surfnturf
- August 6, 2008
- Lincoln Vermont
- 3 1992 and 1 1998
I have instaled a Mercedes 4 cyl. engine and 4 speed std. trans in a 92 Ford Explorer 2 wd automatic. I have a small prob. I knew that the automatic Explorer rearend would be a higher ratio and leaves 4th gear not usable. First gear is a little weak also. Does anyone know what ratio would be good for me. I would like to pull a small camper. I am running FF grease in the Explorer also. This is a test to see how it works and I am very happy with it so far. I will be starting on a 98 4x4 when the 92 is done. I will be going with a 5 cyl. turbo Mercedes engine with this one. The 240D 4 cyl. engine is a little doggy. Thanks, Steve
