Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
Engine won't crank -- Lots of troubleshooting with no result
Reply
Thread Tools
Old 08-04-2008, 07:02 PM   #1
cherrybomb
Southern California
cherrybomb's Avatar
'99 EB 5.0L (R.I.P)
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
So, I hopped in the truck to go back to work after lunch and it cranked for a couple seconds as usual, and just as it would have normally started the dash went dark, the cranking stopped and..... Nothing.
I tried cranking again with no success.
I've tried all 3 keys I have which previously worked. When the key is in the run position or while attempting to crank the "THEFT" light is either blinking rapidly or on solid.
There is no Check Engine Light when the key is in the on position or while attempting to crank.
I have not yet tested the PCM relay, nor checked the 30A PCM fuse, though I would expect that it simply wouldn't start, rather than not cranking.
I've also tried disconnecting the battery for ~5 minutes and retrying, with no success. I do hear a relay clicking on and off beneath the dash on the drivers side of the steering column while the battery is connected.
Any thoughts?
I think that it's an anti-theft problem, but I'm not certain how to troubleshoot further. Gonna consult the service manual, but I was hoping I might get some guidance from users who might have had a similar experience. Search didn't yield anything particularly useful either. :-(
Thanks in advance!
__________________
R.I.P "X"
Check out my Elite Registry
Check out my wife and I's blog
cherrybomb is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-04-2008, 07:20 PM   #2
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
Yeah sounds like the PATS lock system is causing the issue.. You can try to find a locksmith who has the capabilities of programming your keys again or going to the dealer to remedy the problem.
Blee1099 is offline   Reply With Quote
Old 08-04-2008, 07:33 PM   #3
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
Or--
you can buy an xcal with tunes from Henson performance and have him just turn the PATS off in the tune file-
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is online now   Reply With Quote
Old 08-04-2008, 07:40 PM   #4
cherrybomb
Southern California
cherrybomb's Avatar
'99 EB 5.0L (R.I.P)
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Originally Posted by jtsmith View Post
Or--
I might just consider that, but I want to be sure that's the problem first. I'm gonna try playing around with the transceiver and seeing if I can make any progress there.
The great part is, I'm in the middle of swapping heads on my wife's car so we're without a vehicle at the moment. At least the X failed to start at home where I have my tools. I have until tomorrow morning to get a vehicle running so I can get to work.
__________________
R.I.P "X"
Old 08-04-2008, 07:43 PM   #5
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
When you say the cranking stopped, are you saying there was a complete power loss and the starter would not turn the motor over?
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 08-04-2008, 07:43 PM   #6
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
Ok
the cranking stopping has me a bit off track
How is the connection at the starter relay and at the + connection on the starter itself?
Have you tried jump starting it?
The pats does nothing to the starter-only the fuel pump is affected
__________________
Jon
2000 Mountaineer
Old 08-04-2008, 08:01 PM   #7
explornj
now in Raleigh,nc
explornj's Avatar
99 sport 4.0 sohc
Vehicle Specs
Quoted: 1 Post(s)
i was thinking the same thing that something is wrong with the battery, or possibly the main fuse in the fuse block under the hood
explornj is offline   Reply With Quote
Old 08-04-2008, 08:36 PM   #8
cherrybomb
Southern California
cherrybomb's Avatar
'99 EB 5.0L (R.I.P)
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Yes... Well, sorta..
It was cranking, and then stopped completely. When it was cranking though, it was cranking as it would with a full charge in the battery.
The connections to the starter look fine.
The main reason why I'm not suspecting the starter/starting system is because the "THEFT" light blinks rapidly when trying to start.
As for the relay I hear "switching" it's a large yellow relay directly under the steering column.
I know there must be a way, but I can't seem to find a way to "hotwire" the PATS system so that it's removed from the equation.
Looks like I might have to get it towed to the dealership tomorrow. :-(
__________________
R.I.P "X"
Old 08-04-2008, 09:38 PM   #9
cherrybomb
Southern California
cherrybomb's Avatar
'99 EB 5.0L (R.I.P)
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hmmn... More weird symptoms..
I can use the remote to lock the doors, but I cannot engage the alarm. I.E a second press of the lock button does not honk the horn.
Intermittently when I turn the key to the RUN position the dash lights do not illuminate to their full brightness, and the "THEFT" light stutters in sync with what sounds like a relay stuttering.
