the gasket. Since you dont have white smoke coming out of the exhaust, then the gasket failure is towards the edge of the block and not towards the cylinder. I would say that some JB-Weld would probably work as a temporary (or permanent if you're me) fix. Just make sure the surface is clean and dry. Also, don't put too much JB weld or it might get into the coolant routes and cause some clogging.
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 07-31-2008, 06:54 AM   #3
tieoneon
Poland, OH
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
If I have to replace the intake gasket, which should I buy? Orginal Ford, Fel Pro, something from Auto Zone? Thanks
Also, any suggestions of do's and don't in changing the intake gasket?
Old 07-31-2008, 07:50 AM   #4
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
Can you crawl under the car and look? You know, it's possible (but unlikely) it's your heater core. Your case drains under the passenger side head. Look under it while it's leaking to see where the coolant is coming from before you arbitrarily tear it apart. If it is the heater core, I'm not sure what would be easier to fix...the core or the head gasket. And if it is the head gasket, have the head and block checked for straight surfaces and surfaces that aren't corroded. No use having to do this again.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 07-31-2008, 08:32 AM   #5
tieoneon
Poland, OH
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I know it's leaking at the back of the engine.
Old 07-31-2008, 09:16 AM   #6
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
I dont think its the intake gasket cauz I dont think there are any coolant lines that run up into the intake. So any damage to the intake gasket would not result in coolant leak. Of course thats assuming we're talking about the same "intake gasket"
__________________
Old 08-01-2008, 07:01 AM   #7
tieoneon
Poland, OH
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It was the intake gasket. Fixed now.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