Lastly, I can't seem to connect to the ECU using my scan tool.
http://www.obd-2.com/
I'm very much afraid that the ECU might be the problem.......
__________________
R.I.P "X"
Old 08-04-2008, 11:04 PM   #10
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
Sounds like a dead battery to me--
Have you tried a jump start?
__________________
Jon
2000 Mountaineer
Old 08-04-2008, 11:06 PM   #11
Willard
Bloomington, Indiana
04 Ranger Edge
Vehicle Specs
Quoted: 1 Post(s)
Seems like it could be a battery to me as well....
I had a similar thing happen to my battery, it just died. Although my starter went with it (I think)
__________________
Jesse
'94 Eddie Bauer DD/Beater
"Old Faithful" RIP
'04 Ranger Edge DD "Black Knight"
You want to see my face?
Willard is offline   Reply With Quote
Old 08-05-2008, 07:51 AM   #12
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
I think these guys are on track with a battery problem. And it may not be a dead battery, it may be a poor connection. Time to clean up all your connections first. Make sure you check the connections at the mega fuse on the driver's side fenderwell. I believe those are either 10mm or 13mm nuts. Also check the connection and harness at the starter. Make sure it's all good and nothing is shorting anywhere.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 08-05-2008, 02:02 PM   #13
cherrybomb
Southern California
cherrybomb's Avatar
'99 EB 5.0L (R.I.P)
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I wouldn't have believed it had I not experienced it for myself, but... It was a dead battery! I was able to start it up no problem with the help of jumper cables and another car.
I've never experienced a battery fail that way. It was (apparently) fully operational, and was cranking my engine as fast as it ever had, then just "poof" it stopped.
Using a meter between the two terminals shows 0 voltage, bizarre!
Thanks all for the help, I was just moments away from having it towed to be looked at because I was "sure" it was some sort of computer/PATS problem. That would have been embarrassing!
Occam's Razor
__________________
R.I.P "X"
Old 08-05-2008, 03:32 PM   #14
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
We once had a Mercury Mistake. When the battery died in it one time, the widnshield wipers and horn turned on.
I think the loss of potential across the various relay coils makes them start clicking on and off.
__________________
Jon
2000 Mountaineer
Old 08-05-2008, 07:54 PM   #15
explornj
now in Raleigh,nc
explornj's Avatar
99 sport 4.0 sohc
Vehicle Specs
Quoted: 1 Post(s)
i have seen to battery's explode when trying to start the car they are strange
Old 08-06-2008, 08:38 AM   #16
Cobraguy
Cobraguy's Avatar
Vehicle Specs
Quoted: 13 Post(s)
I have never experienced anything like that. Weird.
__________________
Old 08-06-2008, 08:40 AM   #17
explornj
now in Raleigh,nc
explornj's Avatar
99 sport 4.0 sohc
Vehicle Specs
Quoted: 1 Post(s)
sounded like a shot gun
Old 08-14-2008, 01:24 AM   #18
Donner
Natomas/Irvine
01 Sp 03 XLT 4x4s, Scion
Vehicle Specs
Quoted: 0 Post(s)
Same problem 03 xlt
Quote:
Is this nut on the passenger side on an 03? It's behind the tire?
Occam's Razor
It clicks rapidly under the drivers side, then slowly.... then stops, then starts again. Could that nut that Cobraguy mentioned cause all of this?
__________________
http://www.explorerforum.com/forums/...d.php?t=240001 For Sale stuff
Donner is offline   Reply With Quote
Old 08-14-2008, 07:17 AM   #19
mawrazen
Atlanta, Ga
94 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Clean you battery terminals and connections!
mawrazen is offline   Reply With Quote
Old 07-17-2010, 09:01 AM   #20
wnieberlein
Baltimore, md
03
Vehicle Specs
Quoted: 0 Post(s)
i am running into the same issue with a few added need help
I have an 03 explorer that was fine yesterday and now today wont even crank. When i put the key in and turn all the dash lights come on as usual EXCEPT the mileage shows dashes for both the truck mileage and trip meter. The battery is fine. i have put a new one in and still same result. I have a viper aftermarket alarm in it and that still seems to work fine also. I need serious help because i only have this one vehicle. any ideas?????? Also, no click under the hood either. its almost like its totally dead. but when i let go of the key the interior dings and the radio turns off and comes back on.... please help.
wnieberlein is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
